Radiator requirement for new Threadripper content creation PC ? - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 12-02-2019, 04:47 AM - Thread Starter
madno's Avatar
Rep: 0
Read a lot about water cooling but am not sure how many radiators I need.
What it is about:
New build for content creation is in the works:
Most relevant load will be GPU und CPU rendering (runs under heavy load for 24 hours). During that the PC is used for other things at the same time (e.g. working on new textures, running new cloth simulations while IRAY, Lightwave or Blender are rendering in the background).
Watercooling planned for two RTX 2080 ti and one Threadripper 3960X
Planned or already bought components:
  • Threadripper 3960X - ordered
  • 64 GB GSkill Trident Z ram (option to go 128 GB) - in the parts box already
  • sTRX4 board with 4 x PCI x16 and 10GB ethernet - ordered (asrock creator)
  • 2 x RTX 2080 ti founder edition (option to go 3 x) for GPU calculations - one is in the box, one to be ordered
  • 1 x RTX Quadro 4000 for display - in the box
  • 3 x Samsung M2 SSDs - in the box
  • 2 Samsung SATA SSDs - one in the box, one later when required
  • water cooling for 2080 ti GPUs - in the box (two EK Vector something)
  • water cooling for CPU - ordered (XSPC RayStorm Neo for AMD sTR4)
  • pump EK-XRES 140 Revo D5 Reservoir pump combo - in the box
  • 3 x EK-Varder 120 EVO static pressure - in the box
  • 1 x EK-Coolstream XE 360 60mm - in the box
  • Case Phanteks Enthoo 719 - ordered
  • PSU Corsair ax1600i - ordered
Is the one radiator sufficient for those components? And is the one pump combo enough even if I would need more radiators?
Thanks in advance for your help.
madno is offline
post #2 of 14 (permalink) Old 12-02-2019, 05:01 AM
Hardware Princess
Hydroplane's Avatar
Rep: 31 (Unique: 26)
It really depends on your noise tolerance I run a 280 push/pull + 420 push for a 7980XE + 2 1080Ti. But my system isn't at full load most of the time. If it was, I'd probably add 1-2 more rads.
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(11 items)
White Voodoo
(15 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Windows 10 LTSB
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #3 of 14 (permalink) Old 12-02-2019, 09:15 AM
Bratislav's Avatar
Rep: 3 (Unique: 3)
- Min 2x 420 rad's.
- Average 360 ​​rad per component(3x 360) for a good delta T and fans at 800-1300 RPM range.
- Or a combination of different sizes, depending on the space you have(420+280+240 for example).
Bratislav is offline
post #4 of 14 (permalink) Old 12-02-2019, 11:01 PM - Thread Starter
madno's Avatar
Rep: 0
Thanks you.
madno is offline
post #5 of 14 (permalink) Old 12-02-2019, 11:52 PM
The IT guy...
OrionBG's Avatar
Rep: 9 (Unique: 7)
What it is about:
New build for content creation is in the works...
Currently I'm running a Treadripper 1590X + one 2080Ti.
I have 3x 360 radiators and 9 fans. The CPU goes to 75C - 85C under load with an OC to 4GHz all core. The GPU goes up to 45C - 50C
Now imagine how much more heat will a 24 core chip plus two 2080Ti cards will be spewing...
The new system I'll be building soon will have those same 3960X CPU and two 2080Ti GPUs, I'll be making two separate loops, one for the CPU and another for the GPUs. The CPU loop is going to be 2x 480 rads and the GPU loop is going to be 2x 480 + 1x 360 rads. All radiators are 60mm thick.
A single 360 radiator with 3 fans (in push configuration) running at about 1300rpm can dissapate about 270w to 330w of heat.
Treadripper 3960x is rated at 280W and most stock 2080Ti's are also arround 280W so arround 840w - 850w for those 3 components only and at stock. (those are overly rounded numbers and may differ depending on the current scenario. And also I know that not all of the electrical power that is consumed by those parts is transferred into heat, but still it's close) To be on the safe side, you will need at least 3x 360mm radiators (and good ones at that) to handle those three componenets loaded at the same time.
Orion-TR4
(12 items)
Threadripper 1950x
Asrock x399 Taichi
EVGA 1080 Ti FE
G.Skill TridentZ RGB
Samsung PM961 Nvme SSD
Samsung 850 EVO SATA SSD
Intel 5400S SATA SSD
Corsair HX1000i
Custom Loop mostly EKWB
Lian-Li PC-O11 WGX ROG Edition
Operating System
Windows 10 Pro
Audio
Sound Blaster Z
OrionBG is offline
post #6 of 14 (permalink) Old 12-03-2019, 02:59 AM
Invalid Media
J7SC's Avatar
Rep: 40 (Unique: 20)
OP: Sounds like you're planning a great build !
The more rad space, the better, given the parameters of your build project, and the fact that with more rad space, each fan can be set to a quieter mode. The thickness of the rads also plays a role
Per sig-rig link, I'm running a TR2 2950X with an all-core oc of 4.3 GHz and 2x factory water cooled Aorus 2080 Ti, each of which has an observed max power draw of 380W (so 760W total heat energy just for the GPUs ). I am using separate loops for CPU and GPU.
The CPU loop has dual pumps and dual XSPC RX360x60 v3 rads, along with a Heatkiller IV TR CPU block. The GPU loop also has dual pumps, but uses triple XSPC RX360x60 v3 rads. As you're planning to run the system under what sounds like fairly heavy load 24hrs, it is also not just a question of controlling peak temps, but also heat soak > plenty of rads with big surface area and volume
J7SC is offline
post #7 of 14 (permalink) Old 12-03-2019, 08:02 AM
StAndrew's Avatar
Rep: 13 (Unique: 9)
The short answer is "all of them". As many as your case and wallet can support.
My advice:
-480mm on front -Intake
-480mm on the side - Intake
-420 on top - Exhaust (140mm fans)
-As many bottom fans as you can fit as intake
-Rear 140mm fan as intake? (get a dust filter). Maybe exhaust, I would play with that one to see if there is a difference. I'll ultimately depend on the case static pressure.
For maximum radiator efficiency, run the heat load to your exhaust radiators prior to your front intake radiators.
Hardware Labs Nemesis GTR and Hardware Labs Nemesis GTS recommended. GTS is more for air flow and GTR is more for performance. Maybe two GTR's for intake and a GTS on the top as exhaust to keep case pressure ideal.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #8 of 14 (permalink) Old 12-04-2019, 11:03 PM - Thread Starter
madno's Avatar
Rep: 0
Many thanks. Seems so my initial plan of two 360 rads (1 x 60 mm, 1 x 36 mm) might be not so good. Will start with them once the components and case arrived and then see how much space is left. According the case's specs it should swallow plenty of rads but need to see it hands on first to get a feeling.
Damn, feeing so noob at the moment :-)
madno is offline
post #9 of 14 (permalink) Old 12-05-2019, 04:42 AM
Hardware Princess
Hydroplane's Avatar
2x360 will work but the fans will need to be at higher RPM (guessing 1500-2000)
CHILLER DESTRUCTION
Z390 Station
(11 items)
White Voodoo
(15 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Windows 10 LTSB
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #10 of 14 (permalink) Old 12-05-2019, 03:38 PM
Ironsmack's Avatar
Rep: 55 (Unique: 51)
You don't need a 60mm rad. Its only useful if you can't fit anymore rads in the case and but you need more surface area.
If you can fit 3 slimmer rads, that would be more ideal. Looking at that rad - 2 x 360 slim + 1 480 slim rads can fit. Or 2 x 480 + 360 slim rad (but it looks more challenging).
But you're right - wait till the case is there and you're able to visualize the space you need + what rads can fit by measuring.
Gaming Rig: (2) Swiffy MCP35x, UT60 + GTX 480 rad, (1) 360 HWL GTX, (1) 240 HWL GTS, HK IV 2920X @ 4.2 GHz, AsRock X399 Fatality, (2) NVidia 1080 w/ HK IV blocks, Gammix S11 Pro 1TB, Crucial MX500 1TB, 2TB Samsung F4, (4) 3 TB & (2) 5 TB Toshiba HD, CL STH10, EVGA 1300 PSU, Win 10 Pro
HTPC Rig: HK IV Stock 3700x, Asus Strix B450, D5 vario w/ EK top, 480 UT60, 240 HWL GTX, Asus 290 w/ XSPC WB 1000/1300, Crucial P1 500 GB, 12TB Ironwolf, 6TB & 8TB HGST, Enthoo Primo, EVGA G2 750, Win 10 Pro
Ironsmack is offline
