Is distribution plate bad for watercooling? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 12-03-2019, 02:54 AM - Thread Starter
sblantipodi's Avatar
Rep: 29 (Unique: 27)
As title.
I want to buy a Lian Li PC O11 Dynamic with a top rad and a bottom one.
I want to use a distribution plate.
Is it difficult with distro plate to fullfill the top rad? Will I be able to remove air from the top rad even using a distro plate as tank?
Thanks
sblantipodi is offline
post #2 of 8 (permalink) Old 12-03-2019, 11:42 AM
StAndrew's Avatar
Rep: 13 (Unique: 9)
I've heard that reservoirs are easier for bleeding and getting air bubbles out of your loop. I think Jayztwocents latest build youtube (or one of the latest) he was planning on a distro plate but opted out for a more traditional reservoir because of some complications. I wasn't really listening and missed the issue he had.
I think distro plates have their niche for a: looks and b: on occasion, cutting down on complexity of your loop (especially with hard lines).
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #3 of 8 (permalink) Old 12-03-2019, 11:44 AM
skupples's Avatar
Rep: 580 (Unique: 324)
distros hold way less volume, so that makes perfect sense.
aside from that, there really shouldn't be any issues, assuming you get the correct plate for your board format/case, however that works.
I keep using the same parts till they break, so it'll be another 100 years before I replace my existing glass reservoirs
skupples is offline
post #4 of 8 (permalink) Old 12-03-2019, 11:48 AM
Overclocker in training
ThrashZone's Avatar
Rep: 90 (Unique: 65)
Hi,
Does not support d5 pumps does it if not no way Jose.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #5 of 8 (permalink) Old 12-03-2019, 11:50 AM
skupples's Avatar
i've seen folks using the no-pump models, n attaching the D5 at the bottom, kinda like a standard reservoir without pump top mating.
skupples is offline
post #6 of 8 (permalink) Old 12-03-2019, 11:58 AM
StAndrew's Avatar
Rep: 13 (Unique: 9)
IIRC, there is nowhere for air to go with a distribution plate so a reservoir is recommended. Either you have to manually bleed all the air out of the loop yourself (you will need a bleed port either on the top radiator or somewhere that can be located at the top when your case is properly oriented. Or run a separate reservoir. Or don't use a distribution plate.
StAndrew is offline
post #7 of 8 (permalink) Old 12-03-2019, 12:06 PM
Tech Enthusiast
deafboy's Avatar
Rep: 441 (Unique: 336)
Yes, you can use a D5 with a Distro-plate
Yes, they are harder to fill bleed
Yes, You can get the air out just like any other system, it just takes a bit more movement and a bit more work
No, there is nothing wrong with them once you get it configured right
IN HONOR OF SYRILLIAN, R.I.P.
ASUS ROG Rampage IV Black Owners Club || PNW Overclockers Club
BMW TJ07 Build Log -- The Ultimate Cooling Machine
2 year anniversary In Remembrance of a Great - RIP Syrillian
Overkill FreeNAS
(10 items)
Intel Xeon E5-1680 V2
Asus Rampage IV Black Edition
nVidia Titan XP (2100/5200)
Corsair Dominator Platinum 32GB
Intel 750 400GB
Intel 750 1.2TB
Samsung PM981 1TB
Corsair AX1200i
2x Swiftech D5 w/ EK Dual Pump Top
XSPC EX480, EX360 & 2x Phobya 1080
EK Supremacy EVO CPU Block
EK Advanced 250mL Res
Lamptron FC-5V2
EK Rampage IV BE Water Block
Copper Tubing w/ push fittings
EK-FC Titan XP Copper/Acetal
Silverstone TJ07, heavily modified
Operating System
Windows 10 Pro
Asus PG297Q
Keyboard
Leopold Otaku
Mouse
Corsair M65
Mouse
Corsair MM600
Audio
Sennheiser HD595 / HD428 / HD280
Audio
Corsair SP2500
E5-2670v1
E5-2670v1
Supermicro X9DRL-iF
12x HGST 4TB CoolSpin
6x WD Red 8TB
Corsair AX750
2x Noctua nh-u9dxi4
3x Scythe AP-30
Norco 4224
Operating System
FreeNAS
deafboy is offline
post #8 of 8 (permalink) Old 12-03-2019, 12:11 PM
ThrashZone's Avatar
Hi,
Okay that model I have not seen.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
