First Time n00b Setup Thoughts - Page 4 - Overclock.net - An Overclocking Community
post #31 of 38 (permalink) Old 01-13-2020, 04:32 PM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by Mordorr View Post
VP755 pump?
Yes, it is a VPP755. It seems to be working well, and quietly.
About the pump control: There is no "fan curve" for the CPU_OPT PWM header that the pump is plugged into. But when I run "CPU burner" in MSI Kombustor the pump RPM goes up from 3800 to 4400, then back to 3800 when I stop it. So, the CPU_OPT header is using the CPU_FAN header's fan curve to control the pump.
This is my first experience with water cooling. Idle core temp is around 28-32C, MSI Kombustor CPU burner 68-74C, World of Warplanes around 46C.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Sapphire Rx 590 Nitro+ 8Gb SE
Kingston Fury HyperX
Corsair CS750M
Noctua NH-D9L
Lian Li PC-011 Dynamic
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
Logitech G402 Hyperion Fury
bkrownd is offline
post #32 of 38 (permalink) Old 01-14-2020, 06:21 AM
Rep: 0
I did refer to her because of this, since last year i did to have one...
https://www.overclock.net/forum/61-w...-problems.html
Mordorr is offline
post #33 of 38 (permalink) Old 01-14-2020, 07:43 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 417 (Unique: 280)
VP755 pump?
I would start testing and finding the point at which performance gets affected by lower pump speeds. You could probably run that pump at 2000 rpm, lose noise, gain pump life and not have any increase in temps.
ciarlatano is offline
post #34 of 38 (permalink) Old 01-14-2020, 08:13 AM
Bad5ector's Avatar
Rep: 10 (Unique: 7)
I have to ask, why external setup? That case is pretty much designed for custom loops, so it can't be space can it? I mean, to each their own, just curious.
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is offline
post #35 of 38 (permalink) Old 01-14-2020, 12:46 PM - Thread Starter
Rep: 1 (Unique: 1)
It's already really quiet. The fans are running around 800 RPM, and since the curves are linked I'd have to see how low the fan speed would be to get the next steps down in pump speed.
I wanted the freshest possible air into the radiator with the least airflow obstruction, and don't want to blow warm radiator air into the case. It also keeps the inside of my case from getting crowded, and by removing the quick-connects I can add things like a temperature/flow meter without disconnecting coolant tubes inside the case. I also thought it would be easier to fill and drain this way. One problem with the 011 Dynamic case is that the slotted vent areas are very restrictive, with more metal blockage than slot opening.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
post #36 of 38 (permalink) Old 01-14-2020, 12:52 PM - Thread Starter
Rep: 1 (Unique: 1)
People were telling me that v.3 should be fine, but we shall see.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
post #37 of 38 (permalink) Old 01-14-2020, 03:47 PM
ciarlatano's Avatar
I was referring to the pump, not the fans.
post #38 of 38 (permalink) Old 01-14-2020, 04:06 PM - Thread Starter
Rep: 1 (Unique: 1)
Fans and pump in the Eisbaer are both controlled by the same "fan curve". They are both quiet, even at full speed.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
