First Time n00b Setup Thoughts - Overclock.net - An Overclocking Community
post #1 of 39 (permalink) Old 12-03-2019, 03:32 PM - Thread Starter
Rep: 2 (Unique: 2)
I'm waiting for my last few parts to arrive before I can start installing the watercooling. My initial configuration will be an Eisbaer Extreme Solo 280 radiator/pump/reservoir external unit and an EK-Velocity CPU water block. This is not the pre-filled Eisbaer AIO, but just the radiator/pump/reservoir unit which ships dry. I have 13/10 flex tubing with Alphacool quick-connects bulkhead-mounted on the back of the case between the outside/radiator and inside/CPU block. The Eisbaer radiator unit will sit vertical on top of the case directly above the CPU. (like the creepy monolith in 2001 haha)
First I need to flush the Eisbaer radiator, but since the radiator/pump/reservoir is a single unit I'll probably need to run the pump to flush it, instead of manually filling/shaking/draining. I need to look at whether I can use a bench power supply to power the motor 12V molex connection for the flushing, with the PWM cable unconnected. Will VPP755 just run at max speed if there's no PWM connection? I was thinking of perhaps hooking the Eisbaer unit up to a big bucket of distilled water using bulkhead connectors on the wall of the bucket, and letting flushed debris settle to the bottom of the bucket as it cycles.
When flushing is done I'll go to putting things together and filling. Inside the Eisbaer housing the pump/reservoir is mounted below the radiator. The Eisbaer Extreme uses the Alphacool NexXxos ST30 280 radiator, so I should be able to pop the top cover off of the Eisbaer shell and access the end port of the radiator to let out air at the very top of the water column, but only when the pump isn't running. I was planning to fill by gravity and test-run the loop before mounting the CPU block so I can wiggle the block around a bit and try to tap out air bubbles.
Having never done this before my plan makes sense in my head, but....we shall see.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Sapphire Rx 590 Nitro+ 8Gb SE
Kingston Fury HyperX
Corsair CS750M
Noctua NH-D9L
Lian Li PC-011 Dynamic
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
Logitech G402 Hyperion Fury
bkrownd is offline
post #2 of 39 (permalink) Old 12-04-2019, 01:32 PM - Thread Starter
Rep: 2 (Unique: 2)
After several days of trying I finally got registered on the Alphacool forum so I could ask about the large springs inside the quick-connects. They say they're "stainless steel", but haven't yet specified an alloy. Not quite what I was expecting, but my boating friend suggests that's probably OK to mix with copper and brass fittings.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
post #3 of 39 (permalink) Old 12-04-2019, 01:49 PM
u broke 666 rep :(
skupples's Avatar
Rep: 676 (Unique: 359)
the mixed metals shouldn't be an issue with quality coolant (mayhems x1)
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #4 of 39 (permalink) Old 12-06-2019, 07:21 PM - Thread Starter
Rep: 2 (Unique: 2)
It looks like the mailman broke down. My packages that were supposed to be delivered today have been in Honolulu since Wednesday and have made no further progress. :/
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
post #5 of 39 (permalink) Old 12-06-2019, 07:45 PM
Shawnb99's Avatar
Rep: 50 (Unique: 32)
waiting is just the worst.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #6 of 39 (permalink) Old 12-07-2019, 10:56 PM - Thread Starter
Rep: 2 (Unique: 2)
By the time I get to work on my parts it's going to be about a month since I placed the first order.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
post #7 of 39 (permalink) Old 12-09-2019, 05:33 PM
Turtle Rig's Avatar
Rep: 7 (Unique: 7)
What parts you need ?
INTEL 10980XE @ NO STOCK
GIGABYTE X299X AORUS MASTER
GIGABYTE WF RTX 2080
CORSAIR DOMINATOR PLATINUM RGB @ 64GB 3200 CL16 QUAD CHANNEL B-DIE
CORSAIR MP510 960GB M.2 GEN 3 SAMSUNG 950 PRO M.2 500GB 850 PRO 500GB CRUCIAL M4 500GB LaCie EXTERNAL 2TB PORSCHE DESIGN & 500GB eSATA
CORSAIR AX1600i TITANIUM @ CORSAIR 330r BLACKOUT EDITION CASE
CORSAIR H115i PRO RGB @ NOCTUA NF-14's INTAKE NF-14 EXHAUST NF-P12
AOC 40" CURVED 4k LG 55" C9 OLED G-SYNC 120HZ
Keyboard
LOGITECH 915 LINEAR WIRELESS
Mouse
LOGITECH G PRO WIRELESS LIZZARD GRIP 3M TAPE
Mousepad
STEELSERIES SMALL
Audio
LOGITECH G935 WIRELESS SCARLETT 2i2 AUDIO INTERFACE KRK ROKITS 10" & SENNHEISER HD 650 & 4.5.0 BTNC SL GRAND 88 CAKEWALK BY BANDLAB
Turtle Rig is offline
post #8 of 39 (permalink) Old 12-10-2019, 01:01 AM - Thread Starter
Rep: 2 (Unique: 2)
I needed the bulkhead fittings, both for the flushing idea and for the final setup. The postman finally delivered all my Black Friday goodies today, and now I just have to count he days until the weekend.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
post #9 of 39 (permalink) Old 12-10-2019, 07:26 AM
GraphicsWhore's Avatar
Rep: 14 (Unique: 12)
I don't know anything about Eisbaer but quality radiators today really don't need flushing. You can do it for a peace of mind I guess but shouldn't be necessary.
7700k
ASUS Maximus IX Code
EVGA 2080Ti XC Gaming
Corsair Vengeance LED 16GB @ 3200
Samsung 960 EVO
Samsung 840 Pro
Samsung 850 EVO
Samsung 850 EVO
Crucial P1
Corsair RM750i
Hardware Labs Black Ice SR2 360MP
EK-D5 G2 Pump
Cuplex KRYOS Next VISION CPU waterblock
EK-Vector RTX RGB waterblock + backplate
Monsoon MMRS 250mm custom reservoir
Monsoon Hardline PETG Tubing 1/2", 5/8"
Thermaltake Core P5
Operating System
Windows 10 Pro
Alienware AW3418DW
Mouse
Logitech G900
Audio
BOSE QC35
Audio
Creative Sound Blaster Z PCI-E
Other
HTC VIVE Pro
GraphicsWhore is offline
post #10 of 39 (permalink) Old 12-10-2019, 07:47 AM
u broke 666 rep :(
skupples's Avatar
its radiators that need flushing, not reservoirs.
skupples is offline
