More flow? - Overclock.net - An Overclocking Community
More flow?
post #1 of 34 (permalink) Old 12-07-2019, 08:33 AM - Thread Starter
RichKnecht's Avatar
Rep: 6 (Unique: 6)
More flow?
I recently dropped my 7900X OC from a 24/7 4.7 to 4.6. Mainly just to lower temps from the 70s to the 60s. I know a 7900X OC'ed to 4.7 (direct die mounted) in the mid 70s isn't bad, but it made me wonder if I have enough flow in my loop as I think temps should be much lower than what I am seeing. My loop consists of 2 EK PE360s, an EK XE360. EK Supremacy CPU block and an EK X-Res/D5 (full speed) combo. All radiators have 3 ML120s on them in a push configuration. It's all soft tube with large radius bends and 6 elbows, so I am concerned that head pressure is really affecting flow. I'm thinking of switching from my present PC 011 air to a new Dynamic XL just to get more "breathing room" for my components as it was pretty challenging to get everything into the 011 air. If I make the switch, I'll have room for another D5, but is it worth it?
On a separate note, I may yank the 7900X and put a 10980XE in there if they prove to be decent overclockers.
Editing PC
(11 items)
7900X
Asus Rampage VI Extreme Omega
ASUS RTX 2060 Dual
Corsair vengence RGB 3466
Samsung 960 EVO 256GB
EVGA 1300W SuperNova Gold
EKWB PE360x2, XE360, Supremacy EVO RGB, Xres140 D5 RGB
Liam Li PC011 Air
Operating System
Windows 10 Pro 64bit
Dell U2412
BenQ 2700PT
RichKnecht is offline
post #2 of 34 (permalink) Old 12-07-2019, 08:51 AM
Overclocker in training
ThrashZone's Avatar
Rep: 119 (Unique: 79)
Hi,
Probably just need another water block
Heatkiller iv pro or velocity
EVO is old.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 34 (permalink) Old 12-07-2019, 09:03 AM - Thread Starter
RichKnecht's Avatar
Rep: 6 (Unique: 6)
Quote: Originally Posted by ThrashZone View Post
Hi,
EVO is old.
I thought about that. I took mine apart and cleaned it although it looked perfect. From what I have read the Heatkiller IV is a great performing block and it looks great too. Performance between all 3 blocks seems to be within a couple degrees +/-. If I go the new case route, I may give hard tubing a try. I appreciate the input as you have helped me in the past with positive results.
Editing PC
(11 items)
7900X
ASUS RTX 2060 Dual
Liam Li PC011 Air
Operating System
Dell U2412
BenQ 2700PT
post #4 of 34 (permalink) Old 12-07-2019, 09:14 AM
Turtle Rig's Avatar
Rep: 4 (Unique: 4)
The 10980XE has so much headroom for OCing unlike AMD which comes clocked to max pretty much. AMD OCing is dumb you put high voltage just to get 4.3Ghz and it already comes with 3.9 ahd 4.1Ghz and 4.2Ghz on high workloads. The Intel chip stock at 3Ghz can go all way up to all cores 4.9 to 5.0Ghz ,,, You just have to inject a proper vcore voltage so it is stable.
INTEL 10980XE @ NO STOCK
GIGABYTE X299X AORUS MASTER
GIGABYTE WF RTX 2080
CORSAIR DOMINATOR PLATINUM RGB @ 64GB 3200 CL16 QUAD CHANNEL B-DIE
CORSAIR MP510 960GB M.2 GEN 3 SAMSUNG 950 PRO M.2 500GB 850 PRO 500GB CRUCIAL M4 500GB LaCie EXTERNAL 2TB PORSCHE DESIGN & 500GB eSATA
CORSAIR AX1600i TITANIUM @ CORSAIR 330r BLACKOUT EDITION CASE
CORSAIR H115i PRO RGB @ NOCTUA NF-14's INTAKE NF-14 EXHAUST NF-P12
AOC 40" CURVED 4k LG 55" C9 OLED G-SYNC 120HZ
Keyboard
LOGITECH 915 LINEAR WIRELESS
Mouse
LOGITECH G PRO WIRELESS
Mousepad
STEELSERIES SMALL
Audio
LOGITECH G935 WIRELESS SCARLETT 2i2 AUDIO INTERFACE KRK ROKITS 10" & SENNHEISER HD 650 & 4.5.0 BTNC SL GRAND 88 Sonar Producer
Turtle Rig is offline
post #5 of 34 (permalink) Old 12-07-2019, 09:18 AM
skupples's Avatar
Rep: 630 (Unique: 342)
and lots of cooling, IE: not an AIO or air blower.
skupples is offline
post #6 of 34 (permalink) Old 12-07-2019, 09:55 AM
Turtle Rig's Avatar
Rep: 4 (Unique: 4)
Oh ya tell me about it. Need to stick the case into a small refigerator or will things get watery and mess up system ?
Keyboard
Mouse
Mousepad
STEELSERIES SMALL
Audio
post #7 of 34 (permalink) Old 12-07-2019, 10:15 AM
Bratislav's Avatar
Rep: 3 (Unique: 3)
EVO is old.
Nonsense...
Bratislav is offline
post #8 of 34 (permalink) Old 12-07-2019, 10:18 AM - Thread Starter
RichKnecht's Avatar
Rep: 6 (Unique: 6)
OK, seems that we got a little off topic here I'm thinking that swapping cases and adding a second D5 pump can't hurt. Maybe even switch to push/pull on the XE360.
Editing PC
(11 items)
7900X
ASUS RTX 2060 Dual
Liam Li PC011 Air
Operating System
Dell U2412
BenQ 2700PT
post #9 of 34 (permalink) Old 12-07-2019, 10:21 AM
skupples's Avatar
I uh.. no. Enjoy setting yourself up for failure. OCN will do nothing but profit from it thanks to all the clicks you'll generate via people saying "told ya that h100 wasn't gonna be big enough for your 10XE"
it's basic math. devices are designed to dissipate certain amounts of heat. IE: "effective up to 250w"
as to the fridge, not enough power. You'd have better luck just having a stand alone AC in your office, so your rads get nice cool air.
adding a second pump is a great move, though remember gains from flow taper off after 1GPM ~120lph.
my dual mcp35x2 is pushing 10 years of age, n they're only $200
skupples is offline
post #10 of 34 (permalink) Old 12-07-2019, 10:24 AM
skupples's Avatar
and yes, 90s directly off of the pump drastically reduce flow potential. 2nd pump will nip that in the bud, but so will replacing some hard 90s for bitpower's snake 90s.
skupples is offline
