Raystorm PRO with no instructions - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 12-07-2019, 05:49 PM - Thread Starter
Emmanuel's Avatar
Rep: 387 (Unique: 318)
Hi everyone,
Just got back from Microcenter with my new Aorus Master Z390!
I also received from Amazon an XSPC Raystorm Pro. The only problem is that for whatever reason, no instructions were included.
I found the manual online:
https://static1.squarespace.com/stat...-pro-intel.pdf
In step 4, it says to screw the posts directly against the motherboard without using any of the included nylon washers. My motherboard has a bunch of traces right next to most H/S holes, there's no way in hell I'm rubbing them with metal.
I haven't installed the block yet but I did screw in the posts with nylon washers in between. I attached a picture, let me know your thoughts. It does elevate the posts by 1mm approximately.
Thanks
2nd Amendment supporter
Back to Gigabyte
(14 items)
9900KS - 5.0GHz stock
Aorus Z390 Master - F11c modded BIOS
Aorus GTX1080ti - 2113MHz
G.Skill Royal DDR4 32GB (4x8GB) - 4133MHz 16-16-16-36 1.50v
Samsung Evo Plus 2TB
Samsung Evo 840 1TB
Evga Supernova P2 1200W
2x independent (CPU & GPU) custom loops
Phanteks Enthoo Pro M
Philips BDM4065UC 40" 4K
Keyboard
Logitech G19
Mouse
Logitech G900
Mousepad
Conkor
Audio
Asus Xonar STX II
Emmanuel is offline
post #2 of 5 (permalink) Old 12-11-2019, 08:27 AM
s002wjh's Avatar
Rep: 0
I have raystorm pro for AM4, I don't recall I put nylon washer on those 4 holes, ill double check. but its good to be safe, nylon washer doesn't hurt anything, so should be fine.
s002wjh is offline
post #3 of 5 (permalink) Old 12-11-2019, 08:29 AM
skupples's Avatar
Rep: 627 (Unique: 342)
the nylon washers are SOP for pegs on most blocks. They're to prevent any sort of conduction/shorting issues.
skupples is offline
post #4 of 5 (permalink) Old 12-18-2019, 06:23 PM - Thread Starter
Emmanuel's Avatar
Thanks for the replies. I built my PC with the washers placed like in the picture, no issues at all and at least I'm not scratching the board. Temps are great with a pretty tight spread across all cores.
Back to Gigabyte
(14 items)
Samsung Evo 840 1TB
Keyboard
Logitech G19
Mouse
Logitech G900
Mousepad
Conkor
Audio
Asus Xonar STX II
Emmanuel is offline
post #5 of 5 (permalink) Old 12-18-2019, 07:07 PM
skupples's Avatar
scratching and warping boards are greatly over stated.
I used to remove stock back plates & strap dynatron 1u CPU coolers on instead, using nothing but washers, nuts, & bolts. never scratched, cracked, arced, or warped a thing.
glad you got it sorted.
skupples is offline
