Quality pass through temp sensor? - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 12-08-2019, 08:15 AM - Thread Starter
Rep: 4 (Unique: 2)
Sorry if this has been asked a dozen times. I've been doing quite a bit of searching and coming up with very little considering the amount of info it's pulling.
Anyway, I'm looking for a good pass through sensor for the coolant loop. I'd like to run my rad fans based on the coolant temp vs. cpu temp. Here's the machine I've been building...
i9-9900k
z390-E board
64m ddr4 3200
dual MSI 1070 GPU's
lian li 011 dynamic case
Appreciate the help, if there's a link to this exact thing feel free to post it instead of wasting your time repeating. It's just the few I've found at any of the online mod stores don't seem to rate very high in reviews. I'd rather not put the system together and require repeated draining because something so simple failed.
SP
Soulpatch is offline
post #2 of 16 (permalink) Old 12-08-2019, 08:18 AM
skupples's Avatar
Rep: 629 (Unique: 342)
Not sure who builds them into a pass (female/female adapter that goes thru floors/ceilings/walls)
But there are plenty of plug/cap sensors from the usual suspects that’ll do the exact same thing. They’d screw into any available radiator port.
skupples is offline
post #3 of 16 (permalink) Old 12-08-2019, 08:32 AM
RichKnecht's Avatar
Rep: 6 (Unique: 6)
i9-9900k
z390-E board
64m ddr4 3200
dual MSI 1070 GPU's
SP
Google is your friend
https://www.microcenter.com/product/...shining-silver
I just put that link there because I am 10 minutes from MC, but Amazon sells them too. They work great.
Editing PC
(11 items)
7900X
Asus Rampage VI Extreme Omega
ASUS RTX 2060 Dual
Corsair vengence RGB 3466
Samsung 960 EVO 256GB
EVGA 1300W SuperNova Gold
EKWB PE360x2, XE360, Supremacy EVO RGB, Xres140 D5 RGB
Liam Li PC011 Air
Operating System
Windows 10 Pro 64bit
Dell U2412
BenQ 2700PT
RichKnecht is offline
post #4 of 16 (permalink) Old 12-08-2019, 08:47 AM - Thread Starter
Rep: 4 (Unique: 2)
Thanks, have been googling. Problem is I'm finding very contradicting information from site to site. Quality being the top of the list since I'd rather not have it fail or leak anymore than the next guy. Was also looking for an in-line just for ease of use. The only open ports I have are in the bitspower front distro plate. Ultimately the temp reading doesn't have to be at the radiators, since the system is small enough and flows enough that the delta-t will not change from one point to another. So I could ultimately plug a solid thermo-couple into the distro plate. I'll look at the bitspower and read some reviews on quality. I used to be a mechanical engineer and tend to over-think and especially don't like doing things more than once. Oddly enough i used to do mods like this back in the 90's, but we used small electric pumps and had to machine heads/cpu blocks ourselves. Parker stainless fittings and 3/8" stainless tubes. Almost always had to include some kind of site-glass to make sure no fungus was growing lol But that was back in the cold-cathode lighting days... LOL
post #5 of 16 (permalink) Old 12-08-2019, 09:12 AM
skupples's Avatar
that's a plug, not a pass thru.
anything inline is gonna be bigger, and do more. like a MIPS device from aquacomputer,.
if quality is a concern, then I'd go see if they make what you're looking for.
skupples is offline
post #6 of 16 (permalink) Old 12-08-2019, 09:25 AM - Thread Starter
Rep: 4 (Unique: 2)
Appreciate the help. Think I'll go with the plug and put it into the distro panel. They make the short ones just for that. Like i said, the delta-t from the radiator to the distribution panel would be minimal in such a short run. Doing a plug type should be much less prone to leakage (at least from the cables coming out) and the readings should be just as accurate. This is my first build in quite awhile and first coolant build in over 20+ years (back then we used a blended version of glycol/water lol). Things have definitely come a VERY long ways since then. Even our thermocouples. We used the real deal (I did prototype power train development) and we had a really nice dyno lab. So the tc's more than we needed, but never failed or leaked lol Like i said, there's a huge amount of chinese made that tends to be much lower in quality. Last thing anybody needs is a case/floor full of coolant.
post #7 of 16 (permalink) Old 12-08-2019, 09:48 AM
RichKnecht's Avatar
Rep: 6 (Unique: 6)
The plug works just fine. I have mine on a "T" fitting, so the fluid passes by it. It has never leaked and it's been on there for ~2 years.
Editing PC
(11 items)
7900X
ASUS RTX 2060 Dual
Liam Li PC011 Air
Operating System
Dell U2412
BenQ 2700PT
post #8 of 16 (permalink) Old 12-08-2019, 10:20 AM
Shawnb99's Avatar
Rep: 44 (Unique: 30)
The aquacompter inline sensors work perfectly for me.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #9 of 16 (permalink) Old 12-08-2019, 10:43 AM
Rep: 12 (Unique: 11)
I just ordered one of these going to give it a try.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Open Air Build
i9
ASUS ROG Strix Z390-H Gaming
MSI GEFORCE GTX1080 TI GAMING X 11G
Corsair Vengeance LPX DDR4 DRAM 3000MHz
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
All PrimoChill parts (Rad 360, Pumps D5, Fittings, and Acrylic Tubing), Byskey CPU&GPU Blocks
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Thermaltake Commander F6 Fan Controller
Other
DIY Sleeved Cables
smilinjohn is offline
post #10 of 16 (permalink) Old 12-08-2019, 10:50 AM
Just hangin' out
Arctucas's Avatar
Rep: 35 (Unique: 34)
I am using these: http://www.xs-pc.com/temperature-sen...r-black-chrome.
In no way should it be misconstrued that I do not disagree.
PC
(14 items)
9900K
eVGA Z390 DARK
eVGA RTX2080 FTW3 ULTRA
GSKILL F4-4500C19D-16GTZKKE
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
LIANG D5, XPSC DUAL BAY RESERVOIR, HEATKILLER IV PRO NICKEL, THERMOCHILL PA140.3, AEROCOOL 140MM SHARK FANS
THERMALTAKE XASER VI
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Z-5500
Arctucas is offline
