Tubes bioattack? - Overclock.net - An Overclocking Community
Tubes bioattack?
post #1 of 88 (permalink) Old 12-16-2019, 01:57 PM - Thread Starter
Rep: 0
Tubes bioattack?
Well, after one year using car G12 from Volkswagen + distillate water, i start noticing this on my tubes:
Sorry in photos aren`t ok, but basically my soft tubes have this white spots....some kind of fungus, i presume.
Already remove the liquid, put pure distillate water for clean, remove, more distillate water, and finally G12 + distillate water.
The system is: Heatkiller Nikel IV + D5 Water-cooling on Heatkiller reservatore and a old Inovatek Tube, + Ice Extreme 120mm radiator and on top Alphacool 360 radiator.
Lot of different metals.
Is this bio something, or quimical reaction?
How can i remove all, without change tubes? Coca-Cola?
Mordorr is offline
post #2 of 88 (permalink) Old 12-16-2019, 02:02 PM
LTSC Consiglieri
skupples's Avatar
Rep: 658 (Unique: 351)
looks like plasticizer.
does it come up easily when wiped?
no. please do not put coca cola into your computer. that's a terrible idea. IDK where that's coming from, as you aren't the first person to mention it as of recent. Seems like reddit troll bs.
either way - most likely plasticizer being leached from your tubes. The VW coolant should cover bio & corrosion just fine, but its likely accelerated the leaching of the plastic from your tubes.
I'd recommend looking up Mayhems biocide+ inhibitor+ they're an inexpensive and incredibly effective set of droppers. Even better, is his X1 clear.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #3 of 88 (permalink) Old 12-16-2019, 02:21 PM - Thread Starter
Rep: 0
Hi skupples
Thanks for fast reply. Coca cola come from old days...i mean about 12 years ago and i did it....for only about 1 hour.
Ontopic.
Didnt try to clean it. Yes been using this for years, and previos system tubes became all white and tuffer.
However, this looks like some organism. Also, i put old liquid on bottle of water and notice something inside fluctuating...like small tubes of something.
Sorry, english is not my native language...
Is this ok?:
https://www.mayhems.net/collections/.../x1-clear-5ltr
I do not want color liquids or exotic stuff...just some practical, serious stuff, to not worry for years, like before.
Thank you in advance!
Mordorr is offline
post #4 of 88 (permalink) Old 12-16-2019, 02:33 PM
LTSC Consiglieri
skupples's Avatar
that would be perfect.
clear, and long lasting.
unfortunately though, I'd highly recommend swapping your tubes, or at the very least flushing with pure water a few times.. not sure there's any stopping the leach once its started.
hopefully someone else can chime in, as I've not had many personal experiences with Plastic leaching.
skupples is offline
post #5 of 88 (permalink) Old 12-16-2019, 02:48 PM - Thread Starter
Rep: 0
My thoughts too.....looks like this tubes are done for good.....
The important is not having problems on pump and WB. Old Apogee GT and Inovatek Rev3, inside look like new as the dau i bought them.
Think gona stay like this a few months more, then buy those 5 liters + new tubes.
That 5L doesn't need more additives, correct? Just clean, and put inside system?
Thank you!
Mordorr is offline
post #6 of 88 (permalink) Old 12-16-2019, 03:09 PM
Black Sun Empire
Wuest3nFuchs's Avatar
Rep: 38 (Unique: 31)
5ltr mayhems x1 clear:
Before Using Mayhems X1 range
The system must be clean and have no chemicals of any kind left in the loop. There must be an absence of bleach, biocide and anti-corrosive inhibitors. We recommend you flush your system with Mayhems Blitz kit before use. Mayhems X1 has biocides and inhibitors included within the mixture.
Properties & Benefits
Can be used with all of Mayhems Dyes to make your own colours
Blended with non-toxic corrosion & scale inhibitors for protection of Copper, Brass, Steel, Nickel and Aluminium. Proven to ASTM D3306 and BS6580 standards
Very low oral toxicity, less than propylene glycol
Contains all the biocides you will need
-15c freezing point (dependant on mix ratio)
Generally Recognised as Safe (GRAS) by the US Food & Drug Administration as a food additive
Mobilizes to prevent scale or sludge filming
Boiling Point: up to 100° C (pressure dependent)
85% Bio-degradable within 30 Days
Bitter taste additives to prevent consumption
Can be stored for up to 3 years (in a cool dry environment)
I recommend epdm based tubing or norprene (not neopren).
I also read good commenta from ekwb zmt which is also epdm.
norprene
https://www.aquatuning.us/search?sSe...orprene%2B&p=1
zmt
https://www.aquatuning.us/search?sSearch=zmt&p=1
btw aquatuning maybe has a shop in your language, whats your Native language btw?
I also made a bad decision by chosing the wrong tube (masterkleer) which i wasnt aware of the plasticizer in it.
And hell yeah it ended that the clear tubing was getting milky over 2-3 months .Coolant used was distilled water only with 10-15ml phobya superzero (btw dont by that stuff ).
The ph would be nice to know from the coolant you had.
6.5 -7.5 is good to go (@skupples) right ?
Gesendet von meinem SM-G950F mit Tapatalk
Watercoolingbox
https://www.overclock.net/t/1352993/...oolingbox/0_20
V3g4n0
(18 items)
2700X
Asus ROG Crosshair Hero VII
Sapphire RX Vega56 Pulse
GSkill F4-3200C14D-16GFX
Crucial MX 500
Crucial MX 500
Optical Drive
Pioneer BDR S09 XLT
BeQuiet Straight Power
BeQuiet Silent Loop 240mm
BeQuiet DARK BASE PRO 900 Silver rev. 2
Operating System
Win 10 1803
AOC Agon AG241QX, 23.8"
Keyboard
Steelseries M750
Mouse
Steelseries Sensei 310
Mousepad
Steelseries DEX
Audio
Steelseries Arctis 5
Audio
Sound Blaster X-Fi titanium HD
Other
Tobii Eyetracer 4c
Ryzen 5 2400G
Asus TUF X470 PLUS GAMING
Crucial Ballistix Sport AT DIMM Kit 16GB Single Ranked BLS2K8G4D30CESTK
Samsung SM843 MZ7TD240HAFV-000DA
Crucial M4
be quiet! Straight Power 11 550W ATX 2.4 (BN281)
Ryzen 7 Wraith RGB
Fractal Design Define R6 Black
Operating System
Win 10 1803 / Server 2016 Standard
Samsung SyncMaster XL2370 LED, 23" (LS23EFPKFVEN)
Wuest3nFuchs is offline
post #7 of 88 (permalink) Old 12-16-2019, 03:36 PM - Thread Starter
Rep: 0
Hi.
I read the instructions too. No problem using 5 litters destillated water or morejust too clean and flux all system....
Yep i know the site. Most of my actually stuff come from there too. I would prefer trans lucid tube, even with transparent liquid....and of course i know tygon! Great stuff!
The tube i use i think is Alphacool not totally transparent. 10/13 i think.
Good question about PH of my liquid....but i don`t have one of those papers for that.
Also, my previous system: Eihm 1046 + radiator Big Momma, was always working the pump 24/24....maybe that fact, can prevent at some point this. Just a crazy thought here.
Thank you for all suggestions. Is up to me have the pain of remove all tubes, buy new ones and repeat all.
Greetings from Portugal.!
Mordorr is offline
post #8 of 88 (permalink) Old 12-16-2019, 03:59 PM
LTSC Consiglieri
skupples's Avatar
Greetings from Tampa Florida
wish they were all this easy
OP : what do?
gallery : oof, mayhems.
OP : ok! fixed
just don't be surprised when even tygon clouds up a little bit.
and agreed, I really like EK's norprene. Quite a bit more flexible than off the shelf norprene hose from the store, or even PPC.
skupples is offline
post #9 of 88 (permalink) Old 12-19-2019, 02:22 PM - Thread Starter
Rep: 0
Back here to the topic:
IS this tube ok?
https://shop.watercool.de/epages/Wat...Products/50272
Must be 10/13mm, because my actual fittings, one more month and will have time to clean liquids and change tubes....
Definitely i must give up transparent tube.......
Mordorr is offline
post #10 of 88 (permalink) Old 12-19-2019, 02:29 PM
LTSC Consiglieri
skupples's Avatar
looks like the stuff EK uses. Seems to work well, doesn't stain or leach.
skupples is offline
