2080Ti watercooled 72c load temps high - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 12-31-2019, 07:15 AM - Thread Starter
Rep: 2 (Unique: 2)
Hello Peeps,
Intel 5930K, Corsair AX1500i, Phanteks Luxe 2 case.
Cooling. 3x140mm Rad front, 2x 280 Rad roof. SC Protium res, EKWB dual serial D5 pumps.
GPU. MSI 2080 Ti Trio X with EKWB nickel Plexi waterblock.
CPU block is watercool heatkiller full copper block.
Previously my pump was a D5 Vario, under load GPU would hit 52c max.
Since installing the EKWB dual pumps, GPU temps hit 72c under load. I think the GPU contact with block needs to be redone or reseated. Anyone got any suggestions?
Sent from my SM-G975F using Tapatalk
bhoot is offline
post #2 of 22 (permalink) Old 12-31-2019, 07:18 AM
LTSC Consiglieri
skupples's Avatar
Rep: 651 (Unique: 349)
did CPU temps go up as well?
would be weird to be a block biff if you didn't remove mess with the block. Seems more likely your new dual d5 isn't running quick enough, or you plumbed something backwards.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #3 of 22 (permalink) Old 12-31-2019, 07:25 AM
The last VRM burner
Rep: 42 (Unique: 25)
Screw it together properly.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 22 (permalink) Old 12-31-2019, 07:32 AM - Thread Starter
Rep: 2 (Unique: 2)
CPU temps as same as before. No change. The GPU has gone up. Just realised. I did install a straight fitting without taking the GPU out of the case. I did not flex the GPU at all. Held it solid, had GPU support arm in place as well. I think the fitting being screwed it must of loosened or shifted the block. Not sure how that even happens. Once you install a block, it should not even flex a millimetre.
Guess will need to re seat the Plexi crap or get the acetal block and stick that on. First time using Plexi waterblock. Have heavy hands.
bhoot is offline
post #5 of 22 (permalink) Old 02-04-2020, 07:31 AM - Thread Starter
Rep: 2 (Unique: 2)
Update on this. Replaced the Nickel block with another ekwb in acetal. Wrong screws used first time. 6mm ones were used but need use the 4mm ones. I asked the guy installed the first *** 6mm, he said it makes no difference as the 6mm screws don't hit the end, meaning they screw in fully. It installed the block myself on acetal. 10c drop in temps to 53c under load with slow fan speeds. Also used thermal grizzly kryonaut TIM and thermal grizzly thermal pads everywhere. For TIM in applied/spread across the whole GPU surface did a thin X and little block in each section.
bhoot is offline
post #6 of 22 (permalink) Old 02-04-2020, 09:04 AM
martinhal's Avatar
Rep: 72 (Unique: 60)
Out of interest what are your ambient temps ? I have an EK block on the same GPU as you and can hit 60c in heavy gaming with a 30c ambient.
martinhal is offline
post #7 of 22 (permalink) Old 02-04-2020, 09:32 AM
Rep: 13 (Unique: 12)
There is usually a REALLY good reason some engineer says to use a particular screw size in a particular place. The guy you referred to in your post doesn't know what he's doing. Wouldn't surprise me if he thinks you don't need ALL of the standoffs to mount a MB...
Open Air Build
i9
ASUS ROG Strix Z390-H Gaming
MSI GEFORCE GTX1080 TI GAMING X 11G
Corsair Vengeance LPX DDR4 DRAM 3000MHz
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
All PrimoChill parts (Rad 360, Pumps D5, Fittings, and Acrylic Tubing), Byskey CPU&GPU Blocks
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Thermaltake Commander F6 Fan Controller
Other
DIY Sleeved Cables
smilinjohn is offline
post #8 of 22 (permalink) Old 02-04-2020, 09:41 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1267 (Unique: 689)
but you don't.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #9 of 22 (permalink) Old 02-04-2020, 10:16 AM
LTSC Consiglieri
skupples's Avatar
need is subjective
mostly wrong, but not completely. there are a few places you can get away with the 6mm screw, LIKE WHEN INSTALLING A BACKPLATE, since that's what they're intended for.
skupples is offline
post #10 of 22 (permalink) Old 02-04-2020, 01:40 PM
Quote: Originally Posted by The Pook View Post
but you don't.
Then why do they have them?
Quote: Originally Posted by skupples View Post
need is subjective
True you can get away with it, but there's a reason for them
Open Air Build
i9
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Other
DIY Sleeved Cables
