Best radiator fan? - Page 2 - Overclock.net - An Overclocking Community
Best radiator fan?
post #11 of 50 (permalink) Old 01-11-2020, 03:26 PM
apw63's Avatar
Rep: 65 (Unique: 56)
They are both high quality fans
https://www.techpowerup.com/review/n...nf-a12x25-pwm/
https://proclockers.com/reviews/cool...2-p-fan-review
Have only used the noise blockers see what the reviews say. I can only speak to my experience with them. I’ve never had a issue. Noise level is subjective. My main gaming/encoding water cooled computer is in our media room. I don’t have to run the fans at max. When the fans spin up to 80% I still hear the isolated d5s over them. This is when watching tv/movies. When my computer is at idle the case fans stop and the rad fans spin around 400.
My System
ASUS ROG Swift PG278Q Owner's club
Asus Maximus XI Formula, 8700K, Corsair Dominator Platinum ROC 3200 16GbB, Asus ROC STRIX 1080 Ti OC version.
apw63 is offline
post #12 of 50 (permalink) Old 01-12-2020, 08:19 AM
Rep: 39 (Unique: 33)
I recommend the Be Quiet! SW3 fans. Have a bunch of them on my radiators, no complaints with them.
Pick whichever speed & 3/4pin you want for your preference.
I just went for the high-speed ones as you can run them silent if you want anyway and have 2000+ rpm when you want. Gives you the best flexibility.
Gigabyte X570 AORUS XTREME, Ryzen 7 3800X 4.4Ghz, 4266/1900 MEM/FCLK, 16.26.19.45.76.tRFC 650 1T 1.600V
4x8Gb Kingston HX434C19FB2K2/16 3466C19 1.2V (Micron E-die 16nm)
OLD: Biostar x470GT8 Ryzen 7 1700 @ ~4.0Ghz CPU, 3200Mhz RAM ...
Nighthog is offline
post #13 of 50 (permalink) Old 01-14-2020, 04:39 PM
Rep: 3 (Unique: 3)
Any issues running rad fans for a while if air cooling a system at first? I'm going to be putting together a new system, but won't be purchasing my rads or blocks right away.
I was looking at the ARCTIC P14 PWM PST and ARCTIC P12 PWM PST as an option.
LOKI23NY is offline
post #14 of 50 (permalink) Old 01-14-2020, 06:43 PM
apw63's Avatar
You should be fine, so long as your are getting air movement, just check your temps.
My System
apw63 is offline
post #15 of 50 (permalink) Old 01-20-2020, 07:12 AM
CoD511's Avatar
Rep: 15 (Unique: 13)
I can only add my personal experience here and it should only be taken as such; my current fans are Noctua F-12 industrialPPC-2000 fans which I have on my radiators (with fairly thin cores, moderate fin density), which I run quite slowly (just sub-1000RPM). They're effectively inaudible without any tone or noise that I find annoying. I'm rather sensitive to the noise. My priority was good cooling with low RPM, decent static pressure fans with enough air moved. I'd love to use the Noctua A12x25 fans but I can't justify the replacement cost. I've used NoiseBlocker fans before however and I have a friend that uses them for his watercooling and whilst they're definitely efficiently, I personally was not able to tolerate the noise, even at a lower RPM.
If you end up getting Noctua A12 fans, I'd love to know how it goes and how they are.
Ryzen 9 3900X | Acer Predator XB271HU | EVGA GTX 1080Ti | ASUS Crosshair VIII Hero | 512GB Samsung 970 Pro | 1TB Samsung 860 EVO | Corsair HX850i | Corsair 900D
CoD511 is offline
post #16 of 50 (permalink) Old 01-20-2020, 03:29 PM
ttnuagmada's Avatar
Rep: 15 (Unique: 15)
Be Quiet SW3's are fantastic. Best combo of price/noise/performance IMO. I tried out a bunch of difference fans when i built my loop and they impressed me. Picked them out over GT's/ML120's/Vardar's. NF-F12's were slightly better all-round, but not for the price at the time.
ttnuagmada is offline
post #17 of 50 (permalink) Old 01-20-2020, 04:58 PM
poah's Avatar
Rep: 7 (Unique: 6)
great fans and highly recommended.
poah is offline
post #18 of 50 (permalink) Old 01-20-2020, 08:27 PM
no regurts
Kalm_Traveler's Avatar
Rep: 6 (Unique: 5)
Quote: Originally Posted by poah View Post
given the cost of them they are not worth it.
I think that would depend on how much you value cooling + silence. Totally worth it to me.
HEDT Overkill
Core i9 10980xe
Asus Rampage VI Extreme Omega
Titan RTX
Titan RTX
G.Skill Trident-Z RGB
Samsung 960 Pro
Samsung 850 EVO
Corsair AX1600i
Thermaltake Tower 900 - black
Operating System
Windows 10 Pro
LG 38GL950-G
Keyboard
Massdrop CTRL
Mouse
Speedlink Decus Respec
9900ks
Maximus XI Extreme
2080 Ti Kingpin
GSkill Trident Z RGB
Samsung 970 Evo Plus
Corsair HX1200
Cooler Master COSMOS C700M
Operating System
Windows 10 Pro
Asus PG348Q
Keyboard
Corsair K70 LUX RGB
Mouse
Corsair Ironclaw RGB
Audio
Klipsch ProMedia Ultra 5.1
Core i7 9750H
RTX 2080 Max-Q
Samsung 960 Pro
Keyboard
Razer Blackwidow TE Chroma V2
Mouse
Razer Mamba Wireless 2018
Kalm_Traveler is offline
post #19 of 50 (permalink) Old 01-21-2020, 12:15 AM
poah's Avatar
Rep: 7 (Unique: 6)
they are very quiet and cool great. hence my suggestion to use them.
poah is offline
post #20 of 50 (permalink) Old 01-21-2020, 06:29 AM
News Fiend
ryan92084's Avatar
+1 for SW3. Only issue with the E-Loops is they aren't so great for pull setups/having a restrictive intake.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
