Weird Noise on D5 EKWB PWM Pump. - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 01-12-2020, 03:50 PM - Thread Starter
Cuenda's Avatar
Rep: 0
Hello, my D5 Pump is making a weird Noise, i completed the loop long ago but i didnt had so much time to spend on the PC thats why i didnt realize until now how annoying is the noise when u stay long on the PC, i have it plugged on the H_AMP conector.
Usually i have it it normal mode so it will increase the RPM according to the CPU temp, and since the i7 7700K have those spikes from 2X to 4X withing few secs and then going back to 2X at the begining i was thinking there was the problem but then i set it on Fix RPM and yet is doing that ****, i recorded a video to show what i mean.
The problem is like, i set it on fixed 2000RPM then it try to go over 2000, then go back to 2000, then go over 2000 again, like that, causing an annoying noise.
In the video first i set it at 2000 RPM then later at 3000 RPM to show that is still doing to the same.
Cuenda is offline
post #2 of 7 (permalink) Old 01-12-2020, 07:04 PM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
With the pump sideways usually air is stuck in it.
Lay the case on it's back....
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #3 of 7 (permalink) Old 01-13-2020, 04:12 AM - Thread Starter
Cuenda's Avatar
Rep: 0
Well, i come back with my problem "Fixed", at least the pump now doesnt make the Noise that it was doing when i had conected in the H_AMP, i remember that i didnt connect in the CPU_FAN coz it wont read the RPM of the Pump, and connected in the W_PUMP was at 100% so i fixed it in the BIOS, it can work fine in any of those 2 conectors, the only problem that i had is that they cannot read the RPM of the PUMP so i must set it in the Bios coz Windows cannot read them either, i set them in PWM mode, wich works by % instead of RPM, its working fine but i would like to read my RPM, what can i do, do i have to connect the cable "Wrong", since it has only 2 cables in the conector of the cable and PWM is 4 Pin conector?
Cuenda is offline
post #4 of 7 (permalink) Old 01-13-2020, 05:45 AM
ThrashZone's Avatar
Hi,
Lowering the speed is hardly a fix
Tilting the case and even laying it on it's back would at least get the air out of the pump which is trapped in it.
But I've already said that haven't I
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #5 of 7 (permalink) Old 01-13-2020, 07:00 AM - Thread Starter
Cuenda's Avatar
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
I can assure you the problem wasnt Air stuck or something like that, the problem that i had before when it was conected on H_AMP is that, in the AI Suite software i set a limit of 2000 RPM and then in the bar that is showing at what speed is working you could see so clear that it was going over the 2000 RPM that i set at limit, then going back to 2000 and all the time like that, makes sense that it was the problem coz the sound was in tune with the RPM bar.
Right now without moving the pc case or anything like that, just changing the conector to another one and set it to PWM mode in bios the sound is gone, my problem now is that i cannot read the RPM in Bios or Windows.
Cuenda is offline
post #6 of 7 (permalink) Old 01-16-2020, 01:19 PM
Ashcroft's Avatar
Rep: 92 (Unique: 72)
If the MB can't read the RPM from the pump then there is a problem. It sounds like maybe the speed was changing because the header was not getting a speed signal to use to adjust the pump speed so it was varying the speed because it thought the pump had stopped.
The pumps cable connects just like any other PWM device, it just doesn't have the two power cables because it gets power straight from the PSU. Don't connect it any other way or you could damage something like sending 12V down a 5V circuit.
Check all the wiring and the pins in the connector. If that is all OK then you can open the back of the pump and take a look at the RPM wires connection to the PCB that is inside. They can sometimes break loose. If after all that you can't see anything clearly wrong and other PWM devices work fine with your MB then I would RMA the pump.
It sounds like it can still be controlled and RPM really doesn't matter as much as finding a nice quiet speed though.
Ashcroft is offline
post #7 of 7 (permalink) Old 01-16-2020, 02:00 PM
ThrashZone's Avatar
Hi,
One question does the pump make the same noise or any noise not connected to any fan port ?
Since it only receives and outputs on the two pwm wires it shouldn't matter which fan port to use
Use a regular chassis port
Only ones I would not use is a actual Pump port or FS_Fan port or Assistant fan.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
