Are my temps too high ? - Overclock.net - An Overclocking Community
post #1 of 58 (permalink) Old 01-14-2020, 03:39 AM - Thread Starter
Ki2Is87's Avatar
Rep: 0
Hi guys,
last month I got a 7900x and a EVGA x299 FTW K motherboard, 32Gb 3600mhz of Patriot Viper Steel Ram and my PSU is a Silverstone SST-ST75F-P.
Furthermore, I've got a EK Supremacy Evo, a Corsair 900D, 1x XE480 + 1x XE360 rads, a D5 pump @85% speed and 7x Be quiet silent wings 3 120mm fans, running @ 1200rpm max.
The Cpu is delidded and direct die mounted with the ICEMAN Delid Die Guard and Liquid Metal on top.
My GTX980TI is in the same loop as my 7900x but not overclocked and has stock TIM on the GPU.
My final settings are 4.5ghz all core, no Avx offset (Avx 0), VIN 1.850v (input voltage), VID 1.212v (OCCT 1 Hour Small Data Set stable @ 1.175v + 0.037v =1.212v overhead for 100% stability)
During 30 to 60 fps rendering, with hybrid and svp (smooth video project), I'm getting a max temp of 80 C, the system is pulling 480w in total from the wall.
During a 5 minute OCCT Small Data Set run, it's getting unstable @ 4.6ghz, AVX0, VIN 1.838v, VID 1.225v, reaching 99 C and pulls 747w from the wall.
Are these temps fine for a XE480 + XE360 custom loop, or too high?
Thx.
Ki2Is87 is offline
post #2 of 58 (permalink) Old 01-14-2020, 07:55 AM
StAndrew's Avatar
Rep: 14 (Unique: 10)
They look a little high but just the temps mean nothing; I really need the water temps are or at least ambient air temps.
I think you have enough radiators but not sure; ultimately it depends on how efficiently they are working. How do you have them mounted in your case?
If you have a water temp sensor, the temp should be ideally no more than 10* over ambient air; I try to shoot around 5* over ambient.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #3 of 58 (permalink) Old 01-14-2020, 08:14 AM
Overclocker in training
ThrashZone's Avatar
Rep: 118 (Unique: 79)
Quote: Originally Posted by Ki2Is87 View Post
Hi guys,
Thx.
Hi,
For a stock or not delidded 7900x probably normal on a ek evo
You can try a newer generation water block it will at least do a lot better than ek evo is doing
There is also the optimus signature block but that one is 200.us the foundation is 120.us but does a lot better.
https://optimuspc.com/products/found...pu-block-intel
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #4 of 58 (permalink) Old 01-14-2020, 08:52 AM
StAndrew's Avatar
Optimus is a great block, probably the best on the market. Get a filter/flush your loop though, as those fins are very tight and even the smallest debris will clog it up.
But I think that will only solve part of your problems. I think your radiators are not operating effectively.
StAndrew is offline
post #5 of 58 (permalink) Old 01-14-2020, 08:59 AM
ThrashZone's Avatar
Hi,
Direct die is fiddly and not on right or making good contact.
Most people abort it's such a pita.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #6 of 58 (permalink) Old 01-14-2020, 09:10 AM
NewUser16's Avatar
Rep: 48 (Unique: 32)
Quote: Originally Posted by ThrashZone View Post
Hi,
For that $ I would go to Heatkiller IV Pro
NewUser16 is offline
post #7 of 58 (permalink) Old 01-14-2020, 09:39 AM
ThrashZone's Avatar
Hi,
Depends really
If PPC had one it might be good but if PPC didn't and had to buy from watercool HK 4 pro would be nearly as much as a better optimus foundation block where shipping is dirt cheap 7.us usps instead of 30 euro fedex.
I've got 2 copper plexi heatkiller 4 pro's by the way
https://www.overclock.net/forum/61-w...l#post28261118
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #8 of 58 (permalink) Old 01-14-2020, 09:50 AM
StAndrew's Avatar
Heatkiller is a good block but the Optimus V2 fins are much thinner and I would wager performs better. I haven't seen any reviews yet. Either way, performance should be close.
Hi,
Hardmounting can be a PITA. I've always used original mounting hardware and washers/spacer approximately the thickness of the IHS to insure each corner is getting equal pressure.
The 7900X has a big die and should be an easy mount. I just finished my 8700k and that die is tiny. I had some concern over the shallow CPU silicon so I used some 1mm 3M insulation foam stuck behind the die to keep it sitting "proud". Mounted perfect the first time.
StAndrew is offline
post #9 of 58 (permalink) Old 01-14-2020, 09:50 AM
NewUser16's Avatar
On one of my systems I have the black copper that cools none delidded 6950X OC to 4.6GHz, temps never go above 90C and radiator fans (Noctua) are at 80% RPM.
I have tried that with Aquacomputer and Koolance blocks and I couldn't get that so block makes a difference and I've always used Heatkiller, never disappointed
Btw. Maybe this new Optimus is good
post #10 of 58 (permalink) Old 01-14-2020, 09:54 AM
ThrashZone's Avatar
On one of my systems I have the black copper that cools 6950X OC to 4.6GHz, temps never go above 90C and radiator fans (Noctua) are at 80% RPM.
Hi,
Run blender open data full test and see what it does
https://opendata.blender.org/
Just lowered my avx offset by 1 not at avx 2 on 4.8
Still have two cores at 79c so optimus foundation is doing quiet well
Name:	x299 optimus 4.6 BOD Long.png
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
