Fluid In resevoir End Cap Screw Threads - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 01-15-2020, 05:30 AM - Thread Starter
Rep: 0
I recently got a 150 Phoyba Reservoir which is mounted horizontally to the top of my case, and am I am using blue XSPC Fluid with the system. On one side the thread where the cap screws into the reservoir has some of the fluid inside in the actual threads,where the end cap screws into the acrylic, where the other side doesn't? both caps are tight and It does not leak, but at the bottom it seems the fluid extends through all the threads. Is that common or is that something I should be concerned about > ?
islhopr is offline
post #2 of 4 (permalink) Old 01-15-2020, 05:54 AM
Overclocker in training
ThrashZone's Avatar
Rep: 131 (Unique: 85)
Hi,
If it's designed to be horizontal both ends of the tube should have o-rings.
If not it's not designed well and probably will leak eventually.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 4 (permalink) Old 01-15-2020, 07:20 AM
StAndrew's Avatar
Rep: 15 (Unique: 11)
Threads are generally not sealed tight. As long as the gasket is sealed, nothing to worry about.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #4 of 4 (permalink) Old 01-15-2020, 07:29 AM
Shawnb99's Avatar
Rep: 48 (Unique: 31)
If concerned you could always buy a new cap to replace it.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
