Need help on flex tubing sizing - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 01-21-2020, 10:46 PM - Thread Starter
mrab54's Avatar
Rep: 0
I'm looking for some help understanding the sizing of tubing and fittings. It has been about 10 years since my last water cooling build with zip ties!
I'm set on going with flex tubing, black in color - mainly geared towards ease of assembly/maintenance more than anything. I'm looking at Primochill's site for tubing and they offer a variety of sizing, so I guess my question is what is standard, what will offer the best durability and strength? I've heard Bitspower fittings are good quality, I think I'd prefer compression fittings.
My rads are going to be EK Coolstream XE 360 and Corsair hydro x xr5 240. Pump res EK Quantum kinetic D5 PWM. CPU block undecided for a 3950x.
Any help would be appreciated.
mrab54 is offline
post #2 of 19 (permalink) Old 01-21-2020, 11:39 PM
Rep: 2 (Unique: 2)
Go for ZMT tubing for easier maintenance. 16mm OD tubing. Corsair Rads are oem HWlabs.
Sent from my SM-G975F using Tapatalk
bhoot is offline
post #3 of 19 (permalink) Old 01-21-2020, 11:47 PM
rdr09's Avatar
Rep: 874 (Unique: 637)
I think op needs more info as to what fitting such as barbs to use with what tube.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #4 of 19 (permalink) Old 01-22-2020, 07:00 AM
apw63's Avatar
Rep: 65 (Unique: 56)
Match your fittings of choice to the ID & OD of your tubing of choice. IMO anything with a ID greater that 10mm is just for aesthetics. 99% of water blocks and fittings are G1/4 or 10mm ID. All coolant has to pass through the 10mm hole. Try to find tubing that is plasticizer free
My System
ASUS ROG Swift PG278Q Owner's club
Asus Maximus XI Formula, 8700K, Corsair Dominator Platinum ROC 3200 16GbB, Asus ROC STRIX 1080 Ti OC version.
apw63 is offline
post #5 of 19 (permalink) Old 01-22-2020, 07:03 AM
Rep: 0
Below article will help with fitting and tube sizing. AFAIK 10/13 is common tube size but 10/16 has better kink resistance
https://www.ekwb.com/blog/fittings-and-tubing-guide/
vivacious_tg is offline
post #6 of 19 (permalink) Old 01-22-2020, 07:09 AM
Rep: 2 (Unique: 2)
Fittings. Honestly, we can post replies here but nothing beats actually buying a few different fitting and just playing around with them. It's what I did. Bough a 90/45 fittings, extensions and few cheap compression fittings from eBay and the cheapest rad I could find and just look at how it held together, how much I needed tighten it. Yes there are different size tubes and fitting. Once I had seen things in my own hands, I knew what I fittings I wanted and how the loop would look. Still use my first test fittings as fill top up setup.
bhoot is offline
post #7 of 19 (permalink) Old 01-22-2020, 07:12 AM
rdr09's Avatar
OP, i've used Black Primochill tubes and they developed white residue in just a few months using distilled water only. OTOH, my XSPC tubes never had any even after years of service.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #8 of 19 (permalink) Old 01-22-2020, 07:16 AM
Overclocker in training
ThrashZone's Avatar
Rep: 128 (Unique: 84)
Hi,
Two of the best new amd blocks on the U.S. market from a New U.S. company based in Chicago
https://optimuspc.com/products/foundation-cpu-block-amd
https://optimuspc.com/products/absol...threadripper-3
Hosing is always 3/8"-10mm only the outside changes 5/8"-16mm is best or thinner wall 1/2"-13mm
Get which ever soft tube barb fittings to accommodate Optimus also has fittings....
You can get PPC discount codes OCN55 for 5% off and they do have holiday codes
https://www.overclock.net/forum/61-w...l#post28289642
Had someone who had issues with black tubing
https://www.overclock.net/forum/61-w...l#post28245906
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #9 of 19 (permalink) Old 01-22-2020, 07:23 AM
rdr09's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
What size barb or compression fitting would fit those size hoses?
I'm aware another member posted info about it already. Just want to keep it simple.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #10 of 19 (permalink) Old 01-22-2020, 07:25 AM
PC Cannibal
DarthBaggins's Avatar
Rep: 92 (Unique: 73)
I would also recommend EK's ZMT (3/8-5/8 - 10/16mm) Any 3/8-10mm barb will work and then 10/16mm compressions as well. ZMT has become my go to soft tubing and is the best to work w/ imo.
*Official*CaseLabs Owners Club!
[Official]Polaris Owners Club
I <3 Mechanical Keyboard
JAC Temper tantrum
(41 items)
PumpkinKing_Jack
(15 items)
The Box
(11 items)
i7 6900k
ASUS x99 Deluxe
MSI GTX 1080 Ti Aero OC
Corsair Dominator Platinum 32GB DDR4 2400 CL10 (4x 8GB)
Samsung 960 EVO 500GB NVMe - Windows 10 Pro
Inland Professional SSD - Linux Mint 19
Seagate Barracuda 2TB
Samsung 840 Evo 1TB (RAID 0)
Samsung 850 EVO 500GB (RAID 0)
Optical Drive
LG GP65NS60
Seasonic 760XP²
EKWB Supremacy EVO x99 Nickel/Plexi
Corsair ML120 (X6)
EK D5 PWM
EK EX-RES250 RGB
EKWB PE360
EK ZMT Tubing 3/8 x 5/8
EKWB FC1080TI GTX Nickel Plexi
InWin 303 Black
Operating System
Windows 10 Pro 64bit
Operating System
Ubuntu 14.04LTS (Mate Mod)
Acer XF270HU
Keyboard
Cooler Master Master Keys Pro S RGB
Keyboard
iKBC New Poker II (Type-C) with Cherry MX-Browns
Keyboard
Ducky OCN Edition with Cherry MX-Blacks
Mouse
Fnatic Flick G1
Mouse
FinalMouse Scream One
Mouse
Zowie EC1-A Special Edition (White)
Mouse
Logitech G403 Wireless
Mouse
Razer Deathadder Chroima Black Ops 3 Edition
Mouse
Glorious Model O (Matte White)
Mousepad
Razer Goliathus Call of Duty: Black Ops III Edition Soft Gaming Mouse Mat, Medium Speed
Audio
Kanto YU2 Gloss White
Audio
Sennheiser PC 360 Special Edition
Audio
Sound Blaster Zx
Other
CableMod Widebeam RGB LED kit (x2)
Other
Mod-One PC Custom Cables
i7 3770
ASUS PH-61
PowerColor RX 580 8GB
Corsair Vengeance 16GB
Seagate Barracuda 2TB 7200RPM
Samsung EVO 860
Corsair HX620
CoolerMaster Masterliquid 120 Lite
Fractal Design Define Mini
Operating System
Ubuntu 14.04 LTS
Operating System
Windows 10 Home
Asus VS238H
Keyboard
Velocifire TKL w/ Outemu Browns
Mouse
Steel Series Rival 110
Mousepad
razer goliathus black ops 3 edition
i7 3770
ASUS P8H61-I R2.0
EVGA GTX 1050 SC
Crucial Ballistix Tactical 8GB DDR3 1600 CL8 (2x4GB)
Samsung 860 EVO 250GB
Seagate Barracuda 500GB SSHD
Seasonic SS-400FL
Lian-Li PC-Q07
Operating System
Windows 10 Home 64Bit
Keyboard
iKBC Poker II Type-C - Cherry MX Browns
Mouse
Microsoft Intellimouse Optical 1.1A
DarthBaggins is offline
