Loop bleeding - Overclock.net - An Overclocking Community
Loop bleeding
post #1 of 18 (permalink) Old 01-26-2020, 01:40 PM - Thread Starter
Rep: 0
Loop bleeding
Hey,
I am very new to custom cooling to every advise would probably be very helpful.
I guess there are like million treads with the same issue, but I also guess that every loop is kind of different.
So I Just upgrade my loop and I have difficulties bleeding it. I mean, there is huge bubble trapped in the thick front rad.
It used to have this layout, the bleeding of this config was really easy.
Pump&Res combo -> GPU block -> 240mm slim rad(top) -> CPU waterblock -> 360mm slim rad(front) -> pump&res combo.
it worked fine but the temp where bit high and noisy so I upgraded one of the rads.
Now this is the layout
Pump&Res combo -> GPU block -> 360mm slim rad(top) -> CPU waterblock -> 360mm thick(60mm) rad(front) -> pump&res combo.
There are some pic here.
Can it be a sign of problem?
Thanks every one for the help =]
Koby990 is offline
post #2 of 18 (permalink) Old 01-26-2020, 01:47 PM
Overclocker in training
ThrashZone's Avatar
Rep: 130 (Unique: 85)
Hi,
GPU is piped backwards for one
EK gpu blocks the the left side is inlet right side outlet on 1080ti
If switched it creates a conflict at the water jet flow
Instead of going in jet plate and splitting into two different directions
Fluid will be going from two directions into one that is conflict.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 18 (permalink) Old 01-26-2020, 01:48 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 611 (Unique: 504)
Tip the case in all directions.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #4 of 18 (permalink) Old 01-26-2020, 10:00 PM - Thread Starter
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
OK, I will gonna have to drain the loop and change it, could it be the cause for the big air bubble? it could impact the CPU cooling performance?
Because the gpu cooling performance looks fine. The CPU temps look little bit high. Maybe it can cause an back impact on the flow rate?
There are more points in that matter? I would like to address all of them if I am draining the loop.
I have tried if for couple of hours, sadly it won't budge.
Koby990 is offline
post #5 of 18 (permalink) Old 01-26-2020, 10:41 PM
Shawnb99's Avatar
Rep: 48 (Unique: 31)
Turn the pumps on and off, keep tipping and after awhile the air will bleed out
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #6 of 18 (permalink) Old 01-26-2020, 11:53 PM
NewUser16's Avatar
Rep: 50 (Unique: 33)
Do the old fashion way and the bubble(s) will go away without you tipping or turning pump off and on. Add 1-2 drops MAX of clear Down Dish soap, works every time, even if you have pastel or dyed liquid, but It has to be clear Down, don't use the color one.
1. Dish soap will release surface tension and any bubbles you have in your line will be gone with no time and
2. It will help your pump(s) to run quieter as well
NewUser16 is offline
post #7 of 18 (permalink) Old 01-27-2020, 12:48 AM
Shawnb99's Avatar
I keep forgetting about this method. Does this work when using mayhems XI fluids or just distilled?
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #8 of 18 (permalink) Old 01-27-2020, 07:10 AM
ThrashZone's Avatar
Hi,
You're killing a lot of flow going backwards through the gpu it's not surprising it's cool though it's first in line it will always be cool in that position
But that is killing pressure for the rest of the loop.
Draining at this point is no loss it's not filling anyway.
This will always give a single gpu the best flow
Name:	ek 1080ti water block.jpg
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #9 of 18 (permalink) Old 01-27-2020, 07:43 AM
I can count to potato
Fluxmaven's Avatar
Rep: 42 (Unique: 16)
Do you not have a drain valve? If you tear it down to swap the GPU tubes, I would add one while you have it apart. Also when filling the loop, it helps to run the pump at max until you get all the bubbles out, then you can set it at your desired speed.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #10 of 18 (permalink) Old 01-27-2020, 08:26 AM
Rep: 0
Old school....never fail the old fairy...
Mordorr is offline
