Help? EKWB/ Lian Li Distro Plate - Page 2 - Overclock.net - An Overclocking Community
post #11 of 26 (permalink) Old 02-04-2020, 04:08 PM
Rep: 8 (Unique: 5)
if that connector on your MB isn't working, then you either need to turn it on or there is something wrong with your board. It could just be that connector may be defective, but odds are good there may be something more. So I would prove out connectors, etc. before putting it all together. If you look in the bios there should also be a control setting for it as well. It may be defaulted at a very low speed or even off until you set it. Anyway, do yourself a favor and buy a cheap PSU, doesn't have to be high wattage. Pickup the EK connector that you can plug your pump to the extra psu into. You want zero power to any components in case of a leak. Fill your res and turn the pump on, then cycle it off almost immediately. Believe me, it'll push that little bit of coolant seriously fast. Keep topping the rest until your system is full. Cap everything off and let it run for a bit to make sure there are no leaks under pressure. Even if you pressure checked it before filling, there is always the chance you could still have a minor leak. Take your time or it could cost you. We've all seen videos of what can happen.
Soulpatch is offline
post #12 of 26 (permalink) Old 02-04-2020, 07:18 PM
hanzy's Avatar
Rep: 20 (Unique: 18)
Sounds like OP already did that if you read last post. They tried a bunch of different adapters.
From everything they're saying it sounds like it was just a bad pump.
I don't know what the Corsair pump is, but hopefully its a D5 variant.
Did you have to scrap the whole Distro plate OP?
“Go then, there are other worlds than these.”
“Every gun makes its own tune... Alive or dead, it's your choice.”
Vin: We deal in lead, friend.
Calvera: So do I. We're in the same business.
Vin: Only as competitors.
hanzy is offline
post #13 of 26 (permalink) Old 02-05-2020, 06:20 AM - Thread Starter
Rep: 0
So After trying two different EKWB Distro Plate G1's I ended up just switching to the Corsair XD5 pump. When turning it on, the pump turned on but very weak when using the corsair RM750x. So I decided to buy a new PowersupplySeasonic Focus GX-750. Plugged it in and the same issue. I decided to move the case around to maybe let some loose air and see if the motor would start spinning and after about a minute, the pump kicked in full gear.
Do pumps usually take time to power to 100%?
abel palustre is offline
post #14 of 26 (permalink) Old 02-05-2020, 06:29 AM
Overclocker in training
ThrashZone's Avatar
Rep: 131 (Unique: 85)
Hi,
If the D5 is powered by sata or molex they run as soon as power hits the pump but for filling you'd never connect the pwm wire to the board seeing it would hamper with full speed operation of the pump.
Connecting the pwm cable to the board passes the operation to the mother board bios and it operates the pump via temperature.
EK's system is flawed for filling the loop basically
You'd have to get a pwm fan splitter cable that is powered by sata or molex so it cranks the power to the pwm cable to full blast for filling it would also have a pwm connection to eventually connect to a fan port on the board.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #15 of 26 (permalink) Old 02-05-2020, 06:54 AM
ThrashZone's Avatar
Hi,
Did you use one of these to trick the psu to give power to the molex ?
Not good to fill a loop while the board is also powered on
If you have a leak you'd like fry the board if any water gets on it
Spoiler!
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #16 of 26 (permalink) Old 02-05-2020, 09:52 AM
hanzy's Avatar
Depends on how the PWM is set up. Sometimes no PWM signal means the pump will run at 100%. Most of the D5's I have used run at 100% duty cycle when no PWM signal is present.
Either way once the system is filled, leaked tested, bled you should use the BIOS/Motherboard software app to setup a profile for the PWM on the pump based on temp.
There are more elaborate solutions to regulate pump RPM based on water temp etc... but setting the PWM "curve" via motherboard will be good enough.
Keep in mind, even at full tilt ~4700RPM the D5 pumps are pretty quiet.
But like thrash said, when filling, bleeding, leak testing you ONLY want the pump to have power via Molex/SATA whatever kind it is. The rest of the system needs to be POWERED OFF. Do yourself a favor for future loop maintenance and all that and buy a cheap PSU if you don't have a spare to JUST run the pump. Either make your own jumper or buy one.
@thrash , how is EK's D5 pump design flawed? No PWM signal is 100% duty cycle. Been this way with almost any D5 PWM I have owned whether its EK or not.
hanzy is offline
post #17 of 26 (permalink) Old 02-05-2020, 06:10 PM
ThrashZone's Avatar
Hi,
The ek pump pulls power off the pwm wiring from the mother board
Meaning the entire board needs to be powered on to just fill the loop because that is the only way the board gives power or a pwm signal.
From a leak finding/ testing perspective that is silly seeing if you have a leak you can very well fry your board if it gets wet.
The jumper I posted fakes the power supply in powering sata and molex power lines not anything else
It only works if the pump is powered by sata and or molex though.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #18 of 26 (permalink) Old 02-05-2020, 09:52 PM
hanzy's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
A DDC pump, yeah. We're talking D5's though right? You have a D5 that doesn't have a molex or SATA cable for power/ground?
My last four builds have used EK D5 pumps. Regular PWM D5, two D5 PWM with their top, dual D5 PWM, and the D5 PWM that came installed in my "FLT Kinetic" combo Their dual top D5 setup was excellent btw. Anyways, every single one of their D5 pumps ran without the PWM header plugged in, only the molex connector and a spare PSU jumped over.
hanzy is offline
post #19 of 26 (permalink) Old 02-05-2020, 10:08 PM
Hardrock's Avatar
Rep: 6 (Unique: 6)
I have the same Distro plate. The Pump plugs directly into a 4 pin fan header. I used the EK leak tester to pressurize the system and check for leaks. After that just fill up the distroplate and turn on the computer leaving the CPU power cables disconnected. The distroplate will fill the CPU tubing within a few seconds, you wont burn anything up.
Hardrock is offline
post #20 of 26 (permalink) Old 02-12-2020, 10:17 PM
Bartdude's Avatar
Rep: 3 (Unique: 2)
@hanzy , awesome
"No s*** lady, does it sound like I'm ordering pizza!"
Corsair 900D
(29 items)
Intel E4790k Haswell
Asus ROG Maximus VII Watchdogs
EVGA 1080 SC Gaming
Corsair Dominator Platinum
Samsung SSD
Samsung SSD
Samsung SSD
Optical Drive
LG Blu Ray Rewriter
Corsiar AX1200i
EK XTOP Revo Duel D5
2X EK Radiator 360 PE
EK Supremacy EVO
EK 1080 Full Cover Waterblock
Aquero 6 XT
Aquero MPS 400 Flow Sensor
9X Gentle Typhoon Fans
Aquacomputer Hubby7
4x Aquacomputer Splitty9
Aquacomputer Poweradjust USB 3 Ultra Version
Corsiar 900D
Operating System
Win 10 Pro 64
Asus ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor
Keyboard
Razer Blackwidow Soft Touch
Keyboard
Razor Orbweaver
Mouse
Razer Deathadder 3500DPI
Mouse
Razer Mouse Mat
Audio
Sound Blaster X-Fi Titanium Fatal1ty Champion Series
Audio
Yamaha RX-V381 5.1 Channel Receiver Amplifier
Audio
Tannoy 5.1 Speakers
Bartdude is offline
