Help? EKWB/ Lian Li Distro Plate - Overclock.net - An Overclocking Community
post #1 of 26 (permalink) Old 02-02-2020, 10:43 PM - Thread Starter
Rep: 0
i got the ekwb distro plate for the lian li. the ddc pump has a 4 pin connector. when plugged into the sys_pump it doesn’t power but when i plug into the cpu_fan it turns on for about 5 secs and cuts off. I have a corsair rm750x powersupply. Someone on reddit said their g1 came with a molex power cable with the pump? Would it be better if i get a 4 pin to Molex adapter and try that?Any help would be great.
PC Specs:
aorus z390 pro wifi mobo
Corsair rm750x psu
Running 6 Corsair QL120 fans
images:https://imgur.com/a/hlFoBc6
https://imgur.com/a/lTDbQz7
abel palustre is offline
post #2 of 26 (permalink) Old 02-02-2020, 11:11 PM
Shawnb99's Avatar
Rep: 48 (Unique: 31)
4 pin is likely PWM control and power is via the molex. Use the molex to power the Pump
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #3 of 26 (permalink) Old 02-02-2020, 11:33 PM
munternet's Avatar
Rep: 16 (Unique: 9)
I think you have the one that is designed to go directly into a fan header. No molex.
6W 4-Pin PWM FAN connector. Am I right?
Check your motherboard manual to see if you have a suitable fan header to supply the required power.
Edit: System fans/pump headers 5 and 6 are also water pump headers and speed can be controlled from the bios
Page 15 item 5
page 32 - BIOS section - M.I.T/Smart Fan 5 Settings
Intel Memory Overclocking Quick Reference https://www.overclock.net/forum/27784556-post7836.html
9900ks
Asus Maximus XI Gene
EVGA 1080 Ti Superclock 2 Black
F4-4400C19D-16GTZSW
Samsung M.2 1TB 970 EVO Plus
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 1 x 360mm and 1 x 420mm Radiators and Vardar Furious Fans
ThermalTake V51
Operating System
Windows 10 Pro
Asus PG349Q 34.1 inches 3440 x 1440 pixels @ 120 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000x500x3
Audio
Steelseries Siberia800 wireless Headset
8700k @ 5.2ghZ
Maximus X Hero
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Asus Maximus VII Ranger
Gigabyte NVIDIA GeForce GTX980
G.SKILL Trident X 16GB 2 x 8GB 2400 Memory F3-2400C10D-16GTX
Seagate Barracuda 2TB
Optical Drive
LG DVD Rom
PSU Coolermaster V1000W
Custom Loop
Case Thermaltake V51 Full Window
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Thermaltake Poseidon Z
Mouse
Logitech G602
munternet is offline
post #4 of 26 (permalink) Old 02-02-2020, 11:45 PM
Iconoclast
Blameless's Avatar
Rep: 3140 (Unique: 1873)
It's a 6w pump...it should be able to run fine off any 3 or 4 pin motherboard header.
Power it up with an adapter to ensure that it functions. If it doesn't something is wrong with the pump or there is an obstruction.
If it does power up when run off just 12v, your PWM settings for your fan headers are probably too low for the pump to start correctly.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #5 of 26 (permalink) Old 02-02-2020, 11:49 PM
munternet's Avatar
Rep: 16 (Unique: 9)
I don't think pumps like to run dry... just in case you didn't have the system full when testing.
Should test fine in the board if fans work from ports 5 and 6
As Blameless says, make sure the header speed is turned up in the bios and that it's set to PWM.
9900ks
F4-4400C19D-16GTZSW
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Pro
Keyboard
Mouse
Mouse
Mousepad
1000x500x3
Audio
8700k @ 5.2ghZ
Maximus X Hero
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Optical Drive
LG DVD Rom
Custom Loop
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Mouse
Logitech G602
post #6 of 26 (permalink) Old 02-03-2020, 06:12 AM - Thread Starter
Rep: 0
So the system isn't full with fluid so I don't want to burn my cpu.
*note first time doing a custom loop ever. Everything is new except for fans and CPU (8700k).
https://imgur.com/a/9zuZPNZ
post #7 of 26 (permalink) Old 02-03-2020, 06:40 AM - Thread Starter
Rep: 0
I plugged it into ports 5/6 and they don't turn on at all. That's when I decided to switch the connection to the CPU_Fan connector.
post #8 of 26 (permalink) Old 02-03-2020, 09:17 PM
Rep: 8 (Unique: 5)
There should be a water pump connection on your motherboard. I'm running a Z390-e and there is a 4 pin pwm connector to power the pump. Look through your manual and find out where yours is located. Don't just randomly plug stuff in. Never a good idea. I'm running a bitspower front distribution plate for the lian-li 011 so they are fairly similar. Again, your board should have a pump control pwm connection. Don't run it dry and try to fill it as it pumps through the system. You can't keep up and you'll wreck the pump. Use a jumper to your power supply to help with that. $3 bucks from EK and works great.
Soulpatch is offline
post #9 of 26 (permalink) Old 02-03-2020, 11:49 PM
hanzy's Avatar
Rep: 20 (Unique: 18)
Have you been running the pump dry?
Typically you want a spare PSU that has been jumped over so you can run JUST the pump and none of the other components(CPU, Motherboard, GPU etc...) are powered up in case there is a leak.
As well as quickly being able to turn off the pump during filling, draining, bleeding.
Looks like that unit comes with a DDC style pump which I have never used but they do say in the manual to run it with fluid in the system.
Besides that EK notes to install the 4 Pin PWM header to a designated CPU or Water pump 4 Pin PWN connector on your motherboard.
“Go then, there are other worlds than these.”
“Every gun makes its own tune... Alive or dead, it's your choice.”
Vin: We deal in lead, friend.
Calvera: So do I. We're in the same business.
Vin: Only as competitors.
hanzy is offline
post #10 of 26 (permalink) Old 02-04-2020, 06:37 AM - Thread Starter
Rep: 0
Has fluid, I have to sys_pumps which is for the water pump. It doesn't work.
So from my testing.
- Bought a 4 pin to molex adapter (really only has 2 pins), tested it and pump worked but was so slow that it only got to one of the GPU tubing and just stopped.
-Also previously ordered a sata to 4 pin (which has only 2 pins). Same results as above.
Being out of a PC since last Thursday, I've moved on to the corsair pump. Thanks all who had helped
