Alphacool radiators - good? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 20 (permalink) Old 02-13-2020, 07:56 AM
ChiTownButcher's Avatar
Rep: 39 (Unique: 32)
I WISH like all hell that HWL would make a 40mm version of the GTS (54 is too thick). This way it would have lower restriction than the current model and still fit in a O11-D XL in top and back of side config.
Alphacool makes good radiators and back in the Sandy Bridge days they were the gold standard of performance but I have seen MAJOR issues with Alphacool customer service and blaming customers/other companies to the point they left OCN. Because of these and a few other things I ethically cant buy their stuff.
EK PE and XE series are another good option and they have a clean aesthetic but people in here hate EK and their ports are screwed in. Because of this their have been a few issues of leaks and a few broken port threads that are a concern.
I would love to do HW labs but I would need 2x 360 GTS (along with 1xSR2 and GPU/CPU block) and that is a lot of restriction for a single D5 unless I want to turn it up to 4/5 where a less restrictive loop could be at 3 and quieter.
Why cant they make a GTS2 40mm, same fins, taller find, to reduce restriction? DAMN IT HWLabs get on that!
Self Proclaimed Gaming Nutt
ChiTownButcher is offline
post #12 of 20 (permalink) Old 02-13-2020, 08:25 AM
Overclocker in training
ThrashZone's Avatar
Rep: 129 (Unique: 85)
Hi,
GTS series looks to be not quite 30mm thick not 54 or 40mm thick
GTX are 54mm thick
GTR are 54.7mm
SR2 are 60mm
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #13 of 20 (permalink) Old 02-13-2020, 09:20 AM
Quote: Originally Posted by ThrashZone View Post
Hi,
GTX are 54mm thick
GTR are 54.7mm
SR2 are 60mm
I understand that but at 30mm its 2x restrictive as a waterblock and 3-5x restrictive as other rads. And the 54mm GTX/GTR will not fit above a Mobo or behind the side intake on a O11-D XL.
Side Intake Clearance = Behind the tray in the second chamber has 50mm clearance, 54 would not fit even if you took the filters off. In front 70mm if you are going to put in a bottom 360. (I dont like the look of a bare rad. in the main chamber)
Top Exhaust Clearance = 70mm (75 if you route your wires around the rad past the rear I/O).
Neither with fans will fit a 54mm radiator.
So my only options for the top and side are: 2xGTS (Very Restrictive for a single pump), XSPC EX, Alphacool 45, or EK PE. Of those I dont like the way Alphacool handled customer issues, and the PE is cleaner look and out performed XSPC.
Hence why I WISH Hardware Labs would make the GTS in a 40mm thick version.
post #14 of 20 (permalink) Old 02-13-2020, 09:24 AM
ThrashZone's Avatar
Hi,
Most people use dual pumps including myself
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #15 of 20 (permalink) Old 02-13-2020, 10:11 AM
Hi,
Most people use dual pumps including myself [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Except other than putting it in back where the PSU is and moving the PSU up top and ditching the Hotswap Bays there is not really a got place to put dual pumps. I am even considering getting a dual pump from reservoir that is made for dual loops to run them in series because I really want the HWL. I think they need to make a 40mm version of the GTS.
post #16 of 20 (permalink) Old 02-13-2020, 10:21 AM - Thread Starter
sakete's Avatar
Rep: 7 (Unique: 6)
Hi,
Going slightly off-topic here, but how would a dual-pump setup work? Typically I see most builds having a single pump/res combo. Would you then need two pump/res combos? Or only one, with a second pump either in front or after the pump/res combo?
At this point I'm still leaning towards going for mostly Optimus PC stuff, including their pump/res combo. But since I own an Aquaero, I also like the idea of going for a D5 Next pump, as that will plug nicely into the Aquasuite software giving me more detailed info other than RPM when just connecting it to a PWM fan header.
I've thought about just getting the Optimus PC reservoir with a D5 Next pump, but then aesthetically it won't look as pleasing as the D5 Next pump would stick out from under it (and not even sure it would all fit together?).
i7-4790K @ 4.6GHz | Noctua NH-D15 | Asus Z97-Pro | G.Skill Ares 2x8GB DDR3-2400 | EVGA GS 1050W | EVGA GTX 980Ti SC+ with Kraken G10 + Kraken X31 | 480GB SanDisk Extreme Pro | 2x 4TB HGST Deskstar NAS RAID 1 | Corsair 750D | Corsair K70 MX-Brown | Logitech G502 | Acer XB270HU
sakete is online now
post #17 of 20 (permalink) Old 02-13-2020, 10:35 AM
Shawnb99's Avatar
Rep: 48 (Unique: 31)
Different tops generally combine them into one serial pump. You could also run two single pumps into each other in serial and get double the head. Running two pumps in Parallel and you get double the flow.
Head is more important then flow since you only need 1GPM flow, more head means you can get a more restrictive loop
Optimus is coming out with a dual pump/res combo, I'll keep pestering them until they do.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #18 of 20 (permalink) Old 02-13-2020, 02:39 PM
I wish there were more dual serial pump options.
post #19 of 20 (permalink) Old 02-13-2020, 08:10 PM
boostedevo's Avatar
Rep: 8 (Unique: 7)
Not really OT because it is Alphacool rads lol. EK dual serial.
boostedevo is offline
post #20 of 20 (permalink) Old 02-17-2020, 06:59 AM
Rep: 2 (Unique: 2)
Using alphacool 60mm 420+280 Rads. Easily available, respectable performance. Best Rads are HWL. For me, Alphacool is good enough, no complaints. I usually used some clear coolant or distilled water to flush over a sink.
420 Alphacool Rad with Singularity Computers 240mm res and dual ekwb serial D5s with Corsair LL140s in push pull.
Sent from my SM-G975F using Tapatalk
bhoot is offline
