Alphacool radiators - good? - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 02-03-2020, 11:00 AM - Thread Starter
sakete's Avatar
Rep: 7 (Unique: 6)
I'm debating getting some radiators later this year, and the Alphacool XT45 caught my eye, as it's a medium size and gives more flexibility in the case I'm working with. Performs pretty well at medium fan speeds, which is where I'd be as low noise levels are a high priority for me.
Are Alphacool radiators good quality?
i7-4790K @ 4.6GHz | Noctua NH-D15 | Asus Z97-Pro | G.Skill Ares 2x8GB DDR3-2400 | EVGA GS 1050W | EVGA GTX 980Ti SC+ with Kraken G10 + Kraken X31 | 480GB SanDisk Extreme Pro | 2x 4TB HGST Deskstar NAS RAID 1 | Corsair 750D | Corsair K70 MX-Brown | Logitech G502 | Acer XB270HU
sakete is offline
post #2 of 20 (permalink) Old 02-10-2020, 11:03 AM - Thread Starter
sakete's Avatar
Rep: 7 (Unique: 6)
Bump.
sakete is offline
post #3 of 20 (permalink) Old 02-10-2020, 11:57 AM
TeslaHUN's Avatar
Rep: 20 (Unique: 18)
Yes they are very good ,i had 8 -10 xt45 in past , 360 and 420 versions , i highly recommend them for low/quiet fan speeds.
TeslaHUN is offline
post #4 of 20 (permalink) Old 02-10-2020, 12:07 PM
Da Boss
NexusRed's Avatar
Rep: 153 (Unique: 129)
I have 2x360mm XT45. Fantastic Radiators. Great build and performance. Lots of performance reviews out there so for sure check those out. The only thing I would have to say is make sure you give them a good clean. I used hot distilled water and vinegar. Plenty of fill, shake, flush until there isn't any more debris on the inside. This should be a normal procedure for any new radiators.
NexusRed is offline
post #5 of 20 (permalink) Old 02-10-2020, 01:10 PM
I can count to potato
Fluxmaven's Avatar
Rep: 40 (Unique: 15)
Have an xt45 420mm in my main rig. No issues with it. The multiple ports are handy and it performs well.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #6 of 20 (permalink) Old 02-10-2020, 02:14 PM
LazarusIV's Avatar
Rep: 76 (Unique: 62)
I had a couple Alphacool rads (UT60 240mm and XT45 360mm) and I just got a Hardware Labs Nemesis-L 420mm (basically a more space-efficient GTX) and the Hardware Labs is hands down the best. Alphacool is good, but Hardware Labs is on the next level quality-wise and also beats almost everything else performance-wise.
Good Review: TechPowerUp reviews
Blessed is he who expects nothing, for he shall never be disappointed
Ryzen Again
(18 items)
Wife's Computer
(14 items)
Ryzen 9 3900X
Gigabyte Aorus Ultra X570
Radeon VII
G.Skill 4x8GB (32GB) 3600CL17 DDR4 F4-3600C17D-16GTZR
HP EX920 1TB NVMe M.2
Crucial MX300 750GB 2.5" SATA SSD
Toshiba - 2 TB 3.5" 7200RPM DT01ACA200
Cooler Master V1200 Platinum
3 x Phanteks PH-F140MP
Thermalright Le Grand Macho RT
Phanteks P600S White
Operating System
Windows 10
Philips 349X7FJEW 3440X1440 FreeSync
Keyboard
Ducky Shine TKL White with Brown Switches
Mouse
Logitech G703 Lightspeed
Audio
Sennheiser GSX1000
Audio
Sennheiser x Massdrop PC37X Gaming Headset
Audio
Kanto YU2 Powered Desktop Speakers
AMD FX 8350
Gigabyte 990FXA-UD5 Rev. 1.1
MSI Radeon RX 560 AERO ITX 4GB
G.Skill Trident Z
Samsung 840 EVO
Western Digital Caviar Black 500GB 7200RPM
Optical Drive
LG WH14NS40 Blu-Ray Rewriter
SeaSonic S12II 620W 80+ Bronze
Cryorig M9a
DIYPC J180-W ATX Mid Tower
Operating System
Windows 10 Education
Acer S271HL 27" 1920 x 1080
Keyboard
Cooler Master MasterKeys Lite L Gaming Keyboard
Mouse
Cooler Master MasterKeys Lite L Gaming Mouse
LazarusIV is offline
post #7 of 20 (permalink) Old 02-10-2020, 02:59 PM - Thread Starter
sakete's Avatar
Rep: 7 (Unique: 6)
Right, but most HL rads are 54mm+, which limits mounting possibilities (with mounting multiple rads in a case). The HL GTS is there only slimmer rad at 30mm, but it has much higher flow restrictions than any other radiator out there (at least according to XtremeRigs 2016 roundup). Doesn't affect cooling performance as it does perform great in that regard, but it can cause lower flow elsewhere in your system and requires a stronger pump.
The alphacool on the other hand has extremely low flow restriction.
Really I would have preferred the HL SR-2 which seems tuned for low RPM fans and performs very well, but it's also 60mm thick, again limiting mounting options.
sakete is offline
post #8 of 20 (permalink) Old 02-10-2020, 05:12 PM
boostedevo's Avatar
Rep: 8 (Unique: 7)
Alphacool was the only 480mm to fit, width-wise, in the bottom of my Phanteks primo. The 45mm model also makes a good fit for top of the case and I assume a lot of cases. All copper, pretty dang good radiator.
boostedevo is offline
post #9 of 20 (permalink) Old 02-11-2020, 09:59 AM
LazarusIV's Avatar
The GTS does have higher flow restriction, but that's really only an issue if you have multiple flow restrictive devices (Like a couple or a few GTS rads, some QDCs, and a restrictive block or two). If you have a typical setup, a restrictive rad and maybe a restrictive block or two, one good pump is perfectly capable. A good DDC or almost any D5 pump will do very well!
Ryzen Again
(18 items)
Wife's Computer
(14 items)
Ryzen 9 3900X
Radeon VII
Operating System
Windows 10
Keyboard
Mouse
Audio
Sennheiser GSX1000
Audio
Audio
AMD FX 8350
G.Skill Trident Z
Samsung 840 EVO
Optical Drive
Cryorig M9a
Operating System
Keyboard
Mouse
post #10 of 20 (permalink) Old 02-12-2020, 10:38 PM
Moose-Tech's Avatar
Rep: 7 (Unique: 7)
I have both Alphacool XT45 X-Flow and HWL GTS XFLOW rads in my case.
The HWL rads are very efficient but the width required me to Dremel my case to fit it in the front. Very good quality and really good at cooling with low to medium fan speeds. Most models only have the two ports.
However, there are times when you want to cut back on fittings and could really use a mutli-port rad. HWL has their SR series but you still have the width issue plus it is 60 mm deep.
The Alphacool XT45 rads offered me that extra flexibility. They are built well with a quality feel to them and are pretty decent cooling-wise.
They work well at low to medium speeds (when used with high SP fans), but are not as efficient as my HWL GTS rads.
I originally had a 140 XT45 X-Flow on the exterior rear fan set on exhaust. The extra ports allowed me to add a temp sensor, a drain, and an air bleed valve without using additional fittings.
The bleed valve was the high point of my system and also was used as a fill port. Very handy.
I now use an Alphacool 280 XT45 X-Flow radiator mounted externally. I use two Corsair ML 140 fans on push only.
When added to my loop (with 2x HWL 280 GTS XFLOW rads) I see a 25% to 35% lower delta (depending upon tests being run and ambient conditions).
All fan curves run off my Aquaero. I have a Quadro added as a remote device on my external radiator that links to the Aquaero.
You could probably get a better price for the HWL rads as the Alphacool can be a little pricey.
However, I am very happy with both of my Alphacool rads, and I am still holding onto the 140 XT45 for another build.
This is a good spot to see some very detailed reviews on radiators: https://www.xtremerigs.net/2015/02/1...or-round-2015/
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
