Explanation for Gradual Water Loss - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 02-03-2020, 02:23 PM - Thread Starter
samuelkwest's Avatar
Rep: 0
Greetings,
My personal watercooling experience is limited to two gaming systems. The first was completed in 2011, and was only just replaced with a new system in May, 2019. The first was soft tubing and the second was (is) hard tubing.
Here's my question: What would account for having to occasionally, but continually, add water to what should be a closed system?
In the case of the soft-tubing system, I found that I had to add an ounce or two every, oh... 6 months, or so. In the case of this newer hard-tubing system, I find that I am adding water even more often than that.
In both builds there have never been any leaks. In both builds the fill-ports were properly sealed with a gasketed fitting.
In the first case the system was fully enclosed in one of Cooler Master's HAF Cases, (HAF 932?), and this new one is built on Thermaltake's Core P90 (so everything is out in the open and visible...)
Thanks,
- s.west
samuelkwest is offline
post #2 of 12 (permalink) Old 02-03-2020, 02:27 PM
Overclocker in training
ThrashZone's Avatar
Rep: 129 (Unique: 85)
Hi,
Nothing cools like distilled water with inhibitor and biocide
Also nothing evaporates like distilled water
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #3 of 12 (permalink) Old 02-04-2020, 09:39 AM - Thread Starter
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
Well, that's 'zactly the combination I'm using. And, yes, it's always worked very well. After 8 years (in that 2011 system I mentioned) there was Zero evidence of fouling of any kind. The water wasn't even cloudy... From reading the various experiences that some folks have reported over the years I was always worried that things were going to go south and I would have to purge/disinfect/scrub/... the system at some point. Never happened. Also, I don't use any coloring of any kind, just what you listed. Do you have any colorant in your own system?
Anyway, to your other point about evaporation... That's really the question. How is it evaporating? I would think that if there was a path for water vapor to escape the system, then the water itself would also escape (i.e. leak). No?
Thanks for your response.
- s.west
post #4 of 12 (permalink) Old 02-04-2020, 10:26 AM
Eh, Wha?
Zero4549's Avatar
Rep: 722 (Unique: 533)
Same reason a sealed and never opened water bottle left on a counter for years will start to look like a raisin. Plastics are in fact not 100% impermeable. O-ring seals arent 100% prefect. The rate is just so low as to be totally imperceptible other then observing the effect in a closed system over a long period of time.
Systems: Fukurou | Prodigy | Tempest | ArcaneServers: Minecraft SMP | Logs: Build Log - Arcane | Video Logs: Project Arcane
Quote:Originally Posted by Zen00 https://www.overclock.net/img/forum/go_quote.gifZero, you are a master story teller, I am sleep now. http://files.overclock.net/images/smilies/thumb.gif
Arcane
(33 items)
Sanctum
(9 items)
Fukurou
(14 items)
Core i7 980x
GIGABYTE GA-EX58-UD5
MSI GeForce GTX 1080TI DUKE
MSI GeForce GTX 680 Lightning
Kingston HyperX T1
Samsung 840 EVO
WD Caviar Black FASS
Plextor M5S
WD Velociraptor
WD FALS
Optical Drive
Sony DVD Burner w/ Lightscribe
Optical Drive
LG Bluray + HDDVD
EVGA 1000 P2
Black Ice GTX 360
Black Ice GTX 240
Cooler Master HAF 932
Operating System
Windows 10 Pro (64)
X-Star DP2710
ASUS VK266H Black 25.5" 2ms LCD
Keyboard
X-Armor U9BL (Mech)
Mouse
Razer Deathadder Chroma
Mouse
Cougar Control
Audio
ATH-A900X
Audio
Maudio AV-40
Audio
Polk PSW-10
Audio
Zalman Mic-1 (Clip-on Mic)
Audio
Sound Blaster X7 LE
Other
Logitech G13
Other
Wacom Intuos 3
Other
Modded PS4, PS3, Xbox 360, and Logitech PC Controllers
Other
Thrustmaster T.16000M FCS HOTAS
Other
Rocketfish 720p Webcam
Other
Scythe "3-Foot Switch"
Ryzen 7 1700
MSI B350M Mortar Arctic
RX Vega 64
G.Skill TridentZ
Samsung EVO 960
Consatellation
Corsair HX 1050
Raijintek Aeneas White Window
Operating System
Windows 10 Pro
Core i5-661
GA-H55-USB3
12GB DDR3 1333
WD Caviar Black AALS 640GB
WD Caviar Green EARS 2TB
Vertex Turbo 60GB (SSD)
Optical Drive
Samsung Blu-ray, Samsung DVD Burner
Seasonic X750 Gold
H50 (With push/pull nocturas)
CM690 II
Operating System
Windows 10 Professional 64
LG 47inch LED LCD
Keyboard
Saitek Eclipse Lite-touch Wireless
Audio
Passive bookshelfspeakers + amp.
Zero4549 is offline
post #5 of 12 (permalink) Old 02-04-2020, 10:33 AM
LTSC Consiglieri
skupples's Avatar
Rep: 651 (Unique: 349)
evap happens, even in hard tube builds.
specially if your system gets REALLY hot, you'll evap even faster.
out of your tubes, out of your radiator, out of your plastic reservoir, out of your pipe. it's just too damn slow to see as a "leak"
cars' coolant has to be topped off every now and then, no? it's just less common due to the huge reservoir.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #6 of 12 (permalink) Old 02-04-2020, 01:02 PM
NewUser16's Avatar
Rep: 50 (Unique: 33)
With soft tubing I can see you gradually losing some liquid every so often, soft tubing tend to absorb some water after awhile.
With hard tubing, once your system is fully bled, which again, could take weeks even months so maybe you still dealing with that, but you really shouldn't see a whole lot of liquid lose, at least not something very noticeable.
If it's obvious to your naked eye that you dropping every 2-3 months you might have ghost leak which is almost impossible to find.
NewUser16 is offline
post #7 of 12 (permalink) Old 02-04-2020, 01:13 PM
Rep: 2 (Unique: 2)
Soft tubing allows for small water molecules to diffuse through the tubing. Hard tubing also does the same, depending on the material some faster than others. PETG is known for excessive diffusion through the material. Have you ever noticed bottles of water looking a little flat? I've got a bottle on the shelf just to prove this point. See attached photo. That's because water molecules have diffused through the PET.
Acrylic tubes have pretty good resistance to water loss over time but they still do a little. Since building my system with glass tubes, I've finally stopped virtually all water loss in my system.
Topping off once in a while isn't all that bad, especially if you're just using distilled water.
SuprPwrUsr is offline
post #8 of 12 (permalink) Old 02-04-2020, 01:28 PM
Iconoclast
Blameless's Avatar
Rep: 3140 (Unique: 1873)
Not well sealed and/or permeable tubing, as has been mentioned.
If it's a problem you might want to double check the seals on everything, including the res cap, and replace the tubing with something known to have low absorption and permeability, like Norprene.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #9 of 12 (permalink) Old 02-05-2020, 04:58 AM
ThrashZone's Avatar
Hi,
Yep both sun light and or heat causes evaporation heat can be anything above room temperature or 24c/ 75f degrees
I don't use any colors anymore all they do is stain
Mayhems does have some so called nonstaining dies but I doubt I'd use them regardless.
But colors wouldn't prevent evaporation.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #10 of 12 (permalink) Old 02-05-2020, 09:28 AM - Thread Starter
Rep: 0
Thanks for all the responses.
I think the rate at which I am currently adding to the hard tube system can only be explained by the 'system not fully bled' possibility.
In this particular situation, my Core P90 'Case' is mounted on the wall, and so there is no way to do any of the shaking or tilting or inverting that I did with the soft tube system, which was built in a conventional full-tower case.
The other explanations, regarding the micro-porosity of the various elements of the system, can't account for the quantity of water I am adding, and the rate at which I am doing so.
I think that, for one thing, I selected a bad 'fill port' location (the top of the vertically-mounted radiator). I may drain some water out of this and relocate the fill port to the top of the, again vertically-mounted, reservoir and see if I have better luck at more quickly purging air from the system.
I'll revisit this thread in a few months and provide an update.
Thanks, again.
- s.west
