How Often To Drain & Refill Loop!? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 36 (permalink) Old 02-04-2020, 09:57 PM
Cloudforever's Avatar
Rep: 60 (Unique: 46)
yeah, just depends on what you have.
I for one have been running about 2 years with no cleaning out and i'm just now seeing juuuust a tiny bit of microbes building up.
using only distilled water and no biocides and just 2 kill coil inserts in the rad.
i'll post pictures here shortly as i had to order some pipe cleaners to run through.
Cloudforever is offline
post #12 of 36 (permalink) Old 02-04-2020, 10:16 PM
StAndrew's Avatar
Rep: 14 (Unique: 10)
Quote: Originally Posted by LesPaulLover View Post
-I generally always monitor my temps when gaming
-Clear tubes but it's a completely closed "silent design" case (no windows on the side panels)
-Just distilled water + "Coolant concentrate: EK-CryoFuel Clear Concentrate (100mL; for 1L of coolant)"
OK I should clarify: it's the "Coolant concentrate: EK-CryoFuel Clear Concentrate (100mL; for 1L of coolant)"
so it doesn't have anything in it. It just looks like slightly-more-opaque water - doesn't seem to have any particulate or anything in it. In fact it had to be mixed with 1000ml of water (which was too much for my loop) and the rest of the mix has been sitting in my storage closet for 2 months now. There's no sediment or anything settled in the bottle.
Unfortunately there is no "magic" calculation on how long between changes, it'll be a bit of trial and error. Its good you're monitoring temps, that will help you detect a problem. Keeping water temps low will increase your anti-corrosive additive life but ultimately it will stop working and will need new fluid. I think 1 year should be max if you want to be safe. 6 months if you want to be REALLY safe. I think the longest I went was about 1.5 years and the CPU block was pretty gross but not terrible.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #13 of 36 (permalink) Old 02-05-2020, 06:12 AM
Rep: 0
I change on January after...about 10 months with distillate+car liquid.
Problem: The thermaltake tube start plasticising....very bad.
Apart that no problems.
Change tube to new from Tygan, and did try X1 Clear, already pré-mixed.
Previous, lot of cleaning with liters flushing of distillate water.
So far so good. Everyday i watch to liquid and tubes to see if there are any changes.
By specifications of X1 producer, i should change liquid every +-9/12 moths.
Waiting and see.
Mordorr is offline
post #14 of 36 (permalink) Old 02-05-2020, 06:29 AM
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
Been using distilled water with ~20% mix of Mayhems XT-1 clear concentrate for 2.5yrs.
Loop at initial build at Q3 2017 was:-
EK Supremacy Evo TR4
EK X-RES 140 Revo D5 PWM
EK ZMT 3/8" 5/8"
Barrow fittings
2x Magicool 360 G2 Slim
MSI GTX 1080 Seahawk EK X
All blocks, rads, tubing, fittings were cleaned at build of loop as listed above, first with tap water, then distilled water.
I changed to a RX Vega 64 with EK-FC Radeon Vega (copper/plexi) few months after initial build. The coolant was drained and reused as it looked clean & clear. Few months later the CPU block was changed to Bykski A-Ryzen-ThV2-X, again coolant drained and reused, as it looked clean & clear.
gupsterg is offline
post #15 of 36 (permalink) Old 02-05-2020, 06:52 AM
d3nso's Avatar
Rep: 0
I've ran loops up to 3 years on destilled water and G48 in 50/50 mix with no buildup or corrosion. I only flush the loop if I change hardware every 2/3 years.
At the end of the day it is a gamble but periods of 6 months or less are not necessary unless you are gonna use pastell or other show fluids.
d3nso is offline
post #16 of 36 (permalink) Old 02-06-2020, 04:57 AM
News Fiend
ryan92084's Avatar
Really just depends on what is in your loop. All copper blocks, clean rads, distilled+ biocide, and not caring that the copper goes black when oxidized I can go 5+ years.
Throw some nickel blocks, colored fluids, and questionable rads in there and I'd be down to a few months.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #17 of 36 (permalink) Old 02-13-2020, 09:21 PM - Thread Starter
LesPaulLover's Avatar
Rep: 19 (Unique: 17)
Thx for the tips y'all. Figure I'll call it somewhere in the middle and flush it around July (8months from installation)
Silence Redefined!
(11 items)
9900K
ASRock Z390 Phantom Gaming X
EVGA 1080Ti SC2 Hybrid
32GB T-Force DARK Pro
Plextor 1TB nVME
EVGA SuperNOVA 750 G2
Fractal Design Celcius S36
Fractal Design Define R6
ViewSonic XG2703-GS
Keyboard
ASUS ROG Strix Flare
Mouse
Steelseries Rival 600
LesPaulLover is offline
post #18 of 36 (permalink) Old 02-14-2020, 03:45 AM
Rep: 0
EK ZMT 3/8" 5/8"
Barrow fittings
Maybe slightly offtopic, but how did you find the ZMT tubes with Barrow fittings? Did you have to do any fiddling to make them work? I'm looking into this setup and I've been reading ZMT is a bit too tight with most fitting manufacturers (outside of ek). TIA!
Asunder is online now
post #19 of 36 (permalink) Old 02-14-2020, 05:45 AM
Meddling user
gupsterg's Avatar
Worked really well IMO, I don't think I did anything fiddly. I hand tightened, warmed tube with hair dryer for minute or so prior to using fitting on it, I used THKN-3/8-V3. I haven't used any other fittings or tubing, only done 2 WC builds, I would say it's a snug fit, but have nothing to compare it to.
Spoiler!
Feel free to private message if there is more you'd like to know of my experience with the tubing & Barrow fitting.
gupsterg is offline
post #20 of 36 (permalink) Old 02-14-2020, 06:29 AM
Rep: 0
Don`t understand how people use only distillate water.....
Mordorr is offline
