How Often To Drain & Refill Loop!? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 36 (permalink) Old 02-14-2020, 07:22 AM
Overclocker in training
ThrashZone's Avatar
Rep: 129 (Unique: 85)
Quote: Originally Posted by Mordorr View Post
Don`t understand how people use only distillate water.....
Hi,
Optimus says using all their products one can use just distilled water
https://optimuspc.com/
Not sure that has been tested through time or not though but supposed to be all brass and marine nickle...
Also doubt anyone willing to go that deep in pockets would skimp on just distilled water but that's another story but short story is inhibitor+ and biocide+ is not all that much
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #22 of 36 (permalink) Old 02-14-2020, 08:16 AM
Rep: 3 (Unique: 3)
I would never use just distilled in any loop. You always want some type of biocide.
I personally run Aquacomputer DP Ultra fluid and I drain maybe once every couple of years.
https://hwbot.org/user/keeph8n
3970X/3990X on ASUS Zenith Extreme Alpha II
10900X/10980XE on ASUS Rampage VI Apex/Encore
9900K on ASUS Apex X/XI
Streacom BC1 | EVGA 1600T2 | KPC T-Rex/Inferno/KPx | G.Skill Memory
keeph8n is offline
post #23 of 36 (permalink) Old 02-14-2020, 08:24 AM
Rep: 0
yep......i just don`t believe it.
Even if it is the most pure water....but each person believes what they want...lol
Mordorr is offline
post #24 of 36 (permalink) Old 02-15-2020, 08:19 PM - Thread Starter
LesPaulLover's Avatar
Rep: 19 (Unique: 17)
It's distilled water with a mix-in solution that's both a biocide and an anti-corrosive agent
I mean it's completely evaporated, then condensed and collected. The boiling process kills any organisms and the evaporation process removes any minerals and other solids that were present in the water.
Silence Redefined!
(11 items)
9900K
ASRock Z390 Phantom Gaming X
EVGA 1080Ti SC2 Hybrid
32GB T-Force DARK Pro
Plextor 1TB nVME
EVGA SuperNOVA 750 G2
Fractal Design Celcius S36
Fractal Design Define R6
ViewSonic XG2703-GS
Keyboard
ASUS ROG Strix Flare
Mouse
Steelseries Rival 600
LesPaulLover is offline
post #25 of 36 (permalink) Old 02-15-2020, 08:23 PM
LTSC Consiglieri
skupples's Avatar
Rep: 654 (Unique: 350)
its possible his crofuel is from when they were repackaging mayhems.
otherwise, stick to mayhems
Quote: Originally Posted by Shawnb99 View Post
I used 5 (4) liter jugs last run just to be safe. It helps they are only $1.99
yep, I get it by the 6 pack from the pharmacy. $1.25 a gallon. no reason to use tap water, ever.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #26 of 36 (permalink) Old 02-15-2020, 08:50 PM
Retired Staff
JedixJarf's Avatar
Rep: 305 (Unique: 244)
I run mayhems pastel green and flush every couple years (whenever something gets upgraded really), no issues here.
JedixJarf is offline
post #27 of 36 (permalink) Old 02-15-2020, 09:08 PM - Thread Starter
Wait...so when I flush my loop I can use just plain old distilled water? I dont need any additives if I'm just flushing it through?
You use a pastel AND go over a year w/o flushing your loop? This thread has been great I've been worried about nothing it sure seems like.....
Silence Redefined!
(11 items)
9900K
Plextor 1TB nVME
ViewSonic XG2703-GS
Keyboard
Mouse
post #28 of 36 (permalink) Old 02-15-2020, 09:29 PM
Retired Staff
JedixJarf's Avatar
I can't attest to any other pastel than mayhems, I've used the pastel green and the pastel white, no issues with either of them. If you just prep your system properly beforehand and clean out the gunk from the factory with distilled water everything will be fine.
post #29 of 36 (permalink) Old 02-16-2020, 12:24 AM
Aren't this fancy!
Faster_is_better's Avatar
Rep: 299 (Unique: 257)
Quote: Originally Posted by ryan92084 View Post
Really just depends on what is in your loop. All copper blocks, clean rads, distilled+ biocide, and not caring that the copper goes black when oxidized I can go 5+ years.
Throw some nickel blocks, colored fluids, and questionable rads in there and I'd be down to a few months.
I think my loop has been together somewhere around 4 years now, the reservoir is totally clear minus a few small lines which may be some remnants of calcium from my hard water (that was used to initially rinse rads). I have added a tiny bit of distilled back in 1 or 2 times, since it must evaporate from the tubes. It's actually getting low again, need to add a bit more (been saying that for 6+ months though haha).
I'm just using distilled and the Mayhems biocide.
Faster_is_better is offline
post #30 of 36 (permalink) Old 02-16-2020, 08:03 AM
Rep: 0
Quote: Originally Posted by gupsterg View Post
Worked really well IMO, I don't think I did anything fiddly. I hand tightened, warmed tube with hair dryer for minute or so prior to using fitting on it, I used THKN-3/8-V3. I haven't used any other fittings or tubing, only done 2 WC builds, I would say it's a snug fit, but have nothing to compare it to.
Hey thank you very much, that really helps! I've been really banging my head against walls on fittings and soft tube (mostly because there is really hardly anything I can find except for ZMT) and how to configure the easiest route. I'll probably go for barrow or EK and ZMT, it's just a pita to send them back + shipping fees are like a lot if they don't fit.
Asunder is offline
