2x 560mm radiators or 1x MO-RA3 Pro? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 14 (permalink) Old 02-04-2020, 04:32 PM - Thread Starter
Rep: 2 (Unique: 2)
I have two system.
Two rigs.
For both separate is question.
1. For 9900KS
2. For 3900X.
Kashtan is offline
post #12 of 14 (permalink) Old 02-04-2020, 06:21 PM
Tech Enthusiast
deafboy's Avatar
Rep: 445 (Unique: 338)
So you're going to watercool both systems and are asking which radiators you should get for each system?
I'm so confused.
What is your goal?
What other components?
IN HONOR OF SYRILLIAN, R.I.P.
ASUS ROG Rampage IV Black Owners Club || PNW Overclockers Club
BMW TJ07 Build Log -- The Ultimate Cooling Machine
2 year anniversary In Remembrance of a Great - RIP Syrillian
HTPC
(10 items)
Overkill FreeNAS
(10 items)
AMD Ryzen R5 3600
ASUS ROG Strix B450-I
nVidia Titan XP
Corsair LPX 3200C16 8GBx2
Samsung PM981 1TB
Corsair SF600
Noctua L9i
Accelero Xtreme III
Noctua NF-A12x25s
Fractal Design Node 202
E5-2670v1
E5-2670v1
Supermicro X9DRL-iF
12x HGST 4TB CoolSpin
6x WD Red 8TB
Corsair AX750
2x Noctua nh-u9dxi4
3x Scythe AP-30
Norco 4224
Operating System
FreeNAS
Intel Xeon E5-1680 V2
Asus Rampage IV Black Edition
nVidia Titan XP (2100/5200)
Corsair Dominator Platinum 32GB
Intel 750 400GB
Intel 750 1.2TB
Samsung PM981 1TB
Corsair AX1200i
2x Swiftech D5 w/ EK Dual Pump Top
XSPC EX480, EX360 & 2x Phobya 1080
EK Supremacy EVO CPU Block
EK Advanced 250mL Res
Lamptron FC-5V2
EK Rampage IV BE Water Block
Copper Tubing w/ push fittings
EK-FC Titan XP Copper/Acetal
Silverstone TJ07, heavily modified
Operating System
Windows 10 Pro
Asus PG297Q
Keyboard
Leopold Otaku
Mouse
Corsair M65
Mouse
Corsair MM600
Audio
Sennheiser HD595 / HD428 / HD280
Audio
Corsair SP2500
deafboy is offline
post #13 of 14 (permalink) Old 02-04-2020, 06:54 PM
Invalid Media
J7SC's Avatar
Rep: 50 (Unique: 24)
...Assuming we're talking cooling per individual system, with room to grow down the line for one or more w-cooled and oc'ed GPU/s per system, cooling performance-wise, there shouldn't be much difference between 2x 560s and the MO-RA3. Personally, I would lean towards the MO-RA3 because a.) a bit less less "plumbing" to do and b.) the option to use quieter 4x 200mm fans (push) or even 8x 200mm fans (push + pull). Also, per vid comment below by Gamers Nexus, apparently, the Mo-RA3 can 'passively' cool up to 200w
What speaks for the 2x 560mm option is if you choose to run dual loops (CPU separate from GPU/s) down the line in any of the systems. That is what I usually do when building oc'ed, multi-GPU systems (ie like the one in my sig) though there are pros and cons with both single/unified vs separate loops. Two 560mm rads might also be easier to re-deploy in future builds.
I'm not 100% certain yet about final configs, but my next build project will likely utilize two MO-RA3s 'in the back', with 200mm fans.
J7SC is offline
post #14 of 14 (permalink) Old 02-05-2020, 05:01 PM - Thread Starter
Rep: 2 (Unique: 2)
Thank you.
Kashtan is offline
