2x 560mm radiators or 1x MO-RA3 Pro? - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 02-04-2020, 12:23 PM - Thread Starter
Rep: 2 (Unique: 2)
2x 560mm radiators only push mode, or 1x MO-RA3 Pro im Push-Pull mode?
What is better for performance/noise?
I finding test, MO-RA2 is better then one 560GTX HWlab, im PP - 560 is better, MO-RA2 not have PP schrouds.
Just theory - MO-RA3 have got 1450ml water, weight 7.4 kg (fact, not on paper), pair 560s have got little bit 1L a water, and 6kg weight is total.
Thank you.
Kashtan is offline
post #2 of 14 (permalink) Old 02-04-2020, 12:29 PM
Shawnb99's Avatar
Rep: 48 (Unique: 31)
Why decide. Grab both
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #3 of 14 (permalink) Old 02-04-2020, 01:11 PM
outofmyheadyo's Avatar
Rep: 55 (Unique: 51)
double 560 will beat mora no problems
outofmyheadyo is offline
post #4 of 14 (permalink) Old 02-04-2020, 01:36 PM
StAndrew's Avatar
Rep: 14 (Unique: 10)
The 560's will have about a 160mm radiator advantage or about x1 120 + a 40mm radiator. I think the Mora with push/pull will be the better performer.
However...
Depending on your heat load, they will more than likely perform about the same. Unless you are running an obnoxiously high heat load (or running no fans), I'm reasonably certain each setup will return the water to almost, if not ambient temps. What nuclear reactor are you cooling?
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #5 of 14 (permalink) Old 02-04-2020, 02:23 PM - Thread Starter
Rep: 2 (Unique: 2)
I have gor two different systems - on 9900KS and 3900X. In future planning add GPUs - one or two. Overclocking on limit and beyond.
Kashtan is offline
post #6 of 14 (permalink) Old 02-04-2020, 02:43 PM
Tech Enthusiast
deafboy's Avatar
Rep: 445 (Unique: 338)
Two systems on the same loop?!
IN HONOR OF SYRILLIAN, R.I.P.
ASUS ROG Rampage IV Black Owners Club || PNW Overclockers Club
BMW TJ07 Build Log -- The Ultimate Cooling Machine
2 year anniversary In Remembrance of a Great - RIP Syrillian
HTPC
(10 items)
Overkill FreeNAS
(10 items)
AMD Ryzen R5 3600
ASUS ROG Strix B450-I
nVidia Titan XP
Corsair LPX 3200C16 8GBx2
Samsung PM981 1TB
Corsair SF600
Noctua L9i
Accelero Xtreme III
Noctua NF-A12x25s
Fractal Design Node 202
E5-2670v1
E5-2670v1
Supermicro X9DRL-iF
12x HGST 4TB CoolSpin
6x WD Red 8TB
Corsair AX750
2x Noctua nh-u9dxi4
3x Scythe AP-30
Norco 4224
Operating System
FreeNAS
Intel Xeon E5-1680 V2
Asus Rampage IV Black Edition
nVidia Titan XP (2100/5200)
Corsair Dominator Platinum 32GB
Intel 750 400GB
Intel 750 1.2TB
Samsung PM981 1TB
Corsair AX1200i
2x Swiftech D5 w/ EK Dual Pump Top
XSPC EX480, EX360 & 2x Phobya 1080
EK Supremacy EVO CPU Block
EK Advanced 250mL Res
Lamptron FC-5V2
EK Rampage IV BE Water Block
Copper Tubing w/ push fittings
EK-FC Titan XP Copper/Acetal
Silverstone TJ07, heavily modified
Operating System
Windows 10 Pro
Asus PG297Q
Keyboard
Leopold Otaku
Mouse
Corsair M65
Mouse
Corsair MM600
Audio
Sennheiser HD595 / HD428 / HD280
Audio
Corsair SP2500
deafboy is offline
post #7 of 14 (permalink) Old 02-04-2020, 03:13 PM - Thread Starter
Rep: 2 (Unique: 2)
No.
9900KS my home - this one, 3900X on job - is two.
For begin - only CPU, later add GPUs.
Kashtan is offline
post #8 of 14 (permalink) Old 02-04-2020, 03:32 PM
Tech Enthusiast
deafboy's Avatar
I'm confused...
So what system as you asking for advice on the radiator(s)?
The loop I'd recommend for the 9900KS would be different than the 3900x
HTPC
(10 items)
Overkill FreeNAS
(10 items)
AMD Ryzen R5 3600
nVidia Titan XP
Samsung PM981 1TB
Corsair SF600
Noctua L9i
Accelero Xtreme III
Noctua NF-A12x25s
E5-2670v1
E5-2670v1
Supermicro X9DRL-iF
6x WD Red 8TB
Corsair AX750
2x Noctua nh-u9dxi4
3x Scythe AP-30
Norco 4224
Operating System
FreeNAS
Intel 750 400GB
Intel 750 1.2TB
Samsung PM981 1TB
Corsair AX1200i
Lamptron FC-5V2
Operating System
Windows 10 Pro
Asus PG297Q
Keyboard
Leopold Otaku
Mouse
Corsair M65
Mouse
Corsair MM600
Audio
Audio
Corsair SP2500
deafboy is offline
post #9 of 14 (permalink) Old 02-04-2020, 03:40 PM - Thread Starter
Rep: 2 (Unique: 2)
I don`t understand.
Why? Question about rads.
Kashtan is offline
post #10 of 14 (permalink) Old 02-04-2020, 04:27 PM
Tech Enthusiast
deafboy's Avatar
Which one of your systems are you asking about?
HTPC
(10 items)
Overkill FreeNAS
(10 items)
AMD Ryzen R5 3600
nVidia Titan XP
Samsung PM981 1TB
Corsair SF600
Noctua L9i
Accelero Xtreme III
Noctua NF-A12x25s
E5-2670v1
E5-2670v1
Supermicro X9DRL-iF
6x WD Red 8TB
Corsair AX750
2x Noctua nh-u9dxi4
3x Scythe AP-30
Norco 4224
Operating System
FreeNAS
Intel 750 400GB
Intel 750 1.2TB
Samsung PM981 1TB
Corsair AX1200i
Lamptron FC-5V2
Operating System
Windows 10 Pro
Asus PG297Q
Keyboard
Leopold Otaku
Mouse
Corsair M65
Mouse
Corsair MM600
Audio
Audio
Corsair SP2500
deafboy is offline
