My first Open-Loop!!!! - Page 4 - Overclock.net - An Overclocking Community
post #31 of 32 (permalink) Old 02-08-2020, 01:49 PM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by skupples View Post
they do, but i'd only go that route if you're trying to pinch pennies.
I could not find another block that fit my video card's particular PCB. PCB isn't the reference or founders edition. Would have went with a "better" name brand if I could have. But to be honest. That would seem like wasted money now because I am highly impressed with the Barrow GPU block. Unless it completely craps on itself in 3 years, I would call that some of the best money I've ever saved. The highest temps I can reach in a 65f degree room is 56c under continuous load. These aren't anything that are complex, require any exotic materials or processes to manufacture. People can spend money anyway they like, but I can bet the name brand blocks are expensive mainly because of the name and all the overhead required to maintain that name.
Tony M is offline
post #32 of 32 (permalink) Old 02-08-2020, 07:35 PM
jura11's Avatar
Rep: 103 (Unique: 67)
Hi there
I have used Barrow and Bykski WB on several occasions and builds and absolutely no issues, I'm using on my build exclusively Barrow and Bykski fittings amd no issues
I habe used Bykski WB for RTX 2080Ti and temperatures have been quite good in 42-46°C region with Galax 380W BIOS, for CPU block (8700k) we have used Bykski as well and we are tested on his build like Bykski and EK Supermacy EVO and with Bykski temperatures have been around 2-4°C under load
But as above Barrow or Bykski do make waterblocks which other makers don't even make, due this only option is to use Barrow or Bykski waterblocks if you want to ru them under water and plus usually Barrow and Bykski have first GPU waterblocks on market than any other maker, I remember when RTX landed Barrow or Bykski already have blocks
Hope this helps
Thanks, Jura
jura11 is offline
