how to use biocide plus and inhibitor - Page 2 - Overclock.net - An Overclocking Community
post #11 of 51 (permalink) Old 02-11-2020, 12:53 PM - Thread Starter
HITTI's Avatar
Rep: 17 (Unique: 17)
I bought a medicine drop with measurement.
Win10 x64 Pro, Acer XB240H, Corsair Obsidian 750D Black,DEMCifilter Corsair Obsidian 750D Dust Filter Kit,Delidded i7-3770K OC'[email protected], F3-12800CL8D-8GBXM, MSI GeForce GTX 960 2GD5, ASRock Z75 Pro3, EVGA SuperNOVA 750 G2 PSU, EK-KIT L240, 2 x NF-A14-FLX Fans, 2 x NF-F12 iPPC 2000, 2 x Samsung 840 Pro 128GB RAID 0 32KB strip, WD Re WD1003FBYZ 1TB,2TB HGST/Hitachi (HUA723020ALA641), Samsung SH-S223L. Schiit Magni3 & Modi3 and V-Moda M-100 Masters.
HITTI is offline
post #12 of 51 (permalink) Old 02-11-2020, 02:17 PM
Rep: 1 (Unique: 1)
Crap...I need to test pH? argh
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Sapphire Rx 590 Nitro+ 8Gb SE
Kingston Fury HyperX
Corsair CS750M
Noctua NH-D9L
Lian Li PC-011 Dynamic
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
Logitech G402 Hyperion Fury
bkrownd is offline
post #13 of 51 (permalink) Old 02-11-2020, 02:48 PM
Just hangin' out
Arctucas's Avatar
Rep: 35 (Unique: 34)
I do not know about Mayhems, or other fancy additives.
What works, and has worked for the last ten years, for me is: distilled water and a couple drops of benzalkonium chloride. My rig sits next to a window, and sunlight shines into my bay res window. I have no issues with any growth of any kind.
Spend your money however you wish...
In no way should it be misconstrued that I do not disagree.
PC
(14 items)
9900K
eVGA Z390 DARK
eVGA RTX2080 FTW3 ULTRA
GSKILL F4-4500C19D-16GTZKKE
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
LIANG D5, XPSC DUAL BAY RESERVOIR, HEATKILLER IV PRO NICKEL, THERMOCHILL PA140.3, AEROCOOL 140MM SHARK FANS
THERMALTAKE XASER VI
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Z-5500
Arctucas is offline
post #14 of 51 (permalink) Old 02-11-2020, 11:16 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 66 (Unique: 45)
Sweet
No You don't HAVE to pH test. But if you are concerned with the fluid in your system, then pH Testing is certainly not a bad idea. Mayhem's sell strips to make it pretty easy, You just dip the strip in your fluid (I usually use the Res to dip in) for a few seconds, then pull it out and give it a minute or so to change color. Based on the color it changes, will tell you what your pH level is, if it's low or higher then the specified range, you may have an issue. If its low, its as easy as dropping a few Mayhem's Inhibitor and Biocide drops to, if its too high, its as easy as just adding some distilled water to it, then test again after the fluid has had a chance to circulate. At least this is my understanding of it. But truth be told, with the Mayhem's Plus line, I haven't had to worry about this and my loops have all been great.
That's awesome you found a situation that works for you. I appreciate your blessing for me to spend my money how I wish on a situation that works for me. God Speed sir!
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #15 of 51 (permalink) Old 02-12-2020, 02:23 PM
Just hangin' out
Arctucas's Avatar
Quote: Originally Posted by oreonutz View Post
Sweet
Was not addressing you.
Offered a simple, inexpensive, proven solution. No need to be offended.
PC
(14 items)
9900K
eVGA Z390 DARK
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Z-5500
Arctucas is offline
post #16 of 51 (permalink) Old 02-12-2020, 02:28 PM
LTSC Consiglieri
skupples's Avatar
Rep: 658 (Unique: 351)
folks always fail to realize there's more to loop health than stuff not growing in it, that's only half the battle. specially if you plan to run things for 5+ years, zero maint, etc.
but yes, there are most definitely all sorts of home brew methods that work. I would not recommend any of them to someone rebounding from a green system though.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #17 of 51 (permalink) Old 02-12-2020, 02:45 PM
Rep: 1 (Unique: 1)
My system is closed, so opening up the reservoir fill port is a bit of a pain, and removing fluid even moreso. Though fortunately I have my radiator externally mounted or I wouldn't have any access to the fill port without draining. I used X1 concentrate, but with no way to estimate the volume of the loop I just poured some concentrate in, and topped off with distilled water.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
post #18 of 51 (permalink) Old 02-12-2020, 03:48 PM
Tech Enthusiast
oreonutz's Avatar
Sorry, was being Tongue In Cheek, did not mean to exude Offense. No Offense was taken, more amused that we were given your blessing for spending our money how we wish. I was being a D**k. LOL.
Truth is, there are many solutions out there that work for people. Just because one works in one system for one person, does not necessarily mean it will work for another in a different system. So I find the one size fits all solutions to be a bit humorous.
That said, the closest thing I have personally found that has worked in my systems so far (and I don't have the same years in custom water cooling as many of you guys do on here, I just have the benefit of caring for and maintaining a lot of custom liquid cooled systems in my relatively short time in this segment) is the Mayhem's Biocide/Inhibitor Drops. They actually are not that expensive at all, $30 total for a bottle of each, and that One Purchase will maintain about 12-15 Systems or so a year, that's not bad for the price at all. If you are only Maintaining One System with 2 Liters of Fluid, well now that one purchase is enough to last you at least 5 years or more (depending on the shelf life of the drops, which is unclear to me at this time.) Either way, I don't think that could be considered expensive for the piece of mind it gives you.
Not at all knocking yours or anyone else's method though, if your method works for you, then it works for you and no one can take that from you. As I said though, there is usually not a One Size Fits all method, and I am sure there is someone this might not work well for, it just seems to be the one thing I have found that has worked in a wide ranging of climates and loops, so its one I feel comfortable promoting without worrying it bringing harm to someone's system.
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #19 of 51 (permalink) Old 02-12-2020, 03:55 PM
LTSC Consiglieri
skupples's Avatar
next time, just dilute into a gallon. too much x1 will reduce cooling potential.
X1 can definitely add up quickly, but as Oreo said. the droppers are dirt cheap.
skupples is offline
post #20 of 51 (permalink) Old 02-12-2020, 03:58 PM
Overclocker in training
ThrashZone's Avatar
Rep: 131 (Unique: 85)
Hi,
X1 doesn't evaporate near as much as distilled...
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
