how to use biocide plus and inhibitor - Page 3 - Overclock.net - An Overclocking Community
post #21 of 51 (permalink) Old 02-12-2020, 03:59 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 66 (Unique: 45)
Quote: Originally Posted by bkrownd View Post
My system is closed, so opening up the reservoir fill port is a bit of a pain, and removing fluid even moreso. Though fortunately I have my radiator externally mounted or I wouldn't have any access to the fill port without draining. I used X1 concentrate, but with no way to estimate the volume of the loop I just poured some concentrate in, and topped off with distilled water.
Well you can use that same fill port on your externally mounted radiator to dip a pH Test strip in for a few seconds to test to see if you are nice and balanced. I don't know if you have concern to think you might not be, but it definitely won't hurt. I too have a system with an externally mounted radiator, and I also had used the fill port to run my first pH Test on my loop, it worked great. In my case it was right after flushing out Pastel White Cryofuel that had fell out in my loop, worst decision I had ever made was to put colored liquid in my loop. I spent hours flushing it, and had hoped that I could run it with just distilled water for a few days before switching to Mayhem's Biocide/Inhibitor Plus, and discovered the pH was really low, finally made the decision to just clean it with Mayhem's Blitz Kit Part 2, which did a hell of a job, I ran it in my loop for 48 hours, and it cleaned out all kinds of white junk that the flush did not. Every test I have ran since that, has been right in the sweet spot for pH Balance, so for me this mix of Distilled and Mayhems Biocide/Inhibitor Plus, has been great. In late 2017 we expanded to doing Custom Loops for some of our clients who needed the extra cooling in the Pro Workstation Segment of our Business, and I have only used that same combination in those loops, and so far, 2 Years in and just under 50 Loops deep, we have not had one Coolant Related issue. If this ever changes I will definitely be on here asking advice from some of our more seasoned members, but so far this was the most recommended solution to me from this forum that I put a crap ton of further research into, and it has not failed me yet. So that's something...
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #22 of 51 (permalink) Old 02-12-2020, 04:03 PM
LTSC Consiglieri
skupples's Avatar
Rep: 658 (Unique: 351)
Quote: Originally Posted by ThrashZone View Post
Hi,
X1 doesn't evaporate near as much as distilled...
that's definitely one of the benefits of using a "coolant" over an "additive" i'm cheap, so I haven't picked up a bottle of X1 since i got my 1st set of droppers a year or two ago.
reminds me, I need to pull the beast out n top off. i tried shutting off last night, but heard the system start glugging, so i flipped it back on.
a Migraine supported by 40 GTAP15s Vs. my brain = migraine won.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #23 of 51 (permalink) Old 02-12-2020, 04:15 PM
Tech Enthusiast
oreonutz's Avatar
That Sucks man. Migraines are the frickin worst! Glad you caught the glugging when you did.
I have a few of those leak tester pumps, so I test all my Systems for leaks before I ever fill them, it comes in handy when working on so many systems and needing to be sure the loops are solid before putting in the liquid. That is the ONE problem I have noticed here in our dry Vegas Climate especially. The rate at which the Coolant Evaporates. I was convinced on my own system that I had somehow missed a leak somewhere because of how fast my coolant level in my Res was dropping. So much so that I painstakingly checked every single fitting for evidence of a leak, and when I couldn't find one, I completely drained the system, which on this crazy beast is no small feat, and then tested with 3 different Leak Testers, the last one I left on Pressurized in my system for just under 24 hours, and no pressure loss at all, so I know I don't have a leak. So I have come to expect to top off my Res Once a Month, not by a lot mind you, but still around 10 mL or so (Just Guestimating).
I guess this is the one downside to mixing with distilled on your own huh?
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #24 of 51 (permalink) Old 02-13-2020, 12:20 PM
hahler2's Avatar
Rep: 0
I just received my biocide plus and inhibitor plus. Just getting ready to start building my cpu loop. Do I need to premix the drops and the distilled water, or can I fill with distilled water, check for leaks, and then add the biocide and inhibitor directly to the reservoir? I'm thinking for a single 360 rad, pump/res and cpu block that 3 to 4 drops of each should be enough.
hahler2 is offline
post #25 of 51 (permalink) Old 02-13-2020, 12:33 PM
Shawnb99's Avatar
Rep: 48 (Unique: 31)
Add it to the loop once at the end. Once everything is running fine then start checking PH and adding as much as needed
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #26 of 51 (permalink) Old 02-13-2020, 12:48 PM
hahler2's Avatar
Rep: 0
I don't have any PH strips. I'll have to order some. But the rest sounds good. Thanks.
hahler2 is offline
post #27 of 51 (permalink) Old 02-13-2020, 05:17 PM - Thread Starter
HITTI's Avatar
Rep: 17 (Unique: 17)
Name:	Screenshot_20200213-181655_Chrome Beta_1581639429567.png
Win10 x64 Pro, Acer XB240H, Corsair Obsidian 750D Black,DEMCifilter Corsair Obsidian 750D Dust Filter Kit,Delidded i7-3770K OC'[email protected], F3-12800CL8D-8GBXM, MSI GeForce GTX 960 2GD5, ASRock Z75 Pro3, EVGA SuperNOVA 750 G2 PSU, EK-KIT L240, 2 x NF-A14-FLX Fans, 2 x NF-F12 iPPC 2000, 2 x Samsung 840 Pro 128GB RAID 0 32KB strip, WD Re WD1003FBYZ 1TB,2TB HGST/Hitachi (HUA723020ALA641), Samsung SH-S223L. Schiit Magni3 & Modi3 and V-Moda M-100 Masters.
HITTI is offline
post #28 of 51 (permalink) Old 02-13-2020, 05:24 PM
LTSC Consiglieri
skupples's Avatar
yep.
I wonder if the incoming replacement for the droppers takes evap into account.
skupples is offline
post #29 of 51 (permalink) Old 02-13-2020, 05:49 PM - Thread Starter
HITTI's Avatar
mayhem's website I cannot find pH test strips.
HITTI is offline
post #30 of 51 (permalink) Old 02-13-2020, 05:54 PM
LTSC Consiglieri
skupples's Avatar
do you have a pool store near by? best place.
second best place, hardware store.
try to get ones that come in a resealable bottle, and check the exp date.
or ofc, just amazon everything until we're all property of Bezos, that works too. This planet will surely be named Bezearth in no time at this rate. lol
skupples is offline
