how to use biocide plus and inhibitor - Overclock.net - An Overclocking Community
post #1 of 51 (permalink) Old 02-09-2020, 01:14 AM - Thread Starter
HITTI's Avatar
Rep: 17 (Unique: 17)
mayhems how to use biocide plus and inhibitor?
I haven't ordered it or used it but how does the mix ratio work for a 900 mL of water?
Win10 x64 Pro, Acer XB240H, Corsair Obsidian 750D Black,DEMCifilter Corsair Obsidian 750D Dust Filter Kit,Delidded i7-3770K OC'[email protected], F3-12800CL8D-8GBXM, MSI GeForce GTX 960 2GD5, ASRock Z75 Pro3, EVGA SuperNOVA 750 G2 PSU, EK-KIT L240, 2 x NF-A14-FLX Fans, 2 x NF-F12 iPPC 2000, 2 x Samsung 840 Pro 128GB RAID 0 32KB strip, WD Re WD1003FBYZ 1TB,2TB HGST/Hitachi (HUA723020ALA641), Samsung SH-S223L. Schiit Magni3 & Modi3 and V-Moda M-100 Masters.
HITTI is offline
post #2 of 51 (permalink) Old 02-09-2020, 01:43 AM
Tech Enthusiast
oreonutz's Avatar
Rep: 66 (Unique: 45)
So Mayhems Biocide Plus and Inhibitor Plus is the best on the Market in my opinion.
You do mix it into Distilled water, however no, not at the rate you are used to.
It is a 0.05% Mix. This Means for Every 1000mL you want to use exactly 0.5mL of each. This means the entire 15mL Bottle will treat 30 Liters of Coolant.
Most people resort to just mixing in anywhere between 5 to 10 Drops of each when first filling their system (Obviously depending on the amount of liquid it takes to fill your system) and then top it off with just a few drops of each every few months.
But if you want to be precise, you should get yourself a medicine dropper. Fill up an Entire 1000mL Bottle with pure distilled water. Then Use the Medicine dropper to measure exactly .5mL (To be clear that is HALF of a mL) of the Biocide Plus and Put that in your 1000mL of water, and then repeat with the same exact amount of Inhibitor Plus. Then Fill your Loop, and you are good to go. Every 3 to 6 Months, top it off with just a few drops of each, and thats all you have to do!
Hope this helps. BTW here is the Link to the product on Mayhem's Own Website, this explains very clearly the mixture rate if you would like an official source.
https://www.mayhems.net/products/mayhems-biocide-15ml
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #3 of 51 (permalink) Old 02-09-2020, 05:33 AM - Thread Starter
HITTI's Avatar
that helps a lot. I ordered both and a dropper.
HITTI is offline
post #4 of 51 (permalink) Old 02-09-2020, 08:57 AM
Rep: 0
This should be fixed.
Always a pain, to get the right mixes...and products.
Thank you!
Mordorr is offline
post #5 of 51 (permalink) Old 02-09-2020, 09:02 AM
Overclocker in training
ThrashZone's Avatar
Rep: 129 (Unique: 85)
Hi,
Just need some good ph strips in a sealed bag or bottle
Go to a pool supply store locally sure they have even better test devices.
Did eventually read inhibitor effects ph more than biocide but add both equally.
Between 7-8 ph is good not lower than 7 though.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #6 of 51 (permalink) Old 02-09-2020, 01:43 PM
Rep: 0
@oreonutz thank you for the great explanation, I've also been looking for some information on this topic!
Asunder is offline
post #7 of 51 (permalink) Old 02-09-2020, 04:25 PM
Tech Enthusiast
oreonutz's Avatar
Thank you!
No Problem! Glad to help!
Quote: Originally Posted by ThrashZone View Post
Hi,
Yup, Thrash makes a good point. Although you should be fine by just using the drops as described, to be 100 percent sure your mix is right, its good to Test with a Ph Test Strip to make sure your Ph balance in your loop is correct. I am no where close to an expert on this aspect, so probably want to do more research on this if interested, but I do know that between 7-8 on the test strips as @ThrashZone Mentioned is the sweet spot.
Using the Inhibitor as described, with the Biocide and pure distilled should get you there though, unless you have some contamination in your loop that is affecting your balance.
I do know that in every system I have used this mixture in, every single one has tested between 7-8 on the Strips, so as long as you mix properly, you shouldn't have an issue. Its more for a few months down the road when you want to make sure your pH levels are still good, use a test strip then, if they are lower then 7 thats when you want to add a bit of both drops to the mix to get it back up. (At least that is my understanding.)
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #8 of 51 (permalink) Old 02-11-2020, 12:37 AM
xenolith's Avatar
Rep: 6 (Unique: 6)
1. What's the difference between Mayhems Biocide Plus and Mayhems Biocide Extreme?
2. If Biocide Extreme is more effective at killing and preventing bio-growths, can it be used with Mayhems Inhibitor as well?
3. Would it be a bad idea to add a silver coil to the mix as an everything-but-the-kitchen-sink strategy to help keep all those bio-growth baddies away. I just spent the last three days cleaning out a bunch of green sludge, slime, and scale out of a big 360 radiator. I hope to never have to do that again.
thanks
xenolith is offline
post #9 of 51 (permalink) Old 02-11-2020, 02:55 AM
Tech Enthusiast
oreonutz's Avatar
thanks
Mayhem's Biocide Extreme is an older product, that isn't as effective as Mayhem's Biocide Plus. It contains Copper Sulphate so I would not mix it with the newer "Plus" line of products from Mayhems.
Using Mayhem's Biocide Plus Should be more than enough to keep that nasty crap from growing in your loop again, just make sure to use the right concentrate, you can even though in an extra drop or 2 if you want.
I am pretty sure Biocide Extreme is not compatible with Inhibitor Plus. But Biocide Plus and Inhibitor Plus were made to be used together with Distilled water to be the ultimate solution.
I have never used a silver Kill coil, so I can not advise you one way or the other there. I am maintaining multiple loops right now, over the past several years, and in all of them I use only Distilled Water and Biocide Plus and Inhibitor Plus. I just my yearly flush on 2 of my clients systems, and checked the GPU and CPU Blocks, and they look just as clean as they did on day one, it looks like the flush was completely unnecessary, but its better to be safe then sorry.
As I have never used one, I can't speak to Mayhem's Plus line's Compatibility with them, but I am pretty sure as long as you use the correct mix in your loop, its unnecessary. Good Luck!
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #10 of 51 (permalink) Old 02-11-2020, 05:01 AM
LTSC Consiglieri
skupples's Avatar
Rep: 649 (Unique: 349)
biocide extreme is old. n the + series is about to get replaced as well, for a unified option.
silver has been, and always will be a garbage solution. biocide isn't copper sulphate, or silver based, cuz both copper and silver as terrible solutions. not to mention, copper parts create copper sulphate. there is literally zero reason to be using a kill coil, with or without mayhem's stuff. it's an old bro's tail. YES, silver kills some stuff in your water, but that single coil isn't actually very effective for it
controlling your loop really isn't all that difficult. get the + series, add a squirt of both into each liter of water, win. add a couple drops every couple months, keep winning.
winning = blocks should come out looking essentially new, years later.
green slime and gunk?
you 100% need to start with a Blitz Kit. FOLLOW DIRECTIONS, BE PATIENT.
then refill with mayhems' pre-mix X1 or biocide+/inhibitor+
come back and thank us.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
