new to glass tubing - Overclock.net - An Overclocking Community
new to glass tubing
post #1 of 5 (permalink) Old 02-09-2020, 06:39 PM - Thread Starter
holeyguy's Avatar
Rep: 1 (Unique: 1)
new to glass tubing
i know its here just dont have the time to search through the threads. i have always wanted to do a hard line loop. but have never been brave enought to try petg. so i decided to be brave enough and go glass. been using soft tube since ive done liquid loops and am new to the fittings and how they work. ive got 13mm mayhams tub and 13mm alpha cool fittings. what im confused about is the fit. with soft it has a barb you slide the tube over then the compression collar. i noticed when i put the glass tube in one of the alphacool fittings it wasnt a snug fit. keep in mind the system isnt being built yet so i just took the tube and put the end on the fitting and tightened it down.
i guess what im asking is are there fitting specifically for glass or are they all for hard tubing. also any help understanding these installs will be greatly helpful and appreciated. all ive found on youtube was how to cut and basic install not in depth how to
holeyguy is offline
post #2 of 5 (permalink) Old 02-10-2020, 09:44 PM
Bartdude's Avatar
Rep: 3 (Unique: 2)
Hi, if the fittings are designed for hard tube then they should work fine with glass.
"No s*** lady, does it sound like I'm ordering pizza!"
Corsair 900D
(29 items)
Intel E4790k Haswell
Asus ROG Maximus VII Watchdogs
EVGA 1080 SC Gaming
Corsair Dominator Platinum
Samsung SSD
Samsung SSD
Samsung SSD
Optical Drive
LG Blu Ray Rewriter
Corsiar AX1200i
EK XTOP Revo Duel D5
2X EK Radiator 360 PE
EK Supremacy EVO
EK 1080 Full Cover Waterblock
Aquero 6 XT
Aquero MPS 400 Flow Sensor
9X Gentle Typhoon Fans
Aquacomputer Hubby7
4x Aquacomputer Splitty9
Aquacomputer Poweradjust USB 3 Ultra Version
Corsiar 900D
Operating System
Win 10 Pro 64
Asus ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor
Keyboard
Razer Blackwidow Soft Touch
Keyboard
Razor Orbweaver
Mouse
Razer Deathadder 3500DPI
Mouse
Razer Mouse Mat
Audio
Sound Blaster X-Fi Titanium Fatal1ty Champion Series
Audio
Yamaha RX-V381 5.1 Channel Receiver Amplifier
Audio
Tannoy 5.1 Speakers
Bartdude is offline
post #3 of 5 (permalink) Old 02-10-2020, 10:23 PM
munternet's Avatar
Rep: 16 (Unique: 9)
Measure the glass with a vernier to check for exact size. Some imperial sizes are 0.5 m/m different to their metric equivalents
13m/m might be 1/2 inch (12.7 m/m) and that size O-Ring might only be designed to have 0.3 m/m crush a side.
Edit: Why glass? Surely the risks are higher with cracking and not being as flexible?
Intel Memory Overclocking Quick Reference https://www.overclock.net/forum/27784556-post7836.html
9900ks
Asus Maximus XI Gene
EVGA 1080 Ti Superclock 2 Black
F4-4400C19D-16GTZSW
Samsung M.2 1TB 970 EVO Plus
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 1 x 360mm and 1 x 420mm Radiators and Vardar Furious Fans
ThermalTake V51
Operating System
Windows 10 Pro
Asus PG349Q 34.1 inches 3440 x 1440 pixels @ 120 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000x500x3
Audio
Steelseries Siberia800 wireless Headset
8700k @ 5.2ghZ
Maximus X Hero
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Asus Maximus VII Ranger
Gigabyte NVIDIA GeForce GTX980
G.SKILL Trident X 16GB 2 x 8GB 2400 Memory F3-2400C10D-16GTX
Seagate Barracuda 2TB
Optical Drive
LG DVD Rom
PSU Coolermaster V1000W
Custom Loop
Case Thermaltake V51 Full Window
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Thermaltake Poseidon Z
Mouse
Logitech G602
munternet is offline
post #4 of 5 (permalink) Old 02-11-2020, 06:39 PM - Thread Starter
holeyguy's Avatar
Rep: 1 (Unique: 1)
just decided to go outside the box. and from what ive seen on countless how-to cut videos glass is a bit stronger in regards to cracking when you cut the pieces. if it goes bad ive got petg to fall back on since ive read to build the loop with petg first to get the exact lengths. and yes when i converted it to imperial its 1/2 od x 3/8 id ive used 1/2x3/8 soft tubing in every build ive done so i decided to stay in that range.
holeyguy is offline
post #5 of 5 (permalink) Old 02-11-2020, 07:14 PM
munternet's Avatar
Rep: 16 (Unique: 9)
The material I used in my loop, petg I assume, is nearly impossible to crack, looks like glass and has lasted very well so I'm not sure what you mean?
9900ks
F4-4400C19D-16GTZSW
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Pro
Keyboard
Mouse
Mouse
Mousepad
1000x500x3
Audio
8700k @ 5.2ghZ
Maximus X Hero
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Optical Drive
LG DVD Rom
Custom Loop
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Mouse
Logitech G602
