PC-O11N, vertical GPU, and bottom rad/fans? - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 02-11-2020, 10:11 AM - Thread Starter
Old school cool
Rep: 0
Hey all -
I am pretty far into what I thought was a well-planned water build. I am using EK-Quantum Velocity block for CPU, EK-Quantum Velocity Trio 2080ti for my MSI Gaming X Trio 2080ti, and picked out Corsair XR5 360mm radiators because they're not overly thick so the QL120 fans will work well but I wanted 2 radiators for appearance and cooling capacity. I went with a Radikult PC-O11N distribution reservoir and took a PTO day yesterday to start building everything out. Then I found out the GPU waterblock doesn't fit within the case when mounted horizontally. Next I found out that if I get a vertical GPU bracket they appear to interfere with the lower radiator/fans of the PC-O11N.
Sigh.
I ordered a Coolermaster vertical GPU bracket with hopes to either A) not have to modify it B) modify it to fit my card vertically while still allowing the bottom radiator and fans. Has anyone done this or does anyone have another GPU bracket that definitely works in a PC-O11N case?
Thanks all!
Attached a pic of where I am at so far! I haven't flushed the lines yet, just test fitting.
5mall5nail5 is offline
Tags
pc-o11n
