Issues with Conductonaut - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 02-11-2020, 08:37 PM - Thread Starter
sultanofswing's Avatar
Rep: 0
Figured I would put this here since it is in a water cooled system.
So on all my watercooled Builds I use Liquid Metal on the GPU as it usually gives me the best results. I ran a 1080ti on a EK Full cover block for 2 years without any single issues with the Liquid Metal itself(Conductonaut).
My setup now is a 2080ti on a Heatkiller Nickel plated block and I am seeing some weird things happening with the liquid metal.
I initially put the block on with liquid metal and temps were great I was happy. I wanted to flash some Bios's to the card but since my card is a 2019 version all the old Bios files don't work, so I pulled the card back out and used my CH341A Programmer to program the BIOS chip.
I cleaned the Liquid metal off, applied a new layer and off I went. Card ran 5-6c hotter than it did before even with the same settings with the new bios. Tore card back apart and the LM application was fine but I noticed something strange.
The top of the die had what appeared to be hard pieces of metal stuck to the silicon. I had to use a credit card to pick the pieces off they were stuck to the die pretty good.
Got all that cleaned off and felt like I didn't want to deal with the LM again and just used Kryonaut.
Put card back together and temps were fine but I couldn't keep it below my target of 40c like it was with LM.
Again card came back apart, Applied LM and temps were back to normal. About a week later I started noticing temps were slowly creeping up past when I first installed, Pulled the card back apart and found the same pieces of hard metal stuck to the die.
So here I sit now, back on Kryonaut as I am not sure what the issue is with the LM. Maybe a bad batch of it? At any rate sorry for the long read hopefully someone has possibly ran into this issue before?
sultanofswing is offline
post #2 of 3 (permalink) Old 02-11-2020, 08:54 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 611 (Unique: 504)
Get Coollaboratory Liquid Ultra.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #3 of 3 (permalink) Old 02-11-2020, 08:59 PM
Falkentyne's Avatar
Rep: 425 (Unique: 296)
If that is nickel plated copper (AND NOT NICKEL PLATED ALUMINUM), then grab some 1500 grit sandpaper and roughen up the surface with about 40 strokes of the 1500 grit so it isn't perfectly smooth.
After you're done, wipe the surface with 91% alcohol and a microfiber cloth, then apply 1/4th of a size of a grain of rice of liquid metal onto the heat block, then spend about 15 minutes wiping it around the area of the heat block that will contact the die. Keep spreading and wiping it around even if it's already fully spread--just keep wiping it. DO NOT apply downwards force. Just wipe it and spread it normally.
After about 10 minutes or so, you will start noticing that the liquid metal stops feeling so 'liquid' and starts feeling more paste-like (but a very thin paste like). This is your cue you're getting somewhere.
After about 15 minutes, apply a new same sized drop on top of the old layer and just wipe it around fast. This should be very fast and shouldn't take more than a minute.
Then apply a very small dab to the silicon and wipe it around there like normal.
Then mount.
Report the long term stability later.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Falkentyne is offline
