Question about soft tubing - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 02-12-2020, 04:36 PM - Thread Starter
bigfootnz's Avatar
Rep: 1 (Unique: 1)
I need to replace my VGA, and swap VGA block. My question, as I could not find it anywhere, is there any recommendation how many time I can remove and put it back soft tubing (ZMT)on compression fitting. Current ZMT is just like 6 months old and I would not like to replace it already, but again I do not want to have any leeks. Thanks
Intel Rig
(14 items)
Ryzen Rig
(10 items)
Gigabyte Z390 AORUS MASTER
Gigabyte RTX 2080 Windforce
G.SKILL Trident Z Neo RGB F4-3600C16D-16GTZN x 2
Intel SSD 660P 3D2 QLC 1TB M.2 2280 NVMe x 2
Adata XPG Series SX8200 Pro SSD, 1TB, M.2 (2280), PCIe 3.0 x4, 3D TLC NAND
Corsair RM850i
EK-Supremacy MX
EK-Vector RTX RE - Copper + Plexi & EK-Vector RTX Backplate - Black
EK-CoolStream XE 360 (Triple)
EK-CoolStream PE 360 (Triple)
EK-XRES 140 Revo D5 PWM (incl. pump)
Phanteks Eclipse P600S Anthracite Grey
Dell P2418D
AMD Ryzen 9 3900X
Asus ROG CROSSHAIR VI HERO
Gigabyte GeForce RTX 2070 Windforce 8G Gaming
G.SKILL Trident Z RGB F4-3600C16D-16GTZR 16GB (2 x 8GB) DDR4 3600Mhz CL16 x 2
Adata XPG Series SX8200 SSD, 960GB, M.2 (2280), PCIe 3.0 x4
Samsung 860 QVO MZ-76Q2T0BW 2TB x 2
Corsair RM 850i
Corsair Hydro Series H150i Pro RGB AIO Liquid CPU Cooler 360mm Radiator
Fractal Design Meshify Series C Mid Tower Case
Operating System
Windows 10 Pro
bigfootnz is offline
post #2 of 9 (permalink) Old 02-12-2020, 04:38 PM
Overclocker in training
ThrashZone's Avatar
Rep: 129 (Unique: 85)
Hi,
Usually only if it's loose.
You should have plenty of slack anyway it is soft tubing not hard
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #3 of 9 (permalink) Old 02-12-2020, 04:41 PM - Thread Starter
bigfootnz's Avatar
Rep: 1 (Unique: 1)
Yes, there is some slack but not sure will be able to replace block with tubing, but I'll try that first.
You are saying, that it will leak only if it is tubing is loose on fitting?
Intel Rig
(14 items)
Ryzen Rig
(10 items)
Corsair RM850i
EK-Supremacy MX
Dell P2418D
AMD Ryzen 9 3900X
Corsair RM 850i
Operating System
Windows 10 Pro
post #4 of 9 (permalink) Old 02-12-2020, 04:43 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 66 (Unique: 45)
Yup. ZMT is good stuff. You can continue to reuse that for a long while. Just check to make sure there are no cuts on it from over tightening, and that your o-ring is still in good shape. As long as your tubing is still tough (not super soft so that it just slides off the barb/fitting) and there are no cuts from over tightening, and the o-ring on the fitting is still in good shape, you are good to reuse. And if there is some kind of cut in the tubing from over tightening, then just cut the tube past that cut, and you are good to reuse anyway.
Good Luck!
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #5 of 9 (permalink) Old 02-12-2020, 04:44 PM
ThrashZone's Avatar
Hi,
Once the cap is back on no it shouldn't leak.
Only test i know of is install as normally would and pull a little
If the hose comes off yeah cut it
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #6 of 9 (permalink) Old 02-12-2020, 04:47 PM - Thread Starter
bigfootnz's Avatar
Rep: 1 (Unique: 1)
Thanks
Intel Rig
(14 items)
Ryzen Rig
(10 items)
Corsair RM850i
EK-Supremacy MX
Dell P2418D
AMD Ryzen 9 3900X
Corsair RM 850i
Operating System
Windows 10 Pro
post #7 of 9 (permalink) Old 02-12-2020, 05:45 PM
ThrashZone's Avatar
Hi,
Fittings hold up pretty well if you wet the o-ring before tightening.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #8 of 9 (permalink) Old 02-12-2020, 05:52 PM
Tetrapyloctomist
Aenra's Avatar
Rep: 44 (Unique: 27)
@bigfootnz it's always good practice to:
i) leave a few centimeters of extra length; if its end point had been loose/softer, right now? All you'd need is your cutter, shave off said extra few cms and you'd be good to go again
If on the contrary you've cut it just so, you'd have had to replace it altogether now.
(and barring circumstances that shouldn't be occuring [excess in-case temperatures, coolant constantly on very high temps, etc.], that's pretty much your one and only wear and tear point)
ii) buy more tubing prior to setting your rig up and count the length of each cut piece, which you then write down; that way you know both your total and your individual pieces' lengths.
(if you don't change chassis every time you change componenents, this is a time and trouble saver)
iii) have extra tubing in advance and/or don't be stingy where you shouldn't; if, hypothetically speaking, you bent close to swap that GPU you mention, swapped its tubing too yeah? And with the new one in, you noticed a change in coloration? Between old and new tubing? Replace the rest of it; all of it. Day(s) of waiting for its being shipped, vs having that surplus in your back yard storage.
(and if storing it, which again, you should, keep it somewhere cool, definitely no direct sun exposure; doesn't go bad with time if stored rightly)
Pride, honour and purity.
Aenra is offline
post #9 of 9 (permalink) Old 02-13-2020, 07:57 PM - Thread Starter
bigfootnz's Avatar
Rep: 1 (Unique: 1)
Thanks for advice. I've plenty spare ZMT tubing and some PrimoChill PrimoFlex LRT and DuraClear stored properly.
Intel Rig
(14 items)
Ryzen Rig
(10 items)
Corsair RM850i
EK-Supremacy MX
Dell P2418D
AMD Ryzen 9 3900X
Corsair RM 850i
Operating System
Windows 10 Pro
