Pump search - Overclock.net - An Overclocking Community
Pump search
post #1 of 2 (permalink) Old 02-21-2020, 01:44 PM - Thread Starter
Rep: 0
Pump search
I'm working on a project where I would like to use a USB pump and was wondering if anyone had some leads. What I am hoping to do is use the USB power when the system is turned on to turn on\power an external pump...Alternatively a way to turn on\off the pump via USB...
This is for a large one of project which will have several pumps in play and not have to push volume too far\hard...
any suggestions?
AFisher is offline
post #2 of 2 (permalink) Old 03-01-2020, 02:04 AM
treetops422's Avatar
Rep: 22 (Unique: 16)
any suggestions?
I use two aquarium pumps, 10-20$ each. I manually plug and unplug my pumps from the wall ^^ atm. take note that my external USB fan is always on, if my computer has power even while off. So USB pumps will not turn off when you power down your computer. (maybe you can change that via bios)
You can get DC pumps with a converter. You can get PSU 4 pin connector pump. (4 pin will turn off with your computer) You can get a usb to 4 pin connector converter. You can plug in your power strip into a light switch type deal. Ebay n amazon have it all.
Of my two pumps I like this one, it does not need water in the tubes to start pumping. I bought a adapter from home depot to make it fit my tubes.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Brass barb for the water pump $4 Home Depot
Sapphire Radeon RX 5700 Non XT Boost Core 2035 Gaming Ram 960 43c Air Water Hybrid Cardboard Blower with a 20$ chinese Waterblock on the core 50 gallon tote of water, Ryzen 3700x 4.25 ghz, 15$ chinese waterblock, same tote 3200 ddr3 cl16 Team T-FORCE VULCAN TUF , B450m Asrock Pro 4 Mobo, 700 Watt OCZ PSU.
treetops422 is offline
