Dual Pump - Overclock.net - An Overclocking Community
Dual Pump
post #1 of 73 (permalink) Old 02-22-2020, 03:11 AM - Thread Starter
Pepillo's Avatar
Rep: 4 (Unique: 4)
Dual Pump
I recently assembled this build:
I've been reading this article, I've had an idea and I'd like opinions. In the article they are assembled in series two different pumps, a D5 and a DDC (the output from one to the inlet of another) working perfectly, doubling the pressure and getting 30% more flow. But what I value most is that if a pump breaks, the circuit continues to run, you get redundancy of failures:
https://martinsliquidlab.wordpress.c...vs-parallel/2/
The thing is, I have the D5 of my previous build in a box, and I've thought about taking advantage of it. If you look at this picture:
It doesn't seem at all complicated to mount the D5 with a bracket and a top on that fan, unplug the output from the DDC that goes to the VGA and connect it to the input of the D5, and it's to the VGA.
What do you think, considering that I don't have to make the expense to buy the extra pump, I already have it?
Thanks
Lian Li O11 Dynamic XL + EK O11D Distro-Plate G1 DDC 3.2 + 2x360 EK Radiators - Aorus RTX 2080 TI Fullcover [email protected]/15000 - EVGA Supernova 1600 - Corsair K95 + Dark Core SE/MM1000 - X27P 4K HDR1000 Gsync 144 Hz - Lenovo Explorer
Asus Prime X299 Deluxe - i9 [email protected]/3.2 Delid - 4x8 G.SKILL RipjawsV [email protected] C17 1T - Intel Optane 900P NVME - Crucial MX300 2TB - Samsung EVO 860 4TB + Optane 32GB - 2X2TB WD Raid - DAC Teac UD H01 + AKG K612 Pro + 2.1 Studio
Pepillo is offline
post #2 of 73 (permalink) Old 02-22-2020, 05:37 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
Don't mix pumps
2-D5's yes.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 73 (permalink) Old 02-22-2020, 08:17 AM
toolmaker03's Avatar
Rep: 95 (Unique: 72)
I do not suggest mixing pumps, but in this case after looking over your loop, I do not see that hurting this loop. so for redundancy it will provide that, as for increasing you total flow rate? it should increase that, at least by a little.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #4 of 73 (permalink) Old 02-22-2020, 09:10 AM - Thread Starter
Pepillo's Avatar
Rep: 4 (Unique: 4)
Quote: Originally Posted by ThrashZone View Post
Hi,
Don't mix pumps
2-D5's yes.
Two D5 is not an option, the distro plate use only DDC. Two DDC is it posible, but I alredy have one D5 and one DDC .........
Thanks for your input.
Pepillo is offline
post #5 of 73 (permalink) Old 02-22-2020, 09:41 AM
u broke 666 rep :(
skupples's Avatar
Rep: 681 (Unique: 361)
seems like a terrible idea to mismatch pumps. A.) you'd hear speed wobbles ALL the time, even after trying to sync them.
MCP35x2 is $200 for 2x PWM high speed DDCs, and the second one does much better than 30% added flow. (they also last a decade)
if you do go forward with the D5, don't put them next to each other in serial. put anywhere else in the loop. you're already losing the perf. bonus of not having a serial top on identical pumps, thus why the added flow is so low in dude's testing. My 2nd pump nearly doubles my flow potential
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #6 of 73 (permalink) Old 02-22-2020, 09:50 AM
ThrashZone's Avatar
Hi,
Costly but easy dump the distro plate
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #7 of 73 (permalink) Old 02-22-2020, 10:15 AM
u broke 666 rep :(
skupples's Avatar
but muh a e s t h e t i c
they seem like a pita to work with due to the limited water volume. am I mistaken? Once i'm done putting everything together, the last thing i wanna do is fight glugging and air sucking pumps. (bet most distro pumps will live shorter lives due to all the air they likely pull during fill)
and how do you prevent back flow when cutting power? (normal tube res have a down spout)
skupples is offline
post #8 of 73 (permalink) Old 02-22-2020, 10:18 AM
ThrashZone's Avatar
Hi,
Doesn't even have enough power to get the bubbles out
Some distro plates are compatible with D5 pumps you just didn't get one.
Get two D5's one with reservoir combo and one D5 top and unplug the cheapo pump on the distro and it will just be a pass through thing.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #9 of 73 (permalink) Old 02-22-2020, 10:23 AM
u broke 666 rep :(
skupples's Avatar
dual d5 is pricey man. that MCP35x2 is the lifetime value KING! half the price, n only a bit louder on full tilt, which you don't really need cuz dual pumps.
@30%x2 i maintain well over 2gpm thru 4 radiators, n cpu. Each GPU chops about .5 off of that.
skupples is offline
post #10 of 73 (permalink) Old 02-22-2020, 10:27 AM
NewUser16's Avatar
Rep: 53 (Unique: 36)
I've heard somewhere from supplier whey back few years ago that if you run 2 pumps at even slightly different speeds, one or the other could fail prematurely, let alone mixing 2 differently operating pumps.
NewUser16 is offline
