Which fans for radiator - Overclock.net - An Overclocking Community
post #1 of 35 (permalink) Old 02-22-2020, 11:21 AM - Thread Starter
El Media Vida's Avatar
Rep: 1 (Unique: 1)
Hi guys,
I have all my parts for my custom loop, only I need choose the fans to build the loop. I want a nice static presure and quiet fans, I don't care if they have or not rgb, only I want the best fans for a good price. I know the best option are the NF-A12x25PWM but on my country the price are $32.5 each with taxes.
I saw the Corsair ML120 Pro (CO-9050040-WW) for $25 with taxes.
Or which one do you recommend me?
My radiator it's a Black Ice Nemesis.
Thanks!
El Media Vida is offline
post #2 of 35 (permalink) Old 02-22-2020, 11:43 AM
The last VRM burner
Rep: 44 (Unique: 27)
Might want to look at charts made by der8auer.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #3 of 35 (permalink) Old 02-22-2020, 11:44 AM
Rep: 2 (Unique: 2)
Personally using Corsair LL140s for unicorn spotting. Function wise. As you mentioned, Noctua would be my first stop. After that I would consider BeQuiet silent wing 3. Corsair MLs though I have only used them in 140mm.
I would approach it like this. Write a list of the 10 fans you can actually afford. Go into each one and see what you find in reviews. It's what I do. Once I am settled in a top 3 then decide based on what I can get and for what price. For example, I'd wait until there is a bank holiday or start tracking the price using price spy or something. There are discounts here and there all year round.
Sent from my SM-G975F using Tapatalk
bhoot is offline
post #4 of 35 (permalink) Old 02-22-2020, 11:53 AM
toolmaker03's Avatar
Rep: 95 (Unique: 72)
Quote: Originally Posted by El Media Vida View Post
Hi guys,
Thanks!
well I have two 240mm, a 360mm, and a 480mm hardware labs BIN radiators. in a case these radiators really need 3000RPM fans attached to them to actually work. the noctua IPPC 3000RPM fans or any other static pressure 3000RPM + fan should work fine.
I like this video because he installed slow quite fans at fist, than installed 3000RPM fans later.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #5 of 35 (permalink) Old 02-22-2020, 12:25 PM
poah's Avatar
Rep: 7 (Unique: 6)
Arctic P12s
poah is offline
post #6 of 35 (permalink) Old 02-22-2020, 02:26 PM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by BroadPwns View Post
https://www.youtube.com/watch?v=7cGdQi7LqlU&t=290s
Thank you, the video have the fans that I want buy with exception ML, but a great video.
Nice technike, the previous post video have the list of the fans that I want buy.
https://www.youtube.com/watch?v=ZpKY2hY5Nh8
The problem with that fans are to much expensive, I want a config with 240+360 but with that fans I will spend more on fans than entry loop haha
Quote: Originally Posted by poah View Post
Arctic P12s
Yep, I decided, I will buy that one's, any suggest for ruberpads?
post #7 of 35 (permalink) Old 02-22-2020, 02:33 PM
the point was having fans capable of 3000RPM's or better for those radiators.
https://www.amazon.com/dp/B001JKNMBE...ding=UTF8&th=1
Scythe UltraKaze 120mm CaseFan, High Static Pressure, 3-Pin 3000RPM fans work great without breaking the bank.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #8 of 35 (permalink) Old 02-22-2020, 02:48 PM
The last VRM burner
I use P12s PWM on my case and radiator, there is literally no need for rubber pads or any other kind of dampeners. The only noise made is from blades slashing the air, a low frequency hum that starts getting heard (not annoying, just heard) at around 1200-1300RPM.
PC for all
(21 items)
Iris Pro 6200
Corsair MP510
Samsung Evo 860
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
post #9 of 35 (permalink) Old 02-22-2020, 03:07 PM
Rep: 2 (Unique: 2)
Never used fan standoffs before. Find the standard fan rubber corners are enough. If you really want some dampening then just buy some fan dampening material and cut it out yourself and stick it on. Did this when one I went militant on 2 innocent 120mm Phantek fans. I never apologised to that noisy mofos.
bhoot is offline
post #10 of 35 (permalink) Old 02-22-2020, 05:41 PM
apw63's Avatar
Rep: 65 (Unique: 56)
JayzTwoCents video from April 1st April fools wonder if anything in that video is a joke.
My System
ASUS ROG Swift PG278Q Owner's club
Asus Maximus XI Formula, 8700K, Corsair Dominator Platinum ROC 3200 16GbB, Asus ROC STRIX 1080 Ti OC version.
apw63 is online now
