Maingear Vybe + Apex ICS radiator size compatibility Q - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 02-22-2020, 09:50 PM - Thread Starter
Not New to Overclock.net
scatlm's Avatar
Rep: 29 (Unique: 25)
Hi OCN,
Can anyone tell me if I can use 46mm or even 60mm thick radiators in the front of the Maingear Vybe with the shorter Vybe Apex ICS pump/reservoir installed?
Thank you, kindly.
scatlm is offline
post #2 of 2 (permalink) Old 02-27-2020, 11:03 PM - Thread Starter
scatlm's Avatar
BTW, if anyone's looking to build a system using a Maingear Vybe chassis and the Maingear Apex ICS: you have to use slim radiators (as per Maingear CS.) Also, in terms of length, they only recommend 240's on the top and front, however, you can get a 360 in the front but maintenance will not be very convenient.
scatlm is offline
