So confused about CLC - Overclock.net - An Overclocking Community
post #1 of 43 (permalink) Old 02-23-2020, 08:08 PM - Thread Starter
Rep: 0
I have a Gigabite 570 Master M/B, Ryzen 9 3900,G Skill Trident Z neo 3600 16GBX4 CL16 ram, RTX 2070 SUPER, Samsung 970EVO Plus 1TB. Corsair AX1200, Cool Master Cosmos case. I would like to overclocking it also. So far this is what I have. I need a water cooler that is refillable and that will work. And one that moves some good air not to worried about noise. PLEASE HELP Thanx
Baddodge is offline
post #2 of 43 (permalink) Old 02-23-2020, 08:33 PM
toolmaker03's Avatar
Rep: 95 (Unique: 72)
https://www.performance-pcs.com/wate...-cpupkam4.html
https://www.performance-pcs.com/wate...-wckmg360.html
I like the bitspower kits, this one will need the intel plate on the CPU water block switched out for the AMD plate above, so that it is compatible with your CPU.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #3 of 43 (permalink) Old 02-23-2020, 08:38 PM
The last VRM burner
Rep: 44 (Unique: 27)
Alphacool Eisbaer 360/420mm.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 43 (permalink) Old 02-23-2020, 11:08 PM
poah's Avatar
Rep: 7 (Unique: 6)
Arctic cooler freezer II 360. best AIO you can buy.
poah is offline
post #5 of 43 (permalink) Old 02-24-2020, 12:58 AM
Overclocker
JackCY's Avatar
Rep: 352 (Unique: 250)
Mmm... none. Go custom loop or don't bother with water would be my recommendation.
JackCY is offline
post #6 of 43 (permalink) Old 02-24-2020, 05:02 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 428 (Unique: 285)
Agreed on the Eisbaer being a good choice. Personally, I have had better results with the Swiftech H360 X3, but the fans need to be changed out as the included argeebee fans are garbage that kill performance. Also, the pump on the Swiftech is considerably stronger and was designed to have a GPU and additional rad added should that be your goal in the future.
The OP very clearly stated refillable. You inserting "Arctic Liquid Freezer II" and "Arctic P12" randomly into every thread isn't helping anyone.
ciarlatano is offline
post #7 of 43 (permalink) Old 02-24-2020, 05:27 AM
Schmuckley's Avatar
Rep: 708 (Unique: 565)
Build a bong cooler.
or do a custom loop with Panaflos on the rads.
Panaflo mediums aren't too loud and move a lot of air.
With a bong cooler, a fast fan is not needed. I usually used 1 Intel CPU fan.
Schmuckley is offline
post #8 of 43 (permalink) Old 02-24-2020, 05:31 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
If you ever want to add a gpu water block I would also say go full loop
Soft tubing makes it easy.
Parts well you can treat it with just the basics and add to it easily knowing you have at least a single D5 pump/ reservoir combo to already expand too.
1) Rad
1) cpu block
1) D5 pump reservoir combo
6) 10-16mm barb fittings
10 foot of 10-16mm soft tubing
Budget well depends of how much price shopping you do and region you're in.
Alphacool has some okay water cooling products and just go for the best cpu block.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #9 of 43 (permalink) Old 02-24-2020, 06:59 AM
sakete's Avatar
Rep: 10 (Unique: 9)
Quote: Originally Posted by ThrashZone View Post
Hi,
1) Rad
1) cpu block
Are barb fittings better than compression fittings for soft tubing?
Main
(17 items)
AMD Ryzen 9 3900X
Asus X570 ROG Crosshair VIII Formula
EVGA GTX 980Ti SC+
2x 16GB G.Skill Ripjaws DDR4-3600 C16
1TB Samsung 970 EVO+ NVMe
1TB Samsung 850 EVO SSD
480GB SanDisk Extreme Pro
3x 4TB HGST Deskstar NAS (2 in RAID 1)
Seasonic Prime PX-1000
Optimus Foundation AM4
HWLabs GTS 360 XFLOW
Phanteks Enthoo 719/Luxe 2
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
sakete is offline
post #10 of 43 (permalink) Old 02-24-2020, 07:01 AM
ciarlatano's Avatar
Not better, just more cost effective.
