How To Measure Loop Temperature? - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 02-25-2020, 05:19 PM - Thread Starter
LesPaulLover's Avatar
Rep: 19 (Unique: 17)
Sooo....Spring is around the corner and Summer will be following shortly after. I live in upstate NY, and based on previous experience, I expect my COMPONENT temp measurements to increase somewhere in the 8-10c range. On the other hand this is my FIRST custom loop. Simple question is:
What's the best way to measure the LIQUID temperature in my loop? Run my rig under GPU+CPU stress test, pop open the res. and use a digital thermometer? It says my Pump is rated for use up to "55c" so that's my main concern. Under HEAVY gaming load (BFV for example which pushed 99% GPU and 70-80% all CPU cores w/ AVX instructions) my 9900k+1080Ti pull around 400w total and my loop has a single 360 rad.
Silence Redefined!
(11 items)
9900K
ASRock Z390 Phantom Gaming X
EVGA 1080Ti SC2 Hybrid
32GB T-Force DARK Pro
Plextor 1TB nVME
EVGA SuperNOVA 750 G2
Fractal Design Celcius S36
Fractal Design Define R6
ViewSonic XG2703-GS
Keyboard
ASUS ROG Strix Flare
Mouse
Steelseries Rival 600
LesPaulLover is offline
post #2 of 6 (permalink) Old 02-25-2020, 05:50 PM
ntuason's Avatar
Rep: 175 (Unique: 155)
You're on a custom loop? Get a res that has a built in temp sensor in it or add a Bykski B-TME-SC-V2 into your loop.
i7 980x + CF 6970
(11 items)
i9-9900K @ 5.2GHz 1.39v (Direct-Die)
ASUS ROG Maximus XI Apex
ASUS ROG RTX 2080 Ti O11G
Trident Z Royal @ 4200MHz CL18
970 EVO Plus NVMe M.2 500GB
860 QVO 1TB
BarraCuda 8TB
Cooler Master MasterWatt Maker 1200
Swiftech H360X3 + Nemesis 360 GTX + Barrowch 200mm Boxfish
Lian Li PC-011 Dynamic (White)
Operating System
Windows 10 19H2-1909 64bit
Samsung CHG70 32" QLED, 1ms 144Hz
Keyboard
Logitech G815 Tactile
Mouse
Logitech G Pro Wireless
Mousepad
Logitech G840
Audio
Kanto Yu4 + Kanto SUB8 8-Inch
Audio
Audeze LCD-4
i7 980X 3003B475* @ 4449.1MHz 1.45V (6C-12T)
ASUS Rampage III Extreme - 1208 BIOS
ASUS ROG Strix GeForce GTX 1660 Ti
6GB Corsair Dominator GT 2009MHz / 7-8-7-20 T1 C7*
RAID 0* OCZ Vertex 3 120GBX2 (OS)+ 4X 2TB WD Green
Seasonic PRIME 600 Titanium
Corsair Obsidian 800D
Operating System
Windows 7 Ultimate 64Bit
Keyboard
Filco Majestouch-2 Cherry MX Red
Mouse
Razor Mamba 4G
Mouse
Logitech G703
ntuason is offline
post #3 of 6 (permalink) Old 02-25-2020, 05:59 PM
u broke 666 rep :(
skupples's Avatar
Rep: 681 (Unique: 361)
a few choices
cheapest - g1/4 temp probe plug
cheaper - g1/4 inline temp probe (i prefer plugs, but some say they're less accurate cuz coolant pools in the caps, to that I say, not at 2gpm!)
less cheap - MIPS device from aquacomputer (temp, pressure, flow, some other random data syncs via the awesome aquasuite software, and the included usb cable)
not cheap - sensors built into pumps/res stuff.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #4 of 6 (permalink) Old 02-26-2020, 01:09 AM
Black Sun Empire
Wuest3nFuchs's Avatar
Rep: 38 (Unique: 31)
Keep in mind that bykski uses aluminum here!!
Gesendet von meinem SM-G950F mit Tapatalk
Watercoolingbox
https://www.overclock.net/t/1352993/...oolingbox/0_20
V3g4n0
(18 items)
2700X
Asus ROG Crosshair Hero VII
Sapphire RX Vega56 Pulse
GSkill F4-3200C14D-16GFX
Crucial MX 500
Crucial MX 500
Optical Drive
Pioneer BDR S09 XLT
BeQuiet Straight Power
BeQuiet Silent Loop 240mm
BeQuiet DARK BASE PRO 900 Silver rev. 2
Operating System
Win 10 1803
AOC Agon AG241QX, 23.8"
Keyboard
Steelseries M750
Mouse
Steelseries Sensei 310
Mousepad
Steelseries DEX
Audio
Steelseries Arctis 5
Audio
Sound Blaster X-Fi titanium HD
Other
Tobii Eyetracer 4c
Ryzen 5 2400G
Asus TUF X470 PLUS GAMING
Crucial Ballistix Sport AT DIMM Kit 16GB Single Ranked BLS2K8G4D30CESTK
Samsung SM843 MZ7TD240HAFV-000DA
Crucial M4
be quiet! Straight Power 11 550W ATX 2.4 (BN281)
Ryzen 7 Wraith RGB
Fractal Design Define R6 Black
Operating System
Win 10 1803 / Server 2016 Standard
Samsung SyncMaster XL2370 LED, 23" (LS23EFPKFVEN)
Wuest3nFuchs is offline
post #5 of 6 (permalink) Old 02-26-2020, 09:05 PM
D-EJ915's Avatar
Rep: 13 (Unique: 12)
I stuck a G1/4" plug one in the bottom of my res which works fine for me. I have this one plugged into my lamptron controller.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #6 of 6 (permalink) Old 02-27-2020, 12:22 AM
munternet's Avatar
Rep: 20 (Unique: 11)
If you are anywhere near 55c coolant temp you are in trouble
My coolant has maxed at about 35c in the middle of summer and sits in the low 20s in winter.
If you can afford it the Corsair Commander Pro looks like a good fit for your system.
I would run the pump off the CPU header since it's not allowed to stop completely and you can control the fans based on your coolant temp. Four temp sensors are included in the kit and it also controls your lights.
If your board had a T sensor you could have used that with a 10k thermistor but it looks like your board doesn't have one.
A friend set his up this way and it's awesome
Edit: A single 360 sounds a bit light. I run a 360 and a 420 and that's about right. I have similar hardware.
Intel Memory Overclocking Quick Reference https://www.overclock.net/forum/27784556-post7836.html
Maximus XI Gene Overclocking Results Thread https://www.overclock.net/forum/5-in...k-results.html
New Zealand Overclock.net Club
9900ks
Asus Maximus XI Gene
EVGA 1080 Ti Superclock 2 Black
F4-4400C19D-16GTZSW
Samsung M.2 1TB 970 EVO Plus
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 1 x 360mm and 1 x 420mm Radiators and Vardar Furious Fans
ThermalTake V51
Operating System
Windows 10 Pro
Asus PG349Q 34.1 inches 3440 x 1440 pixels @ 120 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000x500x3
Audio
Steelseries Siberia800 wireless Headset
8700k @ 5.2ghZ
Maximus X Hero
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Asus Maximus VII Ranger
Gigabyte NVIDIA GeForce GTX980
G.SKILL Trident X 16GB 2 x 8GB 2400 Memory F3-2400C10D-16GTX
Seagate Barracuda 2TB
Optical Drive
LG DVD Rom
PSU Coolermaster V1000W
Custom Loop
Case Thermaltake V51 Full Window
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Thermaltake Poseidon Z
Mouse
Logitech G602
munternet is offline
