WC custom loop turned off 3 monts... now what? - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 02-29-2020, 09:11 PM - Thread Starter
Tweaking since 386 era
MaddogMcCree's Avatar
Rep: 1 (Unique: 1)
Hi all! I have been travelling and pc has been turned off for 3 months when i get home. I have a custom loop with dye and pastel (both mayhems) in it, so i am very afraid it has either settled or maybe even gunked up. I read some horror story about a d5 pump sucking the system vacuum due to blockages and i dont want to break anything. I preferrably also dont want to disassemble and clean the entire system while it is not needed. So my question: if it looks bad when i come home, can i just turn it on and hope the settled particles dissolve again into a homogenous fluid? And just hope there is no real blockage? Or is this really a bad idea? Any recommendations?
MaddogMcCree is offline
post #2 of 19 (permalink) Old 02-29-2020, 10:40 PM
u broke 666 rep :(
skupples's Avatar
Rep: 681 (Unique: 361)
full tear down, a 6 pack of distilled gallons, and a mayhems blitz kit.
don't even turn it on. just drain it, & tear it down.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #3 of 19 (permalink) Old 02-29-2020, 10:55 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 70 (Unique: 49)
LOL! I was about to recommend the exact opposite as Skupples! LOL! I highly respect Skupples experience and knowledge though, and he definitely has more experience here than me, so I would probably go with his suggestion to be on the safe side.
If it was me, I would YOLO it, lol. Probably not the best advice. First I would inspect it, hopefully you have a drain built in your system, often a good way to get a pump going if gunk has built up in it, is simply to drain a few mL of Fluid, if you built your drain system in directly after the pump and at the lowest part of your loop, then once you take off the fill port, and crack open your drain, the pressure will cause even built up gunk that may be causing a clog to flow out. I wouldn't drain all the fluid just yet, just drain a few mL into a see through bottle so you can inspect what comes out. If it is all gunked up and separated, then there is no doubt that Skupples suggestion is definitely the way to go here. If however the liquid looks fine, and looking in your Res everything else looks fine, turn on that pump for a few seconds and see if the loop starts up again. If you hear any messed up sounds, or the loop does not start up, then again, drain everything, flush the system with Distilled water, and probably refrain from using that fluid in the future, especially if you have long periods of time where you don't turn it on often.
If however it starts right up, everything looks good, then you have probably dodged a bullet and can use like normal. I personally have only had negative experiences with Colored Fluids, again I am not as experienced as others on here, I just know for me Colored Fluid, especially pastels, are just not worth the hassle. If this was Distilled water with Mayhems Biocide and Inhibitor Plus, or their Clear Fluid, you wouldn't even have this concern. Anyways, good luck, let us know what happens!
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #4 of 19 (permalink) Old 02-29-2020, 11:07 PM
u broke 666 rep :(
skupples's Avatar
awe thanks, but i'm just another scrub.
i'd normally agree, if it were anything other than dye and pastel
I let an X1 build sit for 6 months, then powered it right back up, then let it run for 2 before cleaning. Temps didn't shift, so no fux given.
skupples is offline
post #5 of 19 (permalink) Old 02-29-2020, 11:08 PM
u broke 666 rep :(
skupples's Avatar
I let an X1 build sit for 6 months, then powered it right back up, then let it run for 2 years before cleaning. Temps didn't shift, so no fux given.
oh great, usb power exceeded error. too late for this shart.
skupples is offline
post #6 of 19 (permalink) Old 02-29-2020, 11:24 PM
Watercooler
Socks keep you warm's Avatar
Rep: 136 (Unique: 119)
Just replace it, i honestly think it will be fine, but it's so cheap just to replace it.
I like to have fun.
https://stats.foldingathome.org/donor/110855
https://www.trueachievements.com/gamer/II+TH3PRO+II
16 Threads is Good
(10 items)
Intel Core I9 9900K 4.8Ghz
Gigabyte Aorus Elite
Aorus 2080Ti Xtreme Waterforce WB 11GB
Trident Z
Samsung 250 SSD
Cooler Master Silent Pro Hybrid
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
Socks keep you warm is offline
post #7 of 19 (permalink) Old 03-01-2020, 02:14 AM - Thread Starter
Rep: 1 (Unique: 1)
Thanks for the fast replies! Getting a little anxious though hehe. Skupples why do you say tear it down? Is there a risk of breaking the pump if it is clogged or so? Oreo thank for the alternative solution, depending on how it looks might try that first. Socks: replacing the fluid you mean i guess? Do i really need multiple gallons of water to flush? Would it then not be better to just first flush with tapwater and then distilled?
post #8 of 19 (permalink) Old 03-01-2020, 04:15 AM
Tech Enthusiast
oreonutz's Avatar
I would NOT put tap water through your Loop unless you intend to flush with at least a few gallon's of Distilled and a Mayhem's Blits Kit part 2 (Which coincidentally will need at least a few more gallons of Distilled to flush that too). Putting tap water in your loop is one of the worst things you can do, unless its thoroughly flushed with Distilled afterwards, in which case you should have just used distilled in the first place.
NP for the advice though! Glad to help. There is Risk to the Pump if its SO CLOGGED that it is not able to pump fluid properly, but really your biggest concern is burning the pump out, which is why I said to drain just a bit of fluid first which should get your pump able to start, and then see if your pump is working properly. Hopefully you have some kind of flow meter so you can see how well its pumping. Otherwise you may have to eventually turn your system on, and not just the pump, to check temps and make sure everything looks good. Until you are sure everything is running perfectly, to avoid burning out your pump I would recommend to not allow it to stay on for more than 2 minutes at a time, until you are certain it is pumping properly and that your flow/temps are looking good. And to Cut Power to the Pump Immediately if you hear any weird noises that indicate its having issues pumping fluid, or the second you realize that it is not pumping properly to avoid damage to the pump. If those scenarios happen, and draining a few mL Doesn't help then thats when you definitely should consider draining all the fluid and using a Blitz Kit.
Mr @Socks Keep You Warm is probably correct that flushing the fluid and refilling might be the best option, the problem is it depends where the gunk build up is, and whether just a normal flush will get all the gunk out. You could be in a situation where a lot of the gunk ended up in your Pump and built up in places that are hard to get out with just a normal flush. This is why @skupples recommended using the Blitz Kit, specifically the Blitz Kit Part 2. If you aren't home yet, I would consider ordering one right now, depending on where you live I am pretty sure PCOutlet.com still has a few in stock, and if you are on the west Coast of North America they can get it to you in a few days. Amazon may have stock from PPC or TitanRig.com as well, in which case that might get to you faster.
The Blitz Kit comes with Part 1 and Part 2, definitely best not to confuse the 2. Part 1 is JUST for Radiators, and should be put to the side for a later date when it may be necessary to pull out a rad and thoroughly clean it separately. Part 2 is for running through your loop for 24 hours. It will do an amazing job of cleaning out any left over gunk built up in any part in your loop.
If you find that there is bad gunk build up, it would be a good idea to flush with at least 2 gallons of Distilled water, then fill with Part 2/Distilled Mix, let it run for at least 12 hours, although I would recommend a full 24 hours, then flush with at least another 2 gallons of Distilled, then your loop will be ready for whatever coolant you plan to use next. It also has the added bonus of making sure the pH Balance of your Loop is neutral, so if you are using good fluid, your parts will be cleaner then they were when you bought them from the factory, and you will be set up for success in your loop. In the future I would avoid pastels. Just my opinion, but I found it best to stick by this until there is a pastel on the market that can prove itself not to have this problem. Definitely would avoid mixing Pastels and Dye in the future as well. Just no Pastels, and you will be good! LOL!
Of course you can use Pastels and be fine, it just takes a crap ton more maintenance, and I just prefer to run Clear Distilled with Mayhems Biocide and Inhibitor Plus, or Clear XT1, as either of those set you up with a low Maintenance loop that, like Jensen, "It Just Works". LOL!
Good Luck, let us know how it turns out, you may end up being fine, and then can delay that Blitz kit flush until you are ready to switch out your coolant (I recommend using Blitz Kit Part 2 between each Coolant Change for best results, and One Blitz Kit Purchase gives you enough Part 2 to Flush at least 2 to 3 Times.)
You may be a scrub, but you are a knowledgeable scrub sir, you have my utmost respect!
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #9 of 19 (permalink) Old 03-01-2020, 04:23 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
Shouldn't be too tough to tell how bad or good it is
Just look at the fluid in the reservoir
If it's still a solid color with no fading at the top it's probably okay.
If it looks deluded then yeah break it all down and manually clean the blocks and flush the rest with the blocks removed just temp pipe it together without the blocks in it.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #10 of 19 (permalink) Old 03-01-2020, 06:41 PM - Thread Starter
Rep: 1 (Unique: 1)
Thanks for all your extensive replies. Had I not asked this question here I would have just shaken the case and turned it on, see what happens. Learnt a lot from this. Will keep you guys updated, but that will take a small month. Currently in Australia for a long road trip, live in Amsterdam, there is a very good local supplier, will order a blitz kit right away to keep at hand.
