Is this water block broken??? - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 03-06-2020, 12:13 PM - Thread Starter
Rep: 0
Recently I install a water cooling system for my graphic card, but after that my computer always have a black screen. And my graphic card gets abnormal temperature(standby temperature is 20 celsius higher than before). I follow all the instructions from EKWB provide to me. The only thing that I did not follow that instruction is that I di not cut the thernal pad into specific shape that exactly cover what it should cover. It means that it covers somewhere else, like some solder joint. But I can make sure that the water block is installed tightly onto the graphic card. Does this cause the black screen and abnormal temperature? (When I open the graphic card, there is no mechanical damage or burn marks made by short circuit)
Blankysa is offline
post #2 of 5 (permalink) Old 03-07-2020, 05:06 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 427 (Unique: 284)
What card and which block......
ciarlatano is offline
post #3 of 5 (permalink) Old 03-07-2020, 08:41 AM
Endeav's Avatar
Rep: 0
Pictures of the gpu block mounted and not mounted would be good. Also if you have a black screen, how do you know temps? Or did you get into windows?
Most common problem with EK blocks is using wrong screw length, they put multiple screw lengths in the gpu mount kit, make sure you used the smallest M2.5x4mm screws, and that you used the 0.5mm thickness pads in the correct areas.
Endeav is offline
post #4 of 5 (permalink) Old 03-07-2020, 08:46 AM
u broke 666 rep :(
skupples's Avatar
Rep: 677 (Unique: 360)
no pics no knowing.
highly possible you did something wrong and are causing a short, which would then prevent the card from functioning properly.
It's happened to me more than once with hastily slapping on a new waterblock.
solution - take it off, put it on again. this time try harder, go slower, n start by tightening the screws around the chip first.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #5 of 5 (permalink) Old 03-07-2020, 04:13 PM
D-EJ915's Avatar
Rep: 13 (Unique: 12)
It might not be making proper contact due to you not following the instructions.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
