First watercooling parts shopping list - Page 3 - Overclock.net - An Overclocking Community
post #21 of 106 (permalink) Old 03-08-2020, 06:04 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Quote: Originally Posted by Mordorr View Post
Not tygan clear?
Hi,
Tygon but if it weren't for the printing it would be perfect although softer than most soft tubing I've used.
They have a clear laboratory grade 165f Degree* pretty close to the black posted
https://www.usplastic.com/catalog/it...1121&catid=864
And a clear chemical grade 130f degree
https://www.usplastic.com/catalog/it...5640&catid=864
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #22 of 106 (permalink) Old 03-08-2020, 08:06 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 428 (Unique: 285)
Quote: Originally Posted by sakete View Post
Is there an equivalent clear tubing that's just as low maintenance and plasticizer free?
Tygon does make a plasticizer free clear (Mayhems clear is good tubing, but is NOT plasticizer free, nor is it maintenance free....so no clue why it was recommended given your question) - https://www.frozencpu.com/cat/l3/g/c...ree-Page1.html .
I haven't used the Tygon, but have seen a lot of mentions that it can become very stiff and/or brittle, and can get very cloudy. You need to keep in mind that this kind of tubing is made for medical and chemical applications, so it is all about the performance and longevity in applications where aesthetics and bends to meet eye pleasing requirements mean absolutely nothing.
ciarlatano is offline
post #23 of 106 (permalink) Old 03-08-2020, 08:22 AM
u broke 666 rep :(
skupples's Avatar
Rep: 681 (Unique: 361)
looks good, aside from the alphastool radiators
the pump is excessive for such a small build, so full tilt could possibly induce a leak somewhere that otherwise wouldn't on low duty cycle.
get a aquacomputer MIPS device instead of the flows & temps. you don't really need multiple anyway.
a 2nd temp sensor makes sense, just to be sure the 1st one is working.
that's a ton of side stuff for a 1 radiator build.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #24 of 106 (permalink) Old 03-08-2020, 08:47 AM - Thread Starter
sakete's Avatar
Rep: 10 (Unique: 9)
Good to know, thanks. Black Tygon tubing it is then.
Main
(17 items)
AMD Ryzen 9 3900X
Asus X570 ROG Crosshair VIII Formula
EVGA GTX 980Ti SC+
2x 16GB G.Skill Ripjaws DDR4-3600 C16
1TB Samsung 970 EVO+ NVMe
1TB Samsung 850 EVO SSD
480GB SanDisk Extreme Pro
3x 4TB HGST Deskstar NAS (2 in RAID 1)
Seasonic Prime PX-1000
Optimus Foundation AM4
HWLabs GTS 360 XFLOW
Phanteks Enthoo 719/Luxe 2
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
sakete is offline
post #25 of 106 (permalink) Old 03-08-2020, 08:53 AM - Thread Starter
sakete's Avatar
Rep: 10 (Unique: 9)
So I plan on adding a GPU block + second radiator (probably another 360 or 480 as side exhaust) once nvidia releases their 3080/3080Ti. That's why I want to build this with that in mind. I'm also debating going for HWL GTS rads instead, as they're slim and perform very well for their size. They just tend to be a bit wider than many other radiators (133mm vs. for example 124mm on the equivalent Alphacool). For side mounting in the my Phanteks 719 case, clearances are tight. Those GTS rads are relatively quite restrictive. And the Optimus blocks are pretty restrictive as well (and I'd probably also go for an Optimus GPU block, though given their history so far, it might take a long time before they would release blocks for the 30xx GPU series).
As for the dual-pumps, my goal will be to run them as low as possible to minimize noise levels. Low noise is more important to me than ultimate performance. Might just get Noctua NF-A12x25 fans instead of the SilentWings, and start with a side mount radiator. The fans I could mount out of sight in a pull setup with the 480 rad as side exhaust, so the brown/beige color wouldn't matter. And then once the Chromax version of those Noctua fans come out in Q3, that would be for the top mount 360 x-flow exhaust radiator in push mode (or maybe pull as well, easier to clean the rads that way).
I could even add a third 240 rad on the bottom as intake, but perhaps that's overkill for this build
I'll look into the Aquacomputer MIPS.
Main
(17 items)
AMD Ryzen 9 3900X
EVGA GTX 980Ti SC+
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
sakete is offline
post #26 of 106 (permalink) Old 03-08-2020, 08:58 AM
ciarlatano's Avatar
Sound is really subjective. But....I am a sound profile first builder, and really find the sound signature of the SW3 to be much nicer than the NF-A12x25. While there is a slight performance difference, in your application it may not even be measurable (that's how slight we are talking). Just food for thought.
post #27 of 106 (permalink) Old 03-08-2020, 11:08 AM - Thread Starter
sakete's Avatar
Rep: 10 (Unique: 9)
There is a TPU comparison somewhere that shows for a given RPM, the Noctua is much quieter when measured in dB/dBA (don't remember which one they used), will pushing more air through radiators than the SW3. But if the sound profile, i.e. the frequency of the generated sound, is more pleasant on the SW3 than the Noctua, I agree that it might be more bearable.
I have one NF-F12 fan in my case right now, and I hate the noise of it at higher RPMs. But I also have the NF-A14x25 and the noise profile of those is great (as well as the NF-A15s that are on my Noctua NH-D15, sound great overall).
My application will be Low RPM, probably up to ~1,000.
Main
(17 items)
AMD Ryzen 9 3900X
EVGA GTX 980Ti SC+
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
sakete is offline
post #28 of 106 (permalink) Old 03-08-2020, 11:30 AM
ThrashZone's Avatar
Hi,
Didn't know about mayhems tubing not being plasticizer free can't trust nobody damn it
Tygon well Contains only non-DEHP plasticizer what ever that is supposed to mean ?
That black tygon says nothing one way or another that I noticed.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #29 of 106 (permalink) Old 03-08-2020, 11:47 AM
tatmMRKIV's Avatar
Rep: 132 (Unique: 88)
Not tygan clear?
tygon has printing on it AFAIK and mayhems doesn't, i dunno I have been away from the scene for a while, but I haven't heard anything to the contrary, yet. And mayhems has been put through a lot of tests, I think most people use it for clear soft tubing, here, they did 3 years ago.
(If y'all) ain’t ready for the old murder, then what you gonna do with the new me?
tatmMRKIV is offline
post #30 of 106 (permalink) Old 03-08-2020, 12:24 PM
ciarlatano's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
My understanding is that Mayhems Ultra has very low likelihood of leeching, but is not actually plasticizer free.
The Tygon A-60-G is made from Norprene, which is a plasticizer free material.
