CPU Waterblock started to leak - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 03-10-2020, 07:17 AM - Thread Starter
Rep: 39 (Unique: 33)
Hi guys want to share that I encountered a issue with my CPU waterblock that started to leak water.
I have a Alphacool XPX Eisblock, sandblasted /frosty version. I've been using it now for 8months.
The other day I had a issue when I didn't notice that my LAING DDC pump didn't start and as result the computer was running for a while until it restarted and I noticed as I went into BIOS my CPU was running 107C.
I quickly caught that my pump wasn't running and did a quick shutdown and then restarted to make sure the pump would turn on.
I see it start and check too see if all is ok...
When the pump started to run you get this gush of water coming out from all sides from the CPU waterblock.
The heat had caused some issue with the block and water was now coming out from all sides from it. It was no small amount either. I quickly was trying to shutdown as much was dropping down to my graphics card right below.
I'm not happy to say the least. The heat build-up and the resultant pressure caused some issue with the block.
There was water down the whole backside on my GPU and running down the whole motherboard to the bottom of the case. The computer basically shutdown on it's own before I had time so shut it down. Pulled power and went to check damage.
It's a lot of work to drain and fill this system. Not something I enjoy doing.
Either way I had to remove and redo my VEGA 64 waterblock as there was water on the PCB, was running down from it as I picked it out from the system. I was suspecting it had fried with the amount of water on it. Water was in the PCIE port also. So many points of failure was evident to check later.
I suspected a dead GPU, dead motherboard and maybe dead CPU.
Either way I looked at the CPU waterblock next, I was just a little disappointed and wondering if it's utterly useless now. I wondered what was the cause of failure with it.
I saw it was not the fittings but the part that is the TOP and the middle part where you have your bracket for installation fit into that had leaked in-between. Had something cracked? No.
This waterblock is comprised of 3-layers compared to the usual 2-layer design with only the cold-plate and a top screwed onto it.
You only have 4 screws holding it together screwed from the bottom. The cold-plate had some water on one of the screws... Pressure had forced it out here. I saw there was water inside where there shouldn't be.
I screwed it open and the coldplate had held with it's black O-ring. Water hadn't leaked outside from it and the above middle part where you have your mounting plates for your socket attach. It was on the layer above where you have the top attach to this part with 2 transparent O-rings that had leaked. It was filled with water where there should be none. I looked around and saw no damage to anything. Why did it leak? Pressure?
Is this OK? Did the heat just cause too much pressure in the block so the O-rings could not handle it?
I looked over the whole thing but found no apparent fault. I just decided to dry it up and clean it up and hope that would do it. I was a little worried about the O-rings. They apparently weren't that good as they should be.
After several hours of redoing and cleaning up the mess I went to test the system again if it was still working after filling and redoing the loop and making sure it wasn't leaking again. Too my surprise the system worked and nothing was wrong.
I did my air-bleed and filled up the reservoir to full and started to use the computer for a couple hours. All seemed OK until I started some heat load. As soon as the water got a little warm I saw a drop of water form and drop out from below the CPU waterblock again. ... Panic and shut down!
I quickly dried up the water that had dropped once again on my GPU and checked things. Why is it still leaking? What has gone wrong with it? It was just a single droplet but enough to cause damage it if goes to the wrong place. I had made sure the O-rings where sealed properly and all.
I went to check pressure in the system... PSSSHT!... Too much pressure... Air wanted out from the system as I opened the reservoir. Ok, maybe it's still a issue.
I remove some water from the system to not have as much and retest and get the system warm. I keep testing and have some toilet paper to take any excess leakage. It keeps leaking a droplet now and then. The O-rings are clearly not doing their purpose properly. My CPU block is the weakest link and I have a pressure problem in my system. Any excess pressure and my system wants to release it through my CPU waterblock.
I kept going and opening up the reservoir and sure enough there was too much pressure every time. Air&water wants out from my loop. It's and issue when the weakest link is seemingly the O-rings in my CPU waterblock. I never had the issue it wanted to leak before and I've noted the pressure issue before but it hadn't caused leakage as far as I had seen yet but after this incident.
The block keeps leaking as of this moment, not by much but enough to be a problem. You can keep a little paper there to soak it up before it hits any other parts. It has enough time to dry before another leakage.
I'm a little more than pissed, I need to take out the block once again to maybe redo the re-assembly but not sure if that will be enough to keep it from leaking again. It can't take the pressure my system keeps building up.
Can O-rings shrink with time? These are not the regular black O-rings, some transparent ones. I noticed they were kinda on the slime side and not putting good pressure against the top part.
It's the point of failure as far as I'm concerned. I never thought the CPU block would leak in this way as it has done now. And I wonder why it's doing it now. It's been all good for a solid 6months at least. I've had pressure be high before and it hasn't leaked then.
Gigabyte X570 AORUS XTREME, Ryzen 7 3800X 4.4Ghz, 4266/1900 MEM/FCLK, 16.26.19.45.76.tRFC 650 1T 1.600V
4x8Gb Kingston HX434C19FB2K2/16 3466C19 1.2V (Micron E-die 16nm)
OLD: Biostar x470GT8 Ryzen 7 1700 @ ~4.0Ghz CPU, 3200Mhz RAM ...
Nighthog is offline
post #2 of 20 (permalink) Old 03-10-2020, 07:30 AM
Schmuckley's Avatar
Rep: 708 (Unique: 565)
I would try replacing the O-rings. Surely ones rated for an air compressor would hold enough pressure.
Schmuckley is offline
post #3 of 20 (permalink) Old 03-10-2020, 07:53 AM - Thread Starter
For sure that's the easy solution but finding the right size can be trouble.
__________________________________________________ ___________
I checked the packaging and sure enough some spares are provided with the kit. They are some black ones. They could be meant for the cold-plate which wasn't the issue. But they seem to use similar sizes for both.
Check this page for images techpowerUp review
The spares look more for the issue area where the transparent ones are used. The smaller O-ring is thicker than the one for the cold-plate and seems to be for the top-part.
Will have to try them next time I feel like doing it. Not today at least.
Nighthog is offline
post #4 of 20 (permalink) Old 03-10-2020, 08:03 AM - Thread Starter
Here is a picture for the temporary solution to the issue at hand.
Nighthog is offline
post #5 of 20 (permalink) Old 03-10-2020, 08:14 AM
Shawnb99's Avatar
Rep: 50 (Unique: 32)
I'd just replace the block rather then wishing for the best and trying to fix whatever the issue is.
Failing after 8 months and then failing again would make me stop using it right then and there. I wouldn't trust with out days worth of leak testing it.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #6 of 20 (permalink) Old 03-10-2020, 08:15 AM
Schmuckley's Avatar
Yeesh, that looks pretty janky. Paper towels?
post #7 of 20 (permalink) Old 03-10-2020, 08:17 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
Seems like a air cooler would be a better temporary solution
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #8 of 20 (permalink) Old 03-10-2020, 08:26 AM - Thread Starter
Quote: Originally Posted by ThrashZone View Post
Hi,
You want me to go use the AMD stock cooler? Good laugh!
I have the old XP3 Light with AM4 mounting if the spare O-rings are no good.
The towels work good enough. The leak isn't large right now.
On the other hand if it starts leaking like it did when the pump wasn't working at start... You had water escape all sides of the block. The pressure must have been horrendous for it to fail like that. I'm suspecting a blockage or something.
Nighthog is offline
post #9 of 20 (permalink) Old 03-10-2020, 08:29 AM
ThrashZone's Avatar
Hi,
So toasting the board is better to you okay leaks rarely get better on their own
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #10 of 20 (permalink) Old 03-10-2020, 08:38 AM - Thread Starter
Hi,
The motherboard is already water damaged from a earlier mishap. No warranty with no onboard audio working. (I was so happy when it was working...)
I'm more worried about the GPU, no warranty on it either, second hand mining card. I don't give a crap either way at the moment, this **** been giving me grief like no other system to the amount of money and time spent on it. I was done... Wasn't going to touch it any more and this **** happens. Was I happy?
Nighthog is offline
