Let's talk fittings - Page 3 - Overclock.net - An Overclocking Community
Let's talk fittings
post #21 of 28 (permalink) Old 03-13-2020, 05:44 AM
NewUser16's Avatar
Rep: 53 (Unique: 36)
Quote: Originally Posted by criskoe View Post
The bitspower ball drain valve i got today from PPC wont fully close and seal. When you turn the knob it stops slightly at a angle. It made me inspect it right away. Trying to put any pressure on it while closed results in a very audible air leaking noise out the valve. Not sure how often there are QC issues with bitspower. From what it sounds like here, its not very often. But the drain valve i got today shows it can happen still.
This is very unique to BP valves, they use very tight tolerance to ensure good seal. When you feel that the handle stops put slightly more pressure and you will feel a little snap and handle will close all the way with slight pressure, don't worry, this is very normal with their valves and you wont brake the handle, unless the handle itself is defect
I remember years ago I got 4 of these valves and all of them had the same so I thought "Issue" upon emailing BP they asked me to go ahead and do the last 1/2-1mm turn and that I would feel pressure before total close/seal, but not to worry, so I did and never doubted that part again I've use the same BP fittings and valves from build to build for close to 10 years, not a single leak or issue of any kind.
NewUser16 is offline
post #22 of 28 (permalink) Old 03-13-2020, 06:06 AM
criskoe's Avatar
Rep: 4 (Unique: 4)
Na dude. It wont turn. Ive tried. Its binding on something inside. I cranked on it pretty hard. Hard enough that if it were installed on a pump top you would tear it out of a plexi or acetal theads from the twist. Like i said. If i try any harder. It will break.
Other thing that shows there is something wrong is it when open throttle the ball inside wont fully open and the knob on it is not a strait line. Its crooked a to the close position.
criskoe is offline
post #23 of 28 (permalink) Old 03-13-2020, 06:08 AM
NewUser16's Avatar
OK so maybe we talking different thing, because you will know this very tight opening and closing these valves and they will stay that way always, that part doesn't wear out.
The handle wont be 45 degree until its open or close all the way, but from what you describing there might be something else.
You talking these valves
post #24 of 28 (permalink) Old 03-13-2020, 06:17 AM
criskoe's Avatar
Rep: 4 (Unique: 4)
LOL nice little army of fittings
Yeah im not sure either. I just dont want to break it and get denied a rma. LOL. I mean i tried turning it pretty good. Enough that my fingers really feel it. LOL. It feels like i might break it. Maybe im being a chicken ****.
When I reach out to performance PC and if they tell me to just crank on it. I will
criskoe is offline
post #25 of 28 (permalink) Old 03-13-2020, 06:24 AM
NewUser16's Avatar
I was just like you, didn't want to damaged anything, but BP was good about assuring me that If anything brakes they would send me new one so that's how I learned about that part.
Although BP makes the best fittings at least in my opinion, defects happens and there is no doubt no one makes perfect parts, but they are very good and quick and painless RMA.
I have at least $1500 or more of their fittings alone that are about 10-11 years old and so far super happy and surprisingly, as you can see they look like new and that's not even half of them, a lot of them are already installed in a new, big build I'm working on.
Btw. As I said, the valve seal wont wear out, mine are years old and still feel solid, you don't want anything flimsy either like some of the cheaper brands, but once you get past that pressure and you open and close few times it does get smoother and you will know this as well.
post #26 of 28 (permalink) Old 03-13-2020, 07:02 AM
criskoe's Avatar
Rep: 4 (Unique: 4)
I have about $1500 or more of their fittings alone that are about 10-11 years old and so far super happy and surprisingly, as you can see they look like new.
Well I just said screw it. Its a $20 dollar fitting. If it snaps and they wont help me well what ever. I grabbed a small towel like you would opening a vacuum sealed jar and put it on the tiny knob so i could get good grip and i let er rip.... LOL and it popped! LOL. And now closing it feels normal. Nice man. Thanks.. Man they should probably include a small slip inside about that. No joke tho. I really had to crank on it. happy now tho. thanks man. Saved me a huge head ache trying to rma a silly fitting.
criskoe is offline
post #27 of 28 (permalink) Old 03-13-2020, 07:31 AM
NewUser16's Avatar
I'm glad you got past your fears
Yes I agree, they should have a small info on that part.
Once you install it and liquid will flow through and you open and close few times It will be much smoother, yet tight enough to keep it seal and secure.
post #28 of 28 (permalink) Old 03-21-2020, 09:17 PM
ctguy1955's Avatar
Rep: 1 (Unique: 1)
I just tore my whole system apart to add new coolant and clean up the rads and the XSPC fittings as far
as 45 and 90 degrees are very good. However the straight ones are almost impossible to take off
and reuse if You tighten them too much.
I recently came across Monsoon fittings=. ex-tub-1322
Monsoon Free Center Compression Fitting - 7/16"ID x 5/8"OD - Modders 6 Pack Blue (FCC-71658-6P-BL)
$21.97 (I ordered 12)
Shipping:$11.49
Tax:$0.00
Grand Total:$33.46. amazon and many other places are charging 48 bucks for just 6 of em.
I ordered a second set of 12 for 33.46 again a few days later as I am rethinking my setup.
They are really awesome and are reusable for future teardowns.
Good luck on your choice !!!
ctguy1955 is offline
