9700k/EVGA RTX 2080 Ti Water Cooling - Page 2 - Overclock.net - An Overclocking Community
post #11 of 32 (permalink) Old 04-03-2020, 04:23 PM - Thread Starter
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
Alright so here's the skinny. I have no idea when the Boxfish/d5 will arrive, I got impatient and ordered a Kinetic from EK which came in along with a second heat sink for my other M.2 drive and a 2060 super to aid in folding (Also the cards that will be in my folding rig). The dilemma is this: I have everything I need for the build now, BUT the Kinetic does NOT have top or side G1/4 ports which I was counting on to reduce the amount of 90 degree fittings used to increase flow. Secondary to that, the Boxfish has a Digital temp sensor built in, and the kinetic doesn't. I did order a T probe, but still that pisses me off. What do you think I should do? Wait for the Boxfish or build using the Kinteic?
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #12 of 32 (permalink) Old 04-07-2020, 03:19 PM - Thread Starter
Back at it again.
Avacado's Avatar
Alright, got overzealous. Is 1 D5 enough for 2x360 rads, 1 cup block and 2 gpu blocks?
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #13 of 32 (permalink) Old 04-07-2020, 10:08 PM
Rep: 0
Hello,
How can I replace this part in Blue Star Water Cooler, can any one guide me step by step, otherwise I am going to buy a new one suggested by this source - top10talks.
Thanks
dklimbani is offline
post #14 of 32 (permalink) Old 04-08-2020, 05:10 AM - Thread Starter
Back at it again.
Avacado's Avatar
Quote: Originally Posted by dklimbani View Post
Hello,
Thanks
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #15 of 32 (permalink) Old 04-09-2020, 04:14 PM - Thread Starter
Back at it again.
Avacado's Avatar
Alright, Iv'e started the process. The preferred Boxfish res/D5 is lost in China somewhere, this is less than ideal because the EK combo does not have side or top G1/4 threads that I was planning on for this build. I don't have the baby this weekend, so I have 2 days to build before telework come Monday. I stripped down the case, removed the cables I won't be needing: Front panel audio, Bottom USB hub, and built in RGB hub, i'll be using an EK loop connect, so i'll run the front panel RGB to that. I removed one of the HDD cages and will keep one for good ole platter storage. This is by far the most spacious and feature included case I have ever built out of. I see the complaints of previous people with the ROG logo and will use a razor blade to take it off at a later date.
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #16 of 32 (permalink) Old 04-11-2020, 04:47 AM - Thread Starter
Back at it again.
Avacado's Avatar
Rads mounted, working through the 2x2080ti blocks. It's a pain in the ass, I dont know what I was thinking by changing the thermal pads but its agonizingly slow work.
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #17 of 32 (permalink) Old 04-11-2020, 09:35 AM
Mooncheese's Avatar
Rep: 20 (Unique: 16)
Congrats on skipping right over soft tubing, I wish I had done hard tubing in the first place but I was too intimidated. I had to learn my lesson the hard way (EK Duracrap leaked plasticizer in my loop AND turned lime green from direct and indirect sunlight, JOY). I also just recently upgraded to hard tubing, LOVE IT. Take your time! Also, if you don't have one yet, I HIGHLY recommend a pressure tester, EK sells one that is probably the most popular, "EK Leak Tester".
Putting a block on a GPU is time consuming! Make sure you have the correct pads in the correct locations and make sure you take the transparent plastic off of them (usually blue colored, but they can be transparent).
Here's mine:
https://imgur.com/a/i7zCusE
8700k @ 5.1 GHz - 0 AVX @ 1.386v Dynamic Offset w/ EK Monoblock + Delid | Gigabyte Z370 Aorus Gaming 7 | EVGA 2080 Ti XC2 Ultra @ 2070 Mhz core, 8025 MHz memory @ 1.019v w/ 375W FTW3 vbios + Phanteks Glacier Block | EK CE 420 + EK XE 360 | 2x16GB G-Skill Trident Z Royal 3600 MHz 17-20-20-38 | 2 TB Sabrent Rocket | Corsair RM1000x | Thermaltake View 71 | Alienware AW3418DW + Asus ROG Swift PG278Q (for 3D Vision) on Amazon Basics Arms | Win10 Pro 1809
Mooncheese is offline
post #18 of 32 (permalink) Old 04-11-2020, 02:04 PM - Thread Starter
Back at it again.
Avacado's Avatar
Coming along!
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #19 of 32 (permalink) Old 04-11-2020, 03:23 PM - Thread Starter
Back at it again.
Avacado's Avatar
Fingers crossed. This **** took way more than I wanted to give
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #20 of 32 (permalink) Old 04-11-2020, 03:36 PM
Father, Husband and Gamer
nasmith2000's Avatar
Rep: 45 (Unique: 40)
sweet build! i love the case, just got one too.
mines
(23 items)
9900k (5.0ghz @ 1.265)
msi meg godlike z390
evga 2080ti ftw (hybrid)
32gb corsair dominator lpx 4000mhz
860 evo (500gb) win 10
850 evo (500gb) programs
860 evo (2tb) steam games
860 evo (1tb) origin games
mx500 (2tb) one drive/pictures
mx300 (1tb) misc games
wd 8tb usb 3.0 (backup/storage)
Optical Drive
lg external (usb)
antec 1300w
corsair h150i
lian li O11dynamic xl rog
Operating System
windows 10
pg35vq
Keyboard
happy hacking pro 2
Mouse
razer basilisk
Mousepad
glorious extended gaming mouse mat
Audio
klipsch
Other
thundermaster hotas warthog
Other
thrustmaster tx racing wheel leather edition
nasmith2000 is offline
