Mandrel mounting hardware? - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 03-13-2020, 05:20 AM - Thread Starter
reaper829's Avatar
Rep: 0
I have some mandrels, and need a way to mount them to a piece of wood for complicated bends.
After doing some searching, I can't find any place that just sells the little 90 degree brackets that fit into the mandrel holes, so that I can, for instance, mount one of the mandrels vertically.
Without buying a full kit that includes them, like the Monsoon bending kit, where can I buy just these brackets? Any ideas?
reaper829 is offline
post #2 of 2 (permalink) Old 03-16-2020, 08:16 AM - Thread Starter
reaper829's Avatar
Rep: 0
I ended up just buying the monsoon mandrel kit, which included the brackets. Also, I noticed that the monsoon mandrels are smaller than the primochill mandrels, which is nice for tighter bends.
