Issue with EKWB Radiator (Idle Temp Issue) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 22 (permalink) Old 03-14-2020, 06:14 PM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Quote: Originally Posted by ZeroC00L View Post
That GTS might cause some issues, given where each port is. Is this one still a better performer than the SE and CE?
https://www.performance-pcs.com/wate...s420-f2pb.html
Hi,
One more thing you might consider
You delidded the 7900x right
Did you notice the die is more horizontal that square or even vertical ?
Having a horizontal die on my old 7900x it liked the water jet horizontal also using a ek evo supremacy which is similar design as velocity
The velocity has a vertical water jet great probably for a 9900k but not for a 7900x
So I'd recommend rotating the velocity to where the logo is sideways either direction clockwise or counter clockwise.
It might tighten your core temps to where they are closer to 10c apart instead of 14c apart from what you showed earlier from the R20 run you did.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #22 of 22 (permalink) Old 03-18-2020, 05:19 AM
Old and Decrepit
JustinThyme's Avatar
Rep: 45 (Unique: 31)
There is a lot a play here.
Firstly the 7900X is a HOT chip.
Are you measuring your liquid temp? If not you cant blame the rad just yet.
How are you over clocking? Adaptive or constant voltage? If constant Vcore your idle temps will be hotter.
What power profile are you using?
As already mentioned a large spread in core temps suggest an issue other than the rad. Is your chip delided and redone with LM?
Do you have good contact with the block?
if you are looking for exceptional performance a slim rad as the only rad is not the best of choices. If thats your only option the HW labs GTS is about as good as you are going to get, however, you cant know if the rad is the issue if you dont know the liquid temp and you are running a high performance profile and/or constant Vcore over adaptive.
Das Beast
(30 items)
I9 9940X
Asus Rampage VI Extreme
Asus Strix 2080 Ti OC
Corsair Dominator Platinum RGB CMT64GX4M8Z3600C16
Samsung 960 Pro
Samsung 850 EVO
Intel 905P
Corsair AX1600i
2x Heat Killer IV Strix 2080ti blocks with back plates
Aquaero 6 pro controller
Corsair SP120 PWM x 11
Heatkiller IV pro
Heatkiller Tube 200
EKWB 480 XE
EKWB 480 PE
EKWB 360XE
Corsair LL 120 PWM X8
D5 pumps x2 in serial bitspower head with mod kit
Heatkiller VRM block
Aquacomputer Next D5 pump mounted to Heatkiller tube 200 res
Phantek Entoo Elite Black
Operating System
WIN 10 Pro
ASUS PG349Q
Keyboard
ASUS Core
Mouse
Asus spatha
Mouse
Asus Sheath
Audio
Audio Engine A5+
Audio
SVS1000 Sub
Audio
Audio engine 192kBPS DAC
JustinThyme is online now
Tags
Ekwb , Intel , Radiator , running hot , Water Cooling
