Issue with EKWB Radiator (Idle Temp Issue) - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 03-14-2020, 10:25 AM - Thread Starter
ZeroC00L's Avatar
Rep: 1 (Unique: 1)
Hello,
I built my first custom loop with all EKWB parts. I have their velocity CPU block cooling my i9-7900X, a pump/res. combo that uses a D5 pump, and an SE 420mm radiator. I have delidded my 7900X for much better performance, but noticed that my idle temp with an overclock of 4.5GHz @ 1.150 on the VCore - is sitting at 41C. I thought this was an airflow issue and switched cases to the Phanteks Enthoo Luxe from a Be Quiet! case.
However, after searching for an answer I noticed an article (https://www.xtremerigs.net/2015/07/0...diator-review/) that said how bad the SE radiator performs. This then lead me down a rabbit hole of people saying EKWB products are terrible in performance and longevity.
I thought EKWB was good, since their customer support has been solid in my experience, and they've been around for a while.
So, I come here asking for a recommendation on a new radiator and your opinion and/or experience with EKWB.
Thank you in advance!
WhiteOut
(12 items)
Intel i9 7900X
ASUS ROG RAMPAGE VI APEX
EVGA GTX 1080Ti FTW3
G.Skill 4x8GB (32GB-3200MHz)
Western Digital Black 4TB HDD
Western Digital Black 2TB HDD
Samsung 960 EVO M.2 NVMe 1TB
Samsung 850 Evo 1TB
EVGA G2 Platinum
Fractal Design Celsius S36
be quiet! Dark Base Pro 900 White Edition (Limited Edition)
Operating System
Windows 10 Home 64-bit
ZeroC00L is offline
post #2 of 22 (permalink) Old 03-14-2020, 10:37 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
Yes SE series rads are not very good
Velocity block is okay but not the best either
D5 pump is just fine.
So with that in mind how to go forward
I'd ditch the se rad and get a hardware labs gts series to replace it and go from there.
Post up temperature screen shot after a simple run of cinebench R20 and lets see how the cpu block is performing.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 22 (permalink) Old 03-14-2020, 10:45 AM
Invalid Media
J7SC's Avatar
Rep: 60 (Unique: 26)
Quote: Originally Posted by ZeroC00L View Post
Hello,
I have several EKWB products (CPU and GPU water-blocks) but no EKWB radiators. While I did have some minor issues with the EKWB GPU blocks, quality has otherwise been good for items in use for 7 yrs+. As to radiators, I have 7x XSPC RX360 with the first 4 in use since 2012. No problems whatsoever (other than required flushing w/ distilled water when new, like most rads). Performance and reliability of my XSPC RX360 rads has been exemplary for 24/7/365 use over all these years. In addition, I also use 2x Black Ice Nemesis M184 GTX...again, no problems w/ those either.
However, these two have dramatically different fin counts per given area compared to the XSPC rads, and that suggests different type of fans (apart from size) re. pressure. You might want to check if your fans are ideal for the EK-coolstream-se-360mm for best performance.
J7SC is offline
post #4 of 22 (permalink) Old 03-14-2020, 10:52 AM
ThrashZone's Avatar
Hi,
Missed the obvious if you can return the se rad just opt for a PE or EX series ek rad instead those are the best series.
CE is mediocre but better than se.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #5 of 22 (permalink) Old 03-14-2020, 10:54 AM - Thread Starter
ZeroC00L's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by ThrashZone View Post
Hi,
Here is the screenshot you requested!
Name:	2020-03-14 12_53_13-Window.png
WhiteOut
(12 items)
Intel i9 7900X
Samsung 850 Evo 1TB
EVGA G2 Platinum
Operating System
ZeroC00L is offline
post #6 of 22 (permalink) Old 03-14-2020, 10:57 AM - Thread Starter
ZeroC00L's Avatar
Rep: 1 (Unique: 1)
So, XSPC is your clear go to. Thank you!
I appreciate the information. Any other companies that you recommend/use often?
WhiteOut
(12 items)
Intel i9 7900X
Samsung 850 Evo 1TB
EVGA G2 Platinum
Operating System
ZeroC00L is offline
post #7 of 22 (permalink) Old 03-14-2020, 10:58 AM - Thread Starter
ZeroC00L's Avatar
Rep: 1 (Unique: 1)
Hi,
Is PE or EX rads something you would recommend to anyone, or do you believe I should avoid EKWB altogether in the future?
WhiteOut
(12 items)
Intel i9 7900X
Samsung 850 Evo 1TB
EVGA G2 Platinum
Operating System
ZeroC00L is offline
post #8 of 22 (permalink) Old 03-14-2020, 11:00 AM
ThrashZone's Avatar
Hi,
Thank you
70-84c core temp spread between hottest and coolest at 4.5
Could be better usually look for within 10c to show the contact is very good
Problem with 14c difference is usually going to 4.6-4.7-... the distance will increase not decrease and usually won't even stay the same.
So you may have some thermal paste contact issue too.
Put the fans at full blast and do the test again see if anything improves.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #9 of 22 (permalink) Old 03-14-2020, 11:03 AM - Thread Starter
ZeroC00L's Avatar
Rep: 1 (Unique: 1)
Hi,
Sadly, they only offer CE now in the 420mm size that I need. Should I look at XSPC or another company that you use?
WhiteOut
(12 items)
Intel i9 7900X
Samsung 850 Evo 1TB
EVGA G2 Platinum
Operating System
ZeroC00L is offline
post #10 of 22 (permalink) Old 03-14-2020, 11:07 AM
ThrashZone's Avatar
Hi,
XSPC is okay
Think everyone that needs a slim radiator focusing on low rpm fans goes hardware labs GTS series
http://hardwarelabs.com/nemesis/gts/420gts/
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
Tags
Ekwb , Intel , Radiator , running hot , Water Cooling
