Basic CPU loop - Overclock.net - An Overclocking Community
Basic CPU loop
post #1 of 15 (permalink) Old 03-14-2020, 05:33 PM - Thread Starter
Perf/W is for pussies
Rep: 1 (Unique: 1)
Basic CPU loop
So I am playing with the idea of a custom loop as opposed to an Arctic 280 AIO to cool an upcoming 8 core Intel CPU. I have come up with the following list of parts, and I wanted to get everyone's opinions.
1 block: https://www.performance-pcs.com/barr...-04-v2-bk.html
6 fittings: https://www.performance-pcs.com/ek-s...-10-16-bk.html
Tubing 6ft black rubber:
https://www.performance-pcs.com/ek-t...t-bk-3858.html
or clear:
https://www.performance-pcs.com/wate...-clr-3858.html
5x Arctic P14 PWM fans:
https://www.amazon.com/gp/product/B0...44WTLWGU&psc=1
800LPH PWM pump:
https://www.amazon.com/gp/product/B0...DAQIYG2U&psc=1
Reservoir:
https://www.amazon.com/gp/product/B0...38744OO1&psc=1
420mm copper radiator:
https://www.amazon.com/gp/product/B0...Q8489ITV&psc=1
Will the 800LPH pump be able to achieve a good flow rate for this large of a radiator?
Is there any reason I would need a larger/smaller tubing?
The hose(s) I am considering are 3/8ID 5/8OD either black rubber or clear PVC.
The black rubber seems to be similar to the type used in most radiator situations so that was my first choice.
I wonder however if the benefits of clear tubing might outweigh any benefits of the black rubber (if there are any benefits, I'm not sure there are) The perceived benefit would be strength/safety, but I'm not sure that applies here as I don't think the black rubber tubing is reinforced like other radiator hoses.
Are the fittings of sufficient quality?
I made sure to get compression fittings over barb/clamp style, as safety is paramount. The $$ worth of equipment in play is far more important than saving a couple dollars, but my budget is stretched pretty far already, so I am hoping I can get away with pretty close to this.
I am more worried about something like springing a leak rather than the pump failing for example. In that case the CPU should just throttle itself down to safety, whereas a leak would directly damage a lot of equipment.
The CPU block is nickel plated copper, while the radiator is just copper. Will this combo work without corrosion long term? If not what should be changed?
Is there anything else I should adjust in my design?
Is there anything else I am missing?
The PWM fans will be hooked up in tandem to the MB's PWM controller and spin based on current temps. Should the pump be connected in tandem as well, so that the flow would be proportional to the fan speed?
Or on its own independently/manually controllable PWM?
My cooling goals are to have both a quiet/effective cooling solution for everyday use, along with the ability to crank out maximum cooling for OC when necessary.
Thanks in advance!
Workstation
(10 items)
Workstation 2
(6 items)
Workstation 3
(5 items)
i7-860 [email protected]
EVGA P55 SLI E655
EVGA RTX-2070S FTW3
Team [email protected] 1591 @ 11-11-11-29
Samsung 860 Evo 1TB
Intel 900P
OCZ 750W StealthXstream
Arcitc Liquid Freezer 280mm
Operating System
LInux+windows gaming
Phillips 55" 4k HDR
i5-3340
Gigabyte GA-B75-D3H
Geforce 8400GS
GSKILL Ripjaws DDR3 1600
1TB Spinning rust
Corsair CX-500
i5-2400
1TB Spinning rust
OCZ 500W StealthXstream
Stock Intel Cooler
Operating System
Linux
ctrnull is offline
post #2 of 15 (permalink) Old 03-14-2020, 08:06 PM
sakete's Avatar
Rep: 10 (Unique: 9)
For fittings, don't get EK. Quality on those is iffy. Go for Bitspower, which are overall the best.
Also for tubing, if you want to stick with black tubing, go for Tygon A-60-G, which is higher quality and more consistent in terms of shape and dimensions. The EK ZMT apparently has a lot of quality variation and sometimes the thickness is slightly off, which could cause issues with your fittings.
Clear tubing is nice but they will probably all eventually start leaking plasticizer, gunking up your blocks. Tygon A-60-G should be very maintenance free.
Mixing nickle plated copper with copper rad is perfectly fine and will not cause corrosion. Just make sure to use a good coolant with an inhibitor in it, like Mayhems X1 (generally considered the best). Also just go for a clear coolant. Colored coolants and pastel coolants eventually will leave gunk in your blocks, requiring cleaning.
Keep in mind that often nickle plated copper is cheaply done, and it will eventually start flaking and get in the rest of your loop, gunking things up. I believe Optimus is one of the few, if not the only, that uses very high quality nickle plating that should last for many years.
In general, better to do it right once, than save money now and later having to spend again because you need to upgrade. Of course I understand there are sometimes real budgetary constraints, but then I'd consider waiting and saving more.
Oh, and get a D5 pump + reservoir combo. Reliable and durable, and plenty of power, even for more restrictive loops. Make sure it's made by Laing or Xylem (many of the brands that sell them are relabeled Laing or Xylem, though sometimes they're fake).
Main
(17 items)
AMD Ryzen 9 3900X
Asus X570 ROG Crosshair VIII Formula
EVGA GTX 980Ti SC+
2x 16GB G.Skill Ripjaws DDR4-3600 C16
1TB Samsung 970 EVO+ NVMe
1TB Samsung 850 EVO SSD
480GB SanDisk Extreme Pro
3x 4TB HGST Deskstar NAS (2 in RAID 1)
Seasonic Prime PX-1000
Optimus Foundation AM4
HWLabs GTS 360 XFLOW
Phanteks Enthoo 719/Luxe 2
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
sakete is offline
post #3 of 15 (permalink) Old 03-14-2020, 08:38 PM
I can count to potato
Fluxmaven's Avatar
Rep: 49 (Unique: 20)
Can you afford to be without the machine? If you have a spare PC or don't mind downtime, it would work fine with the components selected. I personally wouldn't bother with a cheapo pump though. I currently run D5's in all my loops and they are perfect.
Also I would argue that barb fittings with clamps are actually more secure than compression fittings as the clamp adjusts to the size of the tubing. With compressions, if for example you get a batch of tubing with too thin of walls the compression collar may not lock down tightly.
I would run pump PWM signal separate from fans. Personally, I leave it at a fixed speed. Pumps can have odd noise or resonance at various speeds. Run it at 100% when filling and bleeding the loop, then just dial it back to a speed where you are comfortable with the noise (or lack of it).
As for stuff that's missing, I would add decoupling kit to mount whatever pump you get. If you want to be as silent as possible these help a ton. https://www.performance-pcs.com/wate...-ac-13505.html
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #4 of 15 (permalink) Old 03-15-2020, 03:01 AM
Rep: 0
I prefer barb fittings w/ worm clamps because they feel more secure and are little cheaper so I agree with Fluxmaven on that. Also I've had multiple ek products shed nickel plating so I only use straight copper blocks, preferably not theirs.
Don't take this the wrong way but it seems like you are trying to piece together a cheap version of a custom w/c setup which never ends well. Cheaper w/c pieces will not work as well and will not last as long as quality products which could potentially damage your other expensive computer parts and waste your money and time. I'm all for saving a buck but when it comes to water cooling it simply isn't worth it. I would save more and buy quality parts. Again, I'm not saying this to be harsh, just some advice.
Second
(10 items)
Backup
(9 items)
Intel 6600K
ASUS Sabertooth Z170 Mark 1
ASUS GTX 970 STRIX
Team Group Pro Dark PC3200
Samsung SSD
Western Digital Blue
Silverstone
Thermochill 120x3 Radiator
Alphacool Monsta 120x2 Radiator
Switech MCP655 Pump
XSPC Raystorm Chrome Edition CPU Block
Monsoon 1/2" ID x 3/4" OD Compression Fittings
Phanteks Enthoo Primo
Operating System
Windows 10
ASUS VG248QE
Keyboard
Razer Ornata Chroma
Mouse
Logitech G502 Hero
Mousepad
Steelseries
Audio
Sennheiser headphones
Intel 4690K
MSI Z87I-Gaming
eVGA GTX 970
Corsair Dominator Platinum
Intel SSD
Corsair
Cooler Master Hyper 212-X
BitFenix
Operating System
Win 10
Intel 4570
ASUS Z87I-Deluxe
ASUS GTX 970 Strix
Gskill PC2133
Samsung SSD
Corsair 650w
Cooler Master Hyper 212X
Some random mini-ITX case
Operating System
Win 10
BugFreak is offline
post #5 of 15 (permalink) Old 03-15-2020, 03:11 AM
Meep
Gilles3000's Avatar
Rep: 327 (Unique: 234)
Barb fittings are good indeed, but worm clamps are way overkill, unpractical and don't look paricularly nice. A decent spring clamp is plenty good.
Do agree on a straight copper/brass loop though, so much more reliable and less hassle.
Cheaper watercooling gear has gotten way better as well. Barrow and Bykski make some excellent quality stuff, not quite Watercool(Heatkiller) or Aquacomputer, but definitely comparable to Alphacool, XSPC etc.
Heck, barrow probably makes the best bang for your buck fittings atm. The fact that Watercool is selling Barrow fittings on their store should tell you plenty.
Gilles3000 is offline
post #6 of 15 (permalink) Old 03-15-2020, 04:34 AM
Rep: 0
Good to know for sure. I'll have to read up on them a bit for my next build. Thanks for that.
I've used the plastic clamps too but I have so many worm clamps laying around at this point I just reuse them for nothing else but habit. Granted they don't look that clean but when positioned right they really cant be seen except for the chrome loop.
Second
(10 items)
Backup
(9 items)
Intel 6600K
ASUS GTX 970 STRIX
Samsung SSD
Silverstone
Switech MCP655 Pump
Operating System
Windows 10
ASUS VG248QE
Keyboard
Razer Ornata Chroma
Mouse
Logitech G502 Hero
Mousepad
Steelseries
Audio
Intel 4690K
MSI Z87I-Gaming
eVGA GTX 970
Intel SSD
Corsair
BitFenix
Operating System
Win 10
Intel 4570
ASUS Z87I-Deluxe
ASUS GTX 970 Strix
Gskill PC2133
Samsung SSD
Corsair 650w
Operating System
Win 10
BugFreak is offline
post #7 of 15 (permalink) Old 03-15-2020, 09:08 AM
New to Ryzen
chas1723's Avatar
Rep: 2 (Unique: 2)
I would not go with EK fittings. Seen too many issues with them. Barrow makes some good ones.
Cheaping out on the pump will lead to disaster. Get a D5 and be done with it.
Looks like you are trying to water cool on the extreme side of cheap. If you dont have the money, then stick to air cooling.
Sent from my SM-N950U using Tapatalk
3800x
(18 items)
3800x
Asrock x570 Taichi
EVGA 980ti
G.Skill Trident Z Neo
Western Digital BLACK SERIES
Samsung 830 Series
Samsung 850 Pro Series
Silicon Power M.2-2280 NVME Solid State Drive
Optical Drive
LG UH12NS29 Blu-Ray Reader, DVD/CD Writer
SeaSonic PRIME Ultra Titanium 750 W 80+ Titanium Certified Fully Modular ATX Power Supply
EK EVO Copper CPU block
EK Titan X Copper GPU block
Alphacool NexXxos XT45 360 Radiator
Alphacool NexXxos XT45 420 X-Flow Radiator
Aquacomputer Aqualis 150mm
Phanteks Enthoo Series Primo Aluminum ATX Full Tower Case
Operating System
Windows 10 Home
BenQ SW271 27.0" 3840x2160
chas1723 is offline
post #8 of 15 (permalink) Old 03-15-2020, 04:11 PM - Thread Starter
Rep: 1 (Unique: 1)
@Fluxmaven
Absolutely, got it. Thanks, that is a great addition at minimal cost!
Also, Ill come up with a small pwm controller to set the pump separate.
@BugFreak
Points well taken. This is why I asked around here first. I have much experience with watercooling, and cooling in general but not in the pc space.
@Gilles3000
Good to hear, I'm glad they make quality stuff.
Thanks!
@sakete
Thats funny, the Tygon A60G was actually my first choice. The only reason that changed because I couldn't find it on either of the sites I had already enlisted and didn't want to pay another shipping charge.
Looks like USplastics is the only place to get it by the foot. I looked all over performance-pcs for it, and amazon but only in long length and for $$.
So black radiator hose style like in cars and refrigeration systems such it is. While I didn't want to miss out on the convenience of being able to visually see the flow or lack thereof, I am glad that there is a good reason to use standard black tubing. Not that I am building for looks, but I prefer the simple black hose look to anything flashy.
I appreciate the comment about colored coolants, and you should continue to give it as advice, but I would never do something as stupid as using colored coolant in a WC setup
I was hoping to stay around $200 which is just about what that list adds up to, but I will budget another hundred in order to have a quality pump. There are a lot of D5 pump/motor/reservoir options out there. Anyone want to point one out that has a real Xylem or Laing, and minimal cost. Most are over 150, but I will be saving 45 on the cheap pump so I that's pretty close. I just want to make sure I get the best pump/housing quality possible for that much if its going to cost that much. If there are solid options under that Please share as well!.
I agree, barb fittings+clamps are highly effective and used almost everywhere in the industry.
However. I have used too many hose clamps to trust then with my computer. Hose clamps when tightened down, and after time, especially when wrapped around a small diameter, tend to break easier cause the spring metal is bent around a sharper corner.
The great thing is, the hose clamp failing alone usually will not spring a leak, as the barbs themselves are highly efficient. The Clamp is just there for a little extra support
While this may be likely the case for a WC setup, it was not the case when the hose clamp broke on my water main. The water pressure was just too high.
I'm gonna go with the screw down ones and avoid failing hose clamps altogether.
Here are 3 I came up with:
https://www.performance-pcs.com/wate...3-8-v3-bk.html
https://www.performance-pcs.com/wate...f-cc5v2-d.html
https://www.performance-pcs.com/wate...1-4-cf-bk.html
I actually like the Swiftech ones the best because they have standard wrench grooves where the others do not.
Are the Swiftech quality like the barrow or Bitspower listed?
Which would you suggest?
Thanks again!
Did you know that 20 US states currently have proposed Digital Right to Repair bills which are moving through the system at various stages? Contact your state's representatives and make sure they understand how important our fair use rights are in the digital age! It is extremely unlikely these will ever see a general election.
Do yourself and the internet a solid and don't use Google. Set Duckduckgo as your default search engine in your browser now for a tracker free search experience!
Workstation
(10 items)
Workstation 2
(6 items)
Workstation 3
(5 items)
EVGA P55 SLI E655
EVGA RTX-2070S FTW3
Samsung 860 Evo 1TB
Intel 900P
Operating System
Phillips 55" 4k HDR
i5-3340
Gigabyte GA-B75-D3H
Geforce 8400GS
1TB Spinning rust
Corsair CX-500
i5-2400
1TB Spinning rust
Stock Intel Cooler
Operating System
Linux
ctrnull is offline
post #9 of 15 (permalink) Old 03-15-2020, 04:52 PM
Fluxmaven's Avatar
Thanks again!
I actually own all 3 of the fittings you listed, and they are all great. If you don't mind the look of the Swiftech they are a great option. The Barrow ones have a notch cut out so you can use a large coin or a whatever to break them loose if needed. One other thing that stands out is the Bitspower fitting you linked is a different size than the other two. 1/2x3/4" which is what I typically run since I like the look of the thicker tubes, but it can be harder to work with than the smaller sizes.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
GTX 1080 FE
WD Black SN750
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Mouse
Glorious Model O
Mousepad
Audio
Audio
Focusrite 2i4 Gen2
Audio
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
WD Blue 3D m.2
Corsair AX760
InWin D-Frame Mini
i7 6700
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
post #10 of 15 (permalink) Old 03-15-2020, 05:57 PM
sakete's Avatar
Rep: 10 (Unique: 9)
Thanks!
Thanks again!
Yeah, $200 for a custom loop isn't realistic. For something decent you're looking at $500+ at a minimum. For something great, closer to $1k. But it's your money
For D5 pumps, look at the Heatkiller reservoir+D5 pump combo, or an Aquacomputer D5 pump + one of their reservoirs (check compatibility first). XSPC should als be fine. Easiest to get pump + res from same brand, as then you can be sure that the res will fit on the pump. I think the EK D5 pumps are good as well, but I don't know about the quality of their reservoirs. Best quality is a glass reservoir or cast acrylic (only one brand offers cast acrylic, Optimus, but they're very expensive).
FrozenCPU also sells Tygon A-60-G by the foot, and fittings and a whole bunch of watercooling stuff. Use discount code OCN to get 6% off there. If you call them they'll sometimes give you an additional discount depending on how much you're buying.
Main
(17 items)
AMD Ryzen 9 3900X
EVGA GTX 980Ti SC+
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
sakete is offline
