Wanting complete water cooling system recommendations for Lian Li 011 Dynamic XL - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 03-15-2020, 06:10 PM - Thread Starter
Rep: 69 (Unique: 60)
I'm putting together and water cooling system and already have the Lian Li 011 Dynamic XL and matching 011 Dynamic/Dynamic XL D-RGB+DDC 3.1 distribution plate. Now all that's needed is the radiators selection, RGB controller for the case and distribution plate since Rog Maximus-V Gene Formula Extreme doesn't have an RGB controller. I'm a Hardware Labs fan and currently own two SR-1 560 radiators (8 Gentle Typhoons 1600 rpm) was eyeballing the 360 SR-2 and GTS 360 for my new build, but would need to run a pull only on the SR-2.
The Lian Li 011 Dynamic XL has 85mm clearance on the bottom and 74mm on the top, I'm looking for silence 1000-1300 rpm fans (considering the Gentle Typhoons are to audible at 4-5 feet) and want capacity and cooling performance at the low-mid speed fans for future expansion.
Also anyone here think I should replace the DDC 3.1 with a higher power model?
Your recommendation and expertise is welcome.
Systemlord is offline
post #2 of 7 (permalink) Old 03-16-2020, 01:16 AM
poah's Avatar
Rep: 7 (Unique: 6)
arctic P12 fans are cheap, quiet and work very very well. I would check your actual clearance for the length and width of the HWL rads in that case more than the thickness.
poah is offline
post #3 of 7 (permalink) Old 03-16-2020, 04:51 AM
Pepillo's Avatar
Rep: 4 (Unique: 4)
A few weeks ago I built my equipment in that case. I replaced the distro plate pump, a DDC 3.1 for a 3.20 DDC, and kept the original as a spare, just in case it breaks down. I attach a photo and a pdf with the components used in the liquid in case they help you.
Lian Li O11 Dynamic XL + EK O11D Distro-Plate G1 DDC 3.2 + 2x360 EK Radiators - Aorus RTX 2080 TI Fullcover [email protected]/15000 - EVGA Supernova 1600 - Corsair K95 + Dark Core SE/MM1000 - X27P 4K HDR1000 Gsync 144 Hz - Lenovo Explorer
Asus Prime X299 Deluxe - i9 [email protected]/3.2 Delid - 4x8 G.SKILL RipjawsV [email protected] C17 1T - Intel Optane 900P NVME - Crucial MX300 2TB - Samsung EVO 860 4TB + Optane 32GB - 2X2TB WD Raid - DAC Teac UD H01 + AKG K612 Pro + 2.1 Studio
Pepillo is offline
post #4 of 7 (permalink) Old 03-16-2020, 12:15 PM - Thread Starter
You just saved me from a major headache, thank you! I canceled my order for the Hardware labs radiators which will not fit! I never thought the Hardware labs radiators were that much different in size, I never owned any other brand and figured they were all the same.
post #5 of 7 (permalink) Old 03-16-2020, 12:20 PM - Thread Starter
I appreciate the link to your build/components, thank you.
post #6 of 7 (permalink) Old 03-16-2020, 01:53 PM
poah's Avatar
Rep: 7 (Unique: 6)
thats why I went for the phanteks P600s over the 011 dynamic.
poah is offline
post #7 of 7 (permalink) Old 03-16-2020, 02:39 PM - Thread Starter
Actually I was mistaken, they will fit. The Hardware Labs radiators are 14mm off the threads mounts from the fans mounts or 105mm from thread to thread and a total of 133mm wide, so I measured 14mm off each hole and actually have room to spare. Being able to use the SR-2 will spare me a lot of restriction to compensate for the restrictive GTS 360. I really wanted a second SR-2 on top, but that was never in the cards.
At least now we know for certain the Lian Li Dynamic XL can fit 120mm Hardware Labs radiators.
