Help me build my first custom loop - Page 6 - Overclock.net - An Overclocking Community
post #51 of 56 (permalink) Old 03-26-2020, 02:06 AM
Meep
Gilles3000's Avatar
Rep: 327 (Unique: 234)
Quote: Originally Posted by CrazyDiamond View Post
I got my pump/res in today. I just realized once it's mounted in the case I will be unable to change the speed. So, what speed should I set it to? I've heard I should run it at full or vary the speed to get the air out but I don't think that will be possible once it's installed unless I run it at full constantly etc.
Is it not a PWM model? If its the Vario(with the dial, and no 4-pin fan connector), yeah you're stuck with what its set to.
Gilles3000 is offline
post #52 of 56 (permalink) Old 03-26-2020, 03:38 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
100% and leave it
Need it to get the air out and keep it out.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #53 of 56 (permalink) Old 03-26-2020, 03:52 AM
skline00's Avatar
Rep: 16 (Unique: 14)
When I do a new build and after leak testing AND moving the case around to try and release air pockets from the rads, etc., I run at high speed for 48-72 hours min to get rid of the bubbles.
Take your time and don't panic.
You'll be fine. Relax and play some video games.
And if you need extra cooling capacity let me know. I have an unused MO-RA3-420 Pro rad that could be run!
9900k-5.0-Kraken X72|Asrock Z390 Taichi|32g-DDR4-3200 FlareX|EVGA GTX 2080TI XC | Corsair MP500-480g|EVGA 1000W|Thermaltake V51|Acer ET430k|Win10-64 home
3900x stock Custom WC Optimus WB 360 +240 rads EK D5|MSI X570 Unify|32g-DDR4-3600 TridentZ Neo|Asrock Radeon VII-EK block |Sbrent Rocket 1tb NVME4|Corsair RX850|Phantek Ethoo Pro|BenQ EX3501R+Oculus Rift
skline00 is offline
post #54 of 56 (permalink) Old 03-26-2020, 04:13 AM - Thread Starter
Crazy
CrazyDiamond's Avatar
Rep: 17 (Unique: 16)
It's not PWM, connected with 4pin Molex. Has the red dial on the bottom, so I guess that would be vario.
Quote: Originally Posted by ThrashZone View Post
Hi,
100% and leave it
Is it not bad to run at 100% all the time? Higher wear?
Thanks! Just concerned with it being stuck on 100% all the time. The pump is mounted to a plate below it that is going to stop me from changing speeds once it's mounted in place. Unless maybe I do some drilling.
And wow that's a huge rad!
Waiting on tubing, cpu block, and mayhems stuff to come in. Hopefully, it'll come by Friday and I'll be able to finish everything this weekend!
CrazyDiamond is offline
post #55 of 56 (permalink) Old 03-26-2020, 04:16 AM
ThrashZone's Avatar
Hi,
No you'll be fine at 100%
Only quirk about vario is do not over turn it past the #5 it might actually slow down.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #56 of 56 (permalink) Old 03-27-2020, 09:19 PM - Thread Starter
Crazy
My tubing came with a bottle of Primochill SysPrep. Is there a consensus on this? Should I use it? Should I flush it out after if I do?
